Coding Style for RTEMS
Wed Dec 5 15:10:34 UTC 2012
Please also look at the document I posted. In intended it to eventually become part of the document set. It has details which I am pretty sure are not in the wiki including settings for various reformatting tools which have been suggested over the years.
Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>Ok, I will try to make the wiki page about the score coding style more verbose
>and add examples.
>http://www.rtems.org/wiki/index.php/Coding_Conventions
>I started this discussion since some file in RTEMS are really hard to read.  If
>you want to change something more complicated it is beneficial to increase the
>readability with a tool and then do the functional changes as a second step.
>For this you need a clear enough description of the target style.
>I do not intend to do format changes without good reason.  It is also madness
>to format source code of external projects e.g. the network stack.
>Sebastian Huber, embedded brains GmbH
>Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>Phone   : +49 89 18 90 80 79-6
>Fax     : +49 89 18 90 80 79-9
>E-Mail  : sebastian.huber at embedded-brains.de
>PGP     : Public key available on request.
>Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>_______________________________________________
>rtems-devel mailing list
>rtems-devel at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-devel
