rtems-libbsd: M68K linkcmds Patches Galore
Fri Aug 17 00:15:13 UTC 2012
Did you do a make preinstall after you did the bootstrap -p? I don't know if it will help or not.
If it doesnt , send me a patch for this and I will try to figure it out.
Kevin Polulak <kpolulak at gmail.com> wrote:
>On Thu, Aug 16, 2012 at 5:17 AM, Sebastian Huber <sebastian.huber at embedded-brains.de<mailto:sebastian.huber at embedded-brains.de>> wrote:
>The INCLUDE works inside a SECTIONS { ... } definition.
>Yeah, looks like I might've jumped the gun there. Turns out I was writing:
>INCLUDE(linkcmds.robsdsets);
>instead of the correct syntax:
>INCLUDE linkcmds.robsdsets
>In my opinion, a little inconsistant on GNU's part but whatever. :/
>That's only half the problem though. Prior to noticing that, I was just getting the ever-helpful "syntax error" message. Now I get "cannot open linker script file linkcmds.robsdsets: No such file or directory". Obviously, ld can't find my file.
>Right now, I've got things setup so that linkcmds.robsdsets sits in m68k/shared/startup and m68k/Makefile.am is aware of it with:
>dist_project_lib_DATA = shared/startup/linkcmds.robsdsets.
>I've already run ./bootstrap -p to regenerate m68k/preinstall.am<http://preinstall.am>. My memory could be wrong but I don't think there even was an m68k/preinstall.am<http://preinstall.am> file until I added the line:
>include $(srcdir)/preinstall.am<http://preinstall.am>
>I even re-bootstrapped just for good measure (still have no idea what that thing is for though; it would be nice if --help would so kindly tell me).
>I'm gonna hold off on submitting the rest of my patches until I can get this fixed. I'm sure it's just something simple that I overlooked. I can rewrite each .robsdsets section in seconds.
>- Kevin Polulak (soh_cah_toa)
>- http://cybercrud.net
