[PATCH] Print MCSR and ESR.
Ric Claus claus at slac.stanford.edu
Sat Dec 1 00:12:59 UTC 2012
The Machine Check and Exception Syndrome Registers on Book-E and Book-E-like
processors contain useful information for decoding the cause of an exception.
NB: This patch depends on the PR 2048 patch sent earlier having been applied.
 .../new-exceptions/bspsupport/ppc_exc_print.c      |   21 ++++++++++++++++---
 cpukit/score/cpu/powerpc/rtems/powerpc/registers.h |    5 ++++
 2 files changed, 22 insertions(+), 4 deletions(-)
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c
index 34233ba..6172ab6 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c
@@ -45,9 +45,9 @@ static uint32_t ppc_exc_get_DAR_dflt(void)
         break;
       case PPC_BOOKE_STD:
       case PPC_BOOKE_E500:
-        return PPC_SPECIAL_PURPOSE_REGISTER(DEAR_BOOKE);
+        return PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_DEAR);
       case PPC_BOOKE_405:
-        return PPC_SPECIAL_PURPOSE_REGISTER(DEAR_405);
+        return PPC_SPECIAL_PURPOSE_REGISTER(PPC405_DEAR);
   return 0xdeadbeef;
@@ -157,11 +157,24 @@ void _BSP_Exception_frame_print(const CPU_Exception_frame *excPtr)
   /* Would be great to print DAR but unfortunately,
    * that is not portable across different CPUs.
    * AFAIK on classic PPC DAR is SPR 19, on the
-   * 405 we have DEAR = SPR 0x3d5 and booE says
+   * 405 we have DEAR = SPR 0x3d5 and bookE says
    * DEAR = SPR 61 :-(
   if (ppc_exc_get_DAR != NULL) {
-    printk("  DAR = 0x%08x\n", ppc_exc_get_DAR());
+    char* reg = ppc_cpu_is_60x() ? " DAR" : "DEAR";
+    printk(" %s = 0x%08x\n", reg, ppc_exc_get_DAR());
+  if (ppc_cpu_is_bookE()) {
+    unsigned esr, mcsr;
+    if (ppc_cpu_is_bookE() == PPC_BOOKE_405) {
+      esr  = PPC_SPECIAL_PURPOSE_REGISTER(PPC405_ESR);
+      mcsr = PPC_SPECIAL_PURPOSE_REGISTER(PPC405_MCSR);
+    } else {
+      esr  = PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_ESR);
+      mcsr = PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_MCSR);
+    printk("  ESR = 0x%08x\n", esr);
+    printk(" MCSR = 0x%08x\n", mcsr);
   if (executing != NULL) {
diff --git a/cpukit/score/cpu/powerpc/rtems/powerpc/registers.h b/cpukit/score/cpu/powerpc/rtems/powerpc/registers.h
index 008e387..7090203 100644
--- a/cpukit/score/cpu/powerpc/rtems/powerpc/registers.h
+++ b/cpukit/score/cpu/powerpc/rtems/powerpc/registers.h
@@ -299,6 +299,11 @@ lidate */
 #define BOOKE_DECAR	54
+#define PPC405_MCSR     0x23C
+#define PPC405_ESR      0x3D4
+#define PPC405_DEAR     0x3D5
+#define BOOKE_DEAR      61
 #define PPC405_TSR	0x3D8
 #define BOOKE_TSR	336
 #define BOOKE_TSR_ENW		(1<<31)
1.7.1
