[GSoC]Todo in POSIX Key project
Ashi
ashi08104 at gmail.com
Wed Aug 8 08:00:58 UTC 2012
2012/8/7 Gedare Bloom <gedare at rtems.org>
> On Tue, Aug 7, 2012 at 10:06 AM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
>> On 08/07/2012 06:30 AM, Ashi wrote:
>> Hi, all.
>> Here is a short description of my first approach to POSIX Key project and
>> an alternative approach. I haven't decided whether I should proceed to
>> implement the alternative, and need discussion.
>> Just to remind everyone, both of these approaches are better than the
>> current approach
>> which is simply broken for unlimited task/threads.
>> - Current approach: one rbtree approach
>> In this approach, there is only one rbtree which is used to manage all
>> POSIX Keys' data. If there are m POSIX Keys and t POSIX Threads, and each
>> Thread has m Key values, then there is n( n = m x t ) nodes in the global
>> rbtree. And the worst-case runtime of key deletion, thread deletion, key
>> setspecific and key getspecific are all O(lg(n)), and the key creation
>> operation has a constant runtime O(1). This approach is implemented now,
>> which is in my first pull request[0].
>> Is thread deletion actually O( lg(n) + m ) or O( m * lg(n) ) depending on
> how you implement iterating through the deleted thread's keys?
> Yeah, after re-check the keyrundestructor() function, it's runtime should
be O( m * lg(n) ).
> I have made some more comments on your pull request.
IMO create and delete times are not as critical as set/get.
>> This approach is simpler and that generally is more desirable. Neither
>> approach completely
>> resolves the nature that when pushed far enough, the approach gets
>> pushed. Can we put
>> a rough instruction per m & T cost on set and get? For example, if this
>> were a simple loop
>> of a chain, we would be fetching memory, checking for end of chain,
>> looking for match, etc.
>> We can count the memory accesses and rough instruction count (e.g. cmp,
>> branch, etc).
>> In practical terms, the seemingly growth in execution time per "unit"
>> increased may be
>> fairly small and not be critical until 100s or 1000s of tasks/keys are in
>> the system. Our
>> expected "normal worst case" is likely a few (2-3) keys and 100 tasks.
>> That would be a
>> huge system in my experience. Most systems are likely to be only 1 key
>> and a few dozen
>> tasks at most.
>> I agree. Maybe you can get cycle counts for the key operations from some
> timing test? Is there one already in the tree? If not you could write one
> in psxtiming.
There is 2 benchmark tests in psxtmtests:
psxtmkey01 tests key create and key delete
psxtmkey01 tests key setspecific and key getspecific
Is it enough for runtime test, or should I add runtime test under
multi-keys and multi-threads?
>> - Alternative approach: one rbtree per thread approach
>> Suppose there are also m POSIX Keys and t POSIX Threads in the system,
>> then each thread maintains one rbtree, all key data of specific thread is
>> in that rbtree. For example, say if each thread has m Key values, then
>> there are m nodes in each thread's rbtree. Gedare suggested if there is no
>> clear advantage than current approach, it may be not worth trying to
>> implement this. So I try to figure out the advantage of this approach than
>> current one. The runtime of this approach:
>> (here n = m x t, there are m keys and t threads)
>> Key create: O(1), create one key
>> Key delete: O(tlg(m)), when key deleted, we must search each thread's
>> rbtree to delete the specific key's node, there are t rbtree and each has m
>> nodes.
>> Key setspecific: O(lg(m)), insert one node to m-k nodes rbtree, in which
>> k is constant.
>> Key getspecfic: O(lg(m)), search in m nodes rbtree
>> Thread delete: O(lg(m)), traverse the m nodes rbtree to release each
>> node's data
>> I believe thread delete is O(m). Deleting a thread must require at least
> O(m) to deal with all of the keys of that thread when the keys are managed
> separately (i.e. no "bulk delete" operation is available).
Yeah, I think I have made a mistake here, it should be O(m).
>> Compared to one rbtree approach, the runtime of Key setspecific,
>> getspecific and thread delete are better. Though lg(m) = lg(n/t) = lg(n) -
>> lg(t), not much better. But the key delete's runtime O(tlg(m)) is kinds of
>> slow than O(lg(n)) when n > n0, and O(tlg(m)) = O(tlg(n/t)), I also have
>> drawn a comparison[1] between tlg(n/t) and lg(n) to illustrate. So there
>> are both some advantage and disadvantage in this alternative approach. IMO,
>> there seems not much advantage than current approach. However, I'm still
>> not sure whether I should give up this alternative. Maybe I have missed
>> some advantage in this approach.
>> Don't lose this. Please write up the O(x) information on the approaches
>> in your project page
>> in the RTEMS Wiki. Include any factors in our decision... etc
>> This write up is very good. Please put a table of the characteristics of
>> each algorithm
>> in O(), space, etc. Capture the same information for each approach.
>> This will really help in the future when we all ask the same questions
>> again. Trust me,
>> we all have shorter memories than the life of this code.
> I see and glad to add this:)
>> - BTW, there is also a hash approach discussed before, however, it's
>> worst case runtime is lg(n), and may be unacceptable to RTEMS as Sebastian
>> suggested before[2].
>> I also made a typo here, the runtime of hash approach is actually O(n).
> I think it also has the disadvantage that we would have to add hash code
>> to RTEMS score
>> which is not there now. The other approaches reuse a score object.
> I see.
>> And another problem is how to know or analysis the memory overhead of
>> these approaches on RTEMS. I've no idea about that yet. Could anyone give
>> me some advice?
>> This last point I think is important. My intuition is that having a
> separate rbtree for each thread will substantially bloat the memory
> overhead. One way to get a handle on this is to estimate the size of the
> structures that will be involved. That is, how many bytes in an rbtree
> header, how many in an rbtree node, and how many of each is created for
> your two approaches? This is pretty simple arithmetic and is also the way
> to determine how much workspace size to reserve for these structures.
> OK, I'll count all the bytes and post the result later.
> -Gedare
>> links:
>> [0]:https://github.com/RTEMS/rtems/pull/3
>> [1]:
>> https://docs.google.com/drawings/d/1P4B9ePAN57OGVywxDhsOVwne1JvGEmyPaGb0RvFolKo/edit
>> [2]:http://www.rtems.org/pipermail/rtems-devel/2012-May/001138.html
>> Best wishes!
>> Zhongwei Yao
>> Joel Sherrill, Ph.D. Director of Research& Developmentjoel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
Best wishes!
Zhongwei Yao
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120808/00da47ba/attachment-0001.html>
