[PATCH] libcsupport: Add and use rtems_debug_putc()
Mon Aug 13 20:23:57 UTC 2012
On 13/08/12 18:31, Gedare Bloom wrote:
> Would there be any problem with just using 'rtems_putc'? the
> rtems_debug_putc seems a little weird to me, because I think debug is
> misleading here; I would expect something named as rtems_debug to be only
> available when rtems-enable-debug is on, and otherwise conditionally
> unavailable.
Yes, I think also that the debug is not that good.  Joel was not happy
with "console".  This "console" is still the best scope name from my
point of view since the "console" is the default output device.
> Perhaps this is just me though. rtems_bsp_putc might be an ok alternative.
RTEMS + BSP in one name is complete nonsense.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
