GCI Task review: breaking up long lines
Wed Dec 5 01:26:31 UTC 2012
Would an objdump and diff on the before and after .o be sufficient?
Chris Johns <chrisj at rtems.org> wrote:
>Gedare Bloom wrote:
>> Hello,
>> We're planning to have GCI students attempt to break up lines longer
>> than 80 characters. I have created a description of the task at [1],
>> please check that the directions are clear and that the way to handle
>> long lines is stated well.
>> If anyone has objections to this as a task please say so, or forever
>> hold your peace.
>> -Gedare
>> [1]
>> http://wiki.rtems.org/wiki/index.php/GoogleCodeInProjects#Break_Long_Lines
>How do we know the changes have _not_ altered the code ?
>Do we need to build apply patches and check the generated code is 100%
>the same ? This would make the amount of work to check the changes more
>than just doing the change. Diff'ing ELF files is complex.
>Chris
>_______________________________________________
>rtems-devel mailing list
>rtems-devel at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-devel
