[PATCH] score: Change _Heap_Extend() API
Thu Aug 9 15:07:23 UTC 2012
The _Heap_Extend() has now the same signature as _Heap_Initialize().
The 4th parameter is ignored (page size in _Heap_Initialize()).
Add Heap_Area and Heap_Initialization_or_extend_handler.
Add and test _Heap_No_extend().
This helps to do a table based heap initialization and extension.
Create a table of Heap_Area elements and iterate through it.  Set the
handler to _Heap_Initialize() in the first iteration and then to
_Heap_Extend().
 cpukit/rtems/src/regionextend.c         |    7 ++--
 cpukit/score/Makefile.am                |    2 +-
 cpukit/score/include/rtems/score/heap.h |   59 +++++++++++++++++++++++++++---
 cpukit/score/src/heapextend.c           |   15 +++-----
 cpukit/score/src/heapnoextend.c         |   37 +++++++++++++++++++
 cpukit/score/src/pheapextend.c          |    7 ++--
 testsuites/libtests/malloctest/init.c   |    4 ++
 7 files changed, 107 insertions(+), 24 deletions(-)
 create mode 100644 cpukit/score/src/heapnoextend.c
diff --git a/cpukit/rtems/src/regionextend.c b/cpukit/rtems/src/regionextend.c
index cf4489e..205534b 100644
--- a/cpukit/rtems/src/regionextend.c
+++ b/cpukit/rtems/src/regionextend.c
@@ -46,7 +46,6 @@ rtems_status_code rtems_region_extend(
   uintptr_t           amount_extended;
-  bool                extend_ok;
   Objects_Locations   location;
   rtems_status_code   return_status;
   Region_Control     *the_region;
@@ -61,14 +60,14 @@ rtems_status_code rtems_region_extend(
       case OBJECTS_LOCAL:
-        extend_ok = _Heap_Extend(
+        amount_extended = _Heap_Extend(
           &the_region->Memory,
           starting_address,
           length,
-          &amount_extended
+          0
-        if ( extend_ok ) {
+        if ( amount_extended > 0 ) {
           the_region->length                += amount_extended;
           the_region->maximum_segment_size  += amount_extended;
           return_status = RTEMS_SUCCESSFUL;
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index cb512e4..dedcec7 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -178,7 +178,7 @@ endif
 libscore_a_SOURCES += src/heap.c src/heapallocate.c src/heapextend.c \
     src/heapfree.c src/heapsizeofuserarea.c src/heapwalk.c src/heapgetinfo.c \
     src/heapgetfreeinfo.c src/heapresizeblock.c src/heapiterate.c \
-    src/heapgreedy.c
+    src/heapgreedy.c src/heapnoextend.c
 ## OBJECT_C_FILES
 libscore_a_SOURCES += src/objectallocate.c src/objectclose.c \
diff --git a/cpukit/score/include/rtems/score/heap.h b/cpukit/score/include/rtems/score/heap.h
index 8e6220c..964386a 100644
--- a/cpukit/score/include/rtems/score/heap.h
+++ b/cpukit/score/include/rtems/score/heap.h
@@ -388,6 +388,33 @@ typedef enum {
 } Heap_Resize_status;
+ * @brief Heap area structure for table based heap initialization and
+ * extension.
+ * @see Heap_Initialization_or_extend_handler.
+typedef struct {
+  void *begin;
+  uintptr_t size;
+} Heap_Area;
+ * @brief Heap initialization and extend handler type.
+ * This helps to do a table based heap initialization and extension.  Create a
+ * table of Heap_Area elements and iterate through it.  Set the handler to
+ * _Heap_Initialize() in the first iteration and then to _Heap_Extend().
+ * @see Heap_Area, _Heap_Initialize(), _Heap_Extend(), or _Heap_No_extend().
+typedef uintptr_t (*Heap_Initialization_or_extend_handler)(
+  Heap_Control *heap,
+  void *area_begin,
+  uintptr_t area_size,
+  uintptr_t page_size_or_unused
  * @brief Gets the first and last block for the heap area with begin
  * @a heap_area_begin and size @a heap_area_size.
@@ -419,6 +446,8 @@ bool _Heap_Get_first_and_last_block(
  * @c CPU_ALIGNMENT, it is aligned up to the nearest @c CPU_ALIGNMENT boundary.
  * Returns the maximum memory available, or zero in case of failure.
 uintptr_t _Heap_Initialize(
   Heap_Control *heap,
@@ -431,22 +460,40 @@ uintptr_t _Heap_Initialize(
  * @brief Extends the memory available for the heap @a heap using the memory
  * area starting at @a area_begin of size @a area_size bytes.
- * The extended space available for allocation will be returned in
- * @a amount_extended.  This pointer may be @c NULL.
  * There are no alignment requirements.  The memory area must be big enough to
  * contain some maintainance blocks.  It must not overlap parts of the current
  * heap areas.  Disconnected subordinate heap areas will lead to used blocks
  * which cover the gaps.  Extending with an inappropriate memory area will
  * corrupt the heap.
- * Returns @c true in case of success, and @c false otherwise.
+ * The unused fourth parameter is provided to have the same signature as
+ * _Heap_Initialize().
+ * Returns the extended space available for allocation, or zero in case of failure.
-bool _Heap_Extend(
+uintptr_t _Heap_Extend(
   Heap_Control *heap,
   void *area_begin,
-  uintptr_t *amount_extended
+  uintptr_t unused
+ * @brief This function returns always zero.
+ * This function only returns zero and does nothing else.
+ * Returns always zero.
+uintptr_t _Heap_No_extend(
+  Heap_Control *unused_0,
+  void *unused_1,
+  uintptr_t unused_2,
+  uintptr_t unused_3
diff --git a/cpukit/score/src/heapextend.c b/cpukit/score/src/heapextend.c
index 9d2d587..cb60427 100644
--- a/cpukit/score/src/heapextend.c
+++ b/cpukit/score/src/heapextend.c
@@ -108,11 +108,11 @@ static void _Heap_Link_above(
   last_block->size_and_flag |= HEAP_PREV_BLOCK_USED;
-bool _Heap_Extend(
   Heap_Control *heap,
   void *extend_area_begin_ptr,
   uintptr_t extend_area_size,
-  uintptr_t *extended_size_ptr
+  uintptr_t unused
   Heap_Statistics *const stats = &heap->stats;
@@ -134,7 +134,7 @@ bool _Heap_Extend(
   bool extend_area_ok = false;
   if ( extend_area_end < extend_area_begin ) {
-    return false;
+    return 0;
   extend_area_ok = _Heap_Get_first_and_last_block(
@@ -147,7 +147,7 @@ bool _Heap_Extend(
   if (!extend_area_ok ) {
     /* For simplicity we reject extend areas that are too small */
-    return false;
+    return 0;
   do {
@@ -160,7 +160,7 @@ bool _Heap_Extend(
     if (
       sub_area_end > extend_area_begin && extend_area_end > sub_area_begin
-      return false;
+      return 0;
     if ( extend_area_end == sub_area_begin ) {
@@ -234,8 +234,5 @@ bool _Heap_Extend(
   /* Statistics */
   stats->size += extended_size;
-  if ( extended_size_ptr != NULL )
-    *extended_size_ptr = extended_size;
-  return true;
+  return extended_size;
diff --git a/cpukit/score/src/heapnoextend.c b/cpukit/score/src/heapnoextend.c
new file mode 100644
index 0000000..8a1585b
--- /dev/null
+++ b/cpukit/score/src/heapnoextend.c
@@ -0,0 +1,37 @@
+ * @file
+ * @ingroup ScoreHeap
+ * @brief Heap Handler implementation.
+ * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Obere Lagerstr. 30
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/score/heap.h>
+  void *unused_1,
+  return 0;
diff --git a/cpukit/score/src/pheapextend.c b/cpukit/score/src/pheapextend.c
index be23c70..5f1a4df 100644
--- a/cpukit/score/src/pheapextend.c
+++ b/cpukit/score/src/pheapextend.c
@@ -28,12 +28,11 @@ bool _Protected_heap_Extend(
   uintptr_t     size
-  bool      extend_ok;
   _RTEMS_Lock_allocator();
-    extend_ok = _Heap_Extend(the_heap, starting_address, size, &amount_extended);
+    amount_extended = _Heap_Extend( the_heap, starting_address, size, 0 );
   _RTEMS_Unlock_allocator();
-  return extend_ok;
+  return amount_extended != 0;
diff --git a/testsuites/libtests/malloctest/init.c b/testsuites/libtests/malloctest/init.c
index a93edc4..a044716 100644
--- a/testsuites/libtests/malloctest/init.c
+++ b/testsuites/libtests/malloctest/init.c
@@ -948,6 +948,7 @@ static void test_heap_extend(void)
   bool ret = false;
   Heap_Control *heap = &TestHeap;
   uint8_t *area_begin = TestHeapMemory;
+  uintptr_t extended_space;
   _Heap_Initialize( heap, area_begin + 768, 256, 0 );
@@ -982,6 +983,9 @@ static void test_heap_extend(void)
   puts( "heap extend - merge below with align up" );
   ret = _Protected_heap_Extend( heap, area_begin + 512, 256 );
   test_heap_assert( ret, true );
+  extended_space = _Heap_No_extend( NULL, 0, 0, 0 );
+  rtems_test_assert( extended_space == 0 );
 static void test_heap_info(void)
1.7.7
