coverage analysis failed
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Aug 13 20:56:36 UTC 2012
On 08/13/2012 03:44 PM, Krzysztof Mięsowicz wrote:
> Did you do a make install on your qemu build?
> I have done make install on my qemu build. I also see on my machine
> bios.bin and vgabios.bin but there is no sgabios.bin. Maybe its due
> some changes in couverture-qemu?
Is it in your source tree? In the source I have for the mips/malta
work, I used a git based on the official tree:
$ find ~/mips-malta/qemu/ -name "*bios.bin"
/home/joel/mips-malta/qemu/pc-bios/sgabios.bin
/home/joel/mips-malta/qemu/pc-bios/bios.bin
/home/joel/mips-malta/qemu/pc-bios/vgabios.bin
So it should be under pc-bios in the tree.
Do you have coverage output?
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120813/4413aef5/attachment-0001.html>
