rtems-libbsd: M68K linkcmds Patches Galore
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Aug 17 14:34:48 UTC 2012
On 08/17/2012 08:46 AM, Ralf Corsepius wrote:
> On 08/17/2012 03:23 PM, Sebastian Huber wrote:
>> On 08/17/2012 03:02 PM, Joel Sherrill wrote:
>>>> Why do we have CPU specific variants of this? On ARM, PowerPC, etc.
>>>> this file
>>>> would look like identical.
>>> Some targets place a leading underscore in front of symbols. If you
>>> have every
>>> symbol both with and without an extra _ prepended, then it will be Ok.
>>> For
>>> example,
>>> both _bsd__stop_set_sysinit_set and __bsd__stop_set_sysinit_set would
>>> have
>>> to be defined.
>>> This is all the targets I have tools installed for and whether or not
>>> they add a
>>> leading underscore.
>>> arm-rtems4.11 - no leading underscore
>>> avr-rtems4.11 - no leading underscore
>>> bfin-rtems4.11 - leading underscore
>>> h8300-rtems4.11 - leading underscore
>>> i386-rtems4.11 - no leading underscore
>>> lm32-rtems4.11 - no leading underscore
>>> m32c-rtems4.11 - leading underscore
>>> m32r-rtems4.11 - no leading underscore
>>> m68k-rtems4.11 - no leading underscore
>>> microblaze-rtems4.11 - no leading underscore
>>> mips-rtems4.11 - no leading underscore
>>> powerpc-rtems4.11 - no leading underscore
>>> sh-rtems4.11 - leading underscore
>>> sparc64-rtems4.11 - no leading underscore
>>> sparc-rtems4.11 - no leading underscore
>>> v850-rtems4.11 - leading underscore
>> With this extra underscore can be dealt in the macros that generate
>> these symbols.
>> The CPU port should provide a macro like
>> #define CPU_LINKER_SYMBOL_NAME(_x) _ ## _x
>> or
>> #define CPU_LINKER_SYMBOL_NAME(_x) _x
> It's already there: cf. cpukit/score/cpu/<cpu>/*.h
So he can check that as well. The truth is what gcc actually does.
I produced that list by checking whether printf() in libc was printf
or _printf.
> Also GCC internally provides some preprocessor defines to help detecting
> them. Unfortunately, for historic reasons, there are cases these defines
> are broken.
>> Even if we deal with the underscore in the linker command files, then I
>> see only two variants and not one for each CPU.
> Openly said, I am not sure this currently ongoing effort will be a
> success. Several similar attempts in RTEMS history repeatedly had failed.
Sebastian has successfully converted a number of BSPs over to
shared linker scripts. It is a difficult task but that doesn't make it
impossible.
>> Is this underscore a GNU linker feature or defined in the ABI?
> It's an ABI feature.
> Ralf
> rtems-devel mailing list
> rtems-devel at rtems.org
Joel Sherrill, Ph.D. Director of Research& Development
