Source Code Beautifier for C
Gedare Bloom
gedare at rtems.org
Tue Dec 4 02:10:06 UTC 2012
Thanks I like the idea I'll have to check this tool out.
On Mon, Dec 3, 2012 at 3:37 PM, Sebastian Huber <
> Hello,
> I recently tested the Uncrustify source code beautifier. It looks pretty
> promising.
> http://uncrustify.sourceforge.**net/ <http://uncrustify.sourceforge.net/>
> If you try it out please use the latest Git master since it contains some
> bug fixes that are not in the latest release.
> Attached is a configuration that is close to the RTEMS coding style. I
> didn't use spaces after '(' and before ')'. The options
> # Add or remove space inside if-condition '(' and ')'
> sp_inside_sparen = force #
> ignore/add/remove/force
> # Add or remove space inside empty function '()'
> sp_inside_fparens = force #
> # Add or remove space inside function '(' and ')'
> sp_inside_fparen = force #
> would enable this.
> A good test to see how it works is this:
> uncrustify -c ~/git-rtems/contrib/**uncrustify/rtems.cfg -f
> cpukit/libfs/src/dosfs/msdos_**misc.c
> We can use this tool to format files before a big change. The procedure
> would be to format the source code, make sure that the generated binary
> code is the same and then commit this. Later we can do the actual
> functional changes.
> We can use also this configuration file as a formal source code format
> specification.
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20121203/0dfc7335/attachment.html>
