rtems-libbsd: M68K linkcmds Patches Galore
Sebastian Huber
Fri Aug 17 08:13:50 UTC 2012
On 08/17/2012 02:59 AM, Kevin Polulak wrote:
> diff --git a/c/src/lib/libbsp/m68k/mcf52235/startup/linkcmds b/c/src/lib/libbsp/m68k/mcf52235/startup/linkcmds
> index f5fe3d0..37b425f 100644
> --- a/c/src/lib/libbsp/m68k/mcf52235/startup/linkcmds
> +++ b/c/src/lib/libbsp/m68k/mcf52235/startup/linkcmds
> @@ -11,11 +11,13 @@
> - * Declare some sizes.
> + * Memory segment sizes.
> + * A heap size of 0 means that all available memory is used for the heap.
> -RamBase = DEFINED(RamBase) ? RamBase : 0x20000000;
> -RamSize = DEFINED(RamSize) ? RamSize : 32K;
> -HeapSize = DEFINED(HeapSize) ? HeapSize : 0x0;
> +RamBase = DEFINED(RamBase) ? RamBase : 0x20000000;
> +RamSize = DEFINED(RamSize) ? RamSize : 32K;
> +HeapSize = DEFINED(HeapSize) ? HeapSize : 0x0;
> _StackSize = DEFINED(_StackSize) ? _StackSize : 0x400;
> _FlashBase = DEFINED(_FlashBase) ? _FlashBase : 0x00000000;
I don't like this format. Each time you change the length of one field in the
columns you have to adjust other lines as well. This makes a review harder.
> - PROVIDE (_fini = .);
> + PROVIDE(_fini = .);
If you look at the default linker command file (e.g. m68k-rtems4.11-ld
--verbose) then you will see that the previous format is used here (space
before "(").
> diff --git a/c/src/lib/libbsp/m68k/shared/startup/linkcmds.robsdsets b/c/src/lib/libbsp/m68k/shared/startup/linkcmds.robsdsets
> new file mode 100644
> index 0000000..23a1d92
> --- /dev/null
> +++ b/c/src/lib/libbsp/m68k/shared/startup/linkcmds.robsdsets
> @@ -0,0 +1,29 @@
> + * This file contains directives for the GNU linker which are needed for
> + * rtems-libbsd FreeBSD code.
> + * COPYRIGHT (c) 1989-1999.
> + * On-Line Applications Research Corporation (OAR).
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + *http://www.rtems.com/license/LICENSE.e
> +__start_set_sysctl_set = .;
> +*(set_sysctl_*);
> +__stop_set_sysctl_set = .;
> +*(set_domain_*);
> +*(set_pseudo_*);
> +_bsd__start_set_modmetadata_set = .;
> +*(_bsd_set_modmetadata_set);
> +_bsd__stop_set_modmetadata_set = .;
> +_bsd__start_set_sysctl_set = .;
> +*(_bsd_set_sysctl_set);
> +_bsd__stop_set_sysctl_set = .;
> +_bsd__start_set_sysinit_set = .;
> +*(_bsd_set_sysinit_*);
> +_bsd__stop_set_sysinit_set = .;
Why is this linkcmds.robsdsets and not linkcmds.rortems?
Why do we have CPU specific variants of this? On ARM, PowerPC, etc. this file
would look like identical.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
