[PATCH] libmd: Use alternative MD5 implementation
Sebastian Huber
Sun Dec 16 17:09:46 UTC 2012
This implementation has less license restrictions.
cpukit/libmd/md5.c | 552 +++++++++++++++++++++++++---------------------------
cpukit/libmd/md5.h | 101 +++++-----
2 files changed, 320 insertions(+), 333 deletions(-)
diff --git a/cpukit/libmd/md5.c b/cpukit/libmd/md5.c
index fa64a12..e6859e2 100644
--- a/cpukit/libmd/md5.c
+++ b/cpukit/libmd/md5.c
@@ -1,311 +1,295 @@
- ** md5.c -- the source code for MD5 routines **
- ** RSA Data Security, Inc. MD5 Message-Digest Algorithm **
- ** Created: 2/17/90 RLR **
- ** Revised: 1/91 SRD,AJ,BSK,JT Reference C ver., 7/10 constant corr. **
- ** Copyright (C) 1990, RSA Data Security, Inc. All rights reserved. **
- ** License to copy and use this software is granted provided that **
- ** it is identified as the "RSA Data Security, Inc. MD5 Message- **
- ** Digest Algorithm" in all material mentioning or referencing this **
- ** software or this function. **
- ** License is also granted to make and use derivative works **
- ** provided that such works are identified as "derived from the RSA **
- ** Data Security, Inc. MD5 Message-Digest Algorithm" in all **
- ** material mentioning or referencing the derived work. **
- ** RSA Data Security, Inc. makes no representations concerning **
- ** either the merchantability of this software or the suitability **
- ** of this software for any particular purpose. It is provided "as **
- ** is" without express or implied warranty of any kind. **
- ** These notices must be retained in any copies of any part of this **
- ** documentation and/or software. **
+ * This is an OpenSSL-compatible implementation of the RSA Data Security, Inc.
+ * MD5 Message-Digest Algorithm (RFC 1321).
+ * Homepage:
+ * http://openwall.info/wiki/people/solar/software/public-domain-source-code/md5
+ * Author:
+ * Alexander Peslyak, better known as Solar Designer <solar at openwall.com>
+ * This software was written by Alexander Peslyak in 2001. No copyright is
+ * claimed, and the software is hereby placed in the public domain.
+ * In case this attempt to disclaim copyright and place the software in the
+ * public domain is deemed null and void, then the software is
+ * Copyright (c) 2001 Alexander Peslyak and it is hereby released to the
+ * general public under the following terms:
+ * modification, are permitted.
+ * There's ABSOLUTELY NO WARRANTY, express or implied.
+ * (This is a heavily cut-down "BSD license".)
+ * This differs from Colin Plumb's older public domain implementation in that
+ * no exactly 32-bit integer data type is required (any 32-bit or wider
+ * unsigned integer data type will do), there's no compile-time endianness
+ * configuration, and the function prototypes match OpenSSL's. No code from
+ * Colin Plumb's implementation has been reused; this comment merely compares
+ * the properties of the two independent implementations.
+ * The primary goals of this implementation are portability and ease of use.
+ * It is meant to be fast, but not as fast as possible. Some known
+ * optimizations are not included to reduce source code size and avoid
+ * compile-time configuration.
#ifdef HAVE_CONFIG_H
-#include "config.h"
+ #include "config.h"
#endif
-#include <string.h> /* memcpy */
+#include <string.h>
#include "md5.h"
- ** Message-digest routines: **
- ** To form the message digest for a message M **
- ** (1) Initialize a context buffer mdContext using MD5Init **
- ** (2) Call MD5Update on mdContext and M **
- ** (3) Call MD5Final on mdContext **
- ** The message digest is now in mdContext->digest[0...15] **
+ * The basic MD5 functions.
+ * F and G are optimized compared to their RFC 1321 definitions for
+ * architectures that lack an AND-NOT instruction, just like in Colin Plumb's
+ * implementation.
+#define F(x, y, z) ((z) ^ ((x) & ((y) ^ (z))))
+#define G(x, y, z) ((y) ^ ((z) & ((x) ^ (y))))
+#define H(x, y, z) ((x) ^ (y) ^ (z))
+#define I(x, y, z) ((y) ^ ((x) | ~(z)))
+ * The MD5 transformation for all four rounds.
+#define STEP(f, a, b, c, d, x, t, s) \
+ (a) += f((b), (c), (d)) + (x) + (t); \
+ (a) = (((a) << (s)) | (((a) & 0xffffffff) >> (32 - (s)))); \
+ (a) += (b);
-/* forward declaration */
-static void Transform (UINT4 *buf, UINT4 *in);
-static unsigned char PADDING[64] = {
- 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
-/* F, G, H and I are basic MD5 functions */
-#define F(x, y, z) (((x) & (y)) | ((~x) & (z)))
-#define G(x, y, z) (((x) & (z)) | ((y) & (~z)))
-#define H(x, y, z) ((x) ^ (y) ^ (z))
-#define I(x, y, z) ((y) ^ ((x) | (~z)))
-/* ROTATE_LEFT rotates x left n bits */
-#define ROTATE_LEFT(x, n) (((x) << (n)) | ((x) >> (32-(n))))
-/* FF, GG, HH, and II transformations for rounds 1, 2, 3, and 4 */
-/* Rotation is separate from addition to prevent recomputation */
-#define FF(a, b, c, d, x, s, ac) \
- {(a) += F ((b), (c), (d)) + (x) + (UINT4)(ac); \
- (a) = ROTATE_LEFT ((a), (s)); \
- (a) += (b); \
-#define GG(a, b, c, d, x, s, ac) \
- {(a) += G ((b), (c), (d)) + (x) + (UINT4)(ac); \
- (a) += (b); \
-#define HH(a, b, c, d, x, s, ac) \
- {(a) += H ((b), (c), (d)) + (x) + (UINT4)(ac); \
- (a) += (b); \
-#define II(a, b, c, d, x, s, ac) \
- {(a) += I ((b), (c), (d)) + (x) + (UINT4)(ac); \
- (a) += (b); \
-#ifdef __STDC__
-#define UL(x) x##U
+ * SET reads 4 input bytes in little-endian byte order and stores them
+ * in a properly aligned word in host byte order.
+ * The check for little-endian architectures that tolerate unaligned
+ * memory accesses is just an optimization. Nothing will break if it
+ * doesn't work.
+#if defined(__i386__) || defined(__x86_64__) || defined(__vax__)
+#define SET(n) \
+ (*(MD5_u32plus *)&ptr[(n) * 4])
+#define GET(n) \
+ SET(n)
#else
-#define UL(x) x
+#define SET(n) \
+ (ctx->block[(n)] = \
+ (MD5_u32plus)ptr[(n) * 4] | \
+ ((MD5_u32plus)ptr[(n) * 4 + 1] << 8) | \
+ ((MD5_u32plus)ptr[(n) * 4 + 2] << 16) | \
+ ((MD5_u32plus)ptr[(n) * 4 + 3] << 24))
+#define GET(n) \
+ (ctx->block[(n)])
#endif
-/* The routine MD5Init initializes the message-digest context
- mdContext. All fields are set to zero.
+ * This processes one or more 64-byte data blocks, but does NOT update
+ * the bit counters. There are no alignment requirements.
-void MD5Init (
- MD5_CTX *mdContext )
+static const void *body(MD5_CTX *ctx, const void *data, size_t size)
- mdContext->i[0] = mdContext->i[1] = (UINT4)0;
- /* Load magic initialization constants.
- mdContext->buf[0] = (UINT4)0x67452301;
- mdContext->buf[1] = (UINT4)0xefcdab89;
- mdContext->buf[2] = (UINT4)0x98badcfe;
- mdContext->buf[3] = (UINT4)0x10325476;
+ const uint8_t *ptr;
+ MD5_u32plus a, b, c, d;
+ MD5_u32plus saved_a, saved_b, saved_c, saved_d;
+ ptr = data;
+ a = ctx->a;
+ b = ctx->b;
+ c = ctx->c;
+ d = ctx->d;
+ do {
+ saved_a = a;
+ saved_b = b;
+ saved_c = c;
+ saved_d = d;
+/* Round 1 */
+ STEP(F, a, b, c, d, SET(0), 0xd76aa478, 7)
+ STEP(F, d, a, b, c, SET(1), 0xe8c7b756, 12)
+ STEP(F, c, d, a, b, SET(2), 0x242070db, 17)
+ STEP(F, b, c, d, a, SET(3), 0xc1bdceee, 22)
+ STEP(F, a, b, c, d, SET(4), 0xf57c0faf, 7)
+ STEP(F, d, a, b, c, SET(5), 0x4787c62a, 12)
+ STEP(F, c, d, a, b, SET(6), 0xa8304613, 17)
+ STEP(F, b, c, d, a, SET(7), 0xfd469501, 22)
+ STEP(F, a, b, c, d, SET(8), 0x698098d8, 7)
+ STEP(F, d, a, b, c, SET(9), 0x8b44f7af, 12)
+ STEP(F, c, d, a, b, SET(10), 0xffff5bb1, 17)
+ STEP(F, b, c, d, a, SET(11), 0x895cd7be, 22)
+ STEP(F, a, b, c, d, SET(12), 0x6b901122, 7)
+ STEP(F, d, a, b, c, SET(13), 0xfd987193, 12)
+ STEP(F, c, d, a, b, SET(14), 0xa679438e, 17)
+ STEP(F, b, c, d, a, SET(15), 0x49b40821, 22)
+/* Round 2 */
+ STEP(G, a, b, c, d, GET(1), 0xf61e2562, 5)
+ STEP(G, d, a, b, c, GET(6), 0xc040b340, 9)
+ STEP(G, c, d, a, b, GET(11), 0x265e5a51, 14)
+ STEP(G, b, c, d, a, GET(0), 0xe9b6c7aa, 20)
+ STEP(G, a, b, c, d, GET(5), 0xd62f105d, 5)
+ STEP(G, d, a, b, c, GET(10), 0x02441453, 9)
+ STEP(G, c, d, a, b, GET(15), 0xd8a1e681, 14)
+ STEP(G, b, c, d, a, GET(4), 0xe7d3fbc8, 20)
+ STEP(G, a, b, c, d, GET(9), 0x21e1cde6, 5)
+ STEP(G, d, a, b, c, GET(14), 0xc33707d6, 9)
+ STEP(G, c, d, a, b, GET(3), 0xf4d50d87, 14)
+ STEP(G, b, c, d, a, GET(8), 0x455a14ed, 20)
+ STEP(G, a, b, c, d, GET(13), 0xa9e3e905, 5)
+ STEP(G, d, a, b, c, GET(2), 0xfcefa3f8, 9)
+ STEP(G, c, d, a, b, GET(7), 0x676f02d9, 14)
+ STEP(G, b, c, d, a, GET(12), 0x8d2a4c8a, 20)
+/* Round 3 */
+ STEP(H, a, b, c, d, GET(5), 0xfffa3942, 4)
+ STEP(H, d, a, b, c, GET(8), 0x8771f681, 11)
+ STEP(H, c, d, a, b, GET(11), 0x6d9d6122, 16)
+ STEP(H, b, c, d, a, GET(14), 0xfde5380c, 23)
+ STEP(H, a, b, c, d, GET(1), 0xa4beea44, 4)
+ STEP(H, d, a, b, c, GET(4), 0x4bdecfa9, 11)
+ STEP(H, c, d, a, b, GET(7), 0xf6bb4b60, 16)
+ STEP(H, b, c, d, a, GET(10), 0xbebfbc70, 23)
+ STEP(H, a, b, c, d, GET(13), 0x289b7ec6, 4)
+ STEP(H, d, a, b, c, GET(0), 0xeaa127fa, 11)
+ STEP(H, c, d, a, b, GET(3), 0xd4ef3085, 16)
+ STEP(H, b, c, d, a, GET(6), 0x04881d05, 23)
+ STEP(H, a, b, c, d, GET(9), 0xd9d4d039, 4)
+ STEP(H, d, a, b, c, GET(12), 0xe6db99e5, 11)
+ STEP(H, c, d, a, b, GET(15), 0x1fa27cf8, 16)
+ STEP(H, b, c, d, a, GET(2), 0xc4ac5665, 23)
+/* Round 4 */
+ STEP(I, a, b, c, d, GET(0), 0xf4292244, 6)
+ STEP(I, d, a, b, c, GET(7), 0x432aff97, 10)
+ STEP(I, c, d, a, b, GET(14), 0xab9423a7, 15)
+ STEP(I, b, c, d, a, GET(5), 0xfc93a039, 21)
+ STEP(I, a, b, c, d, GET(12), 0x655b59c3, 6)
+ STEP(I, d, a, b, c, GET(3), 0x8f0ccc92, 10)
+ STEP(I, c, d, a, b, GET(10), 0xffeff47d, 15)
+ STEP(I, b, c, d, a, GET(1), 0x85845dd1, 21)
+ STEP(I, a, b, c, d, GET(8), 0x6fa87e4f, 6)
+ STEP(I, d, a, b, c, GET(15), 0xfe2ce6e0, 10)
+ STEP(I, c, d, a, b, GET(6), 0xa3014314, 15)
+ STEP(I, b, c, d, a, GET(13), 0x4e0811a1, 21)
+ STEP(I, a, b, c, d, GET(4), 0xf7537e82, 6)
+ STEP(I, d, a, b, c, GET(11), 0xbd3af235, 10)
+ STEP(I, c, d, a, b, GET(2), 0x2ad7d2bb, 15)
+ STEP(I, b, c, d, a, GET(9), 0xeb86d391, 21)
+ a += saved_a;
+ b += saved_b;
+ c += saved_c;
+ d += saved_d;
+ ptr += 64;
+ } while (size -= 64);
+ ctx->a = a;
+ ctx->b = b;
+ ctx->c = c;
+ ctx->d = d;
+ return ptr;
-/* The routine MD5Update updates the message-digest context to
- account for the presence of each of the characters inBuf[0..inLen-1]
- in the message whose digest is being computed.
-void MD5Update (
- MD5_CTX *mdContext,
- const unsigned char *inBuf,
- unsigned int inLen )
+void MD5_Init(MD5_CTX *ctx)
- UINT4 in[16];
- int mdi;
- unsigned int i, ii;
- /* compute number of bytes mod 64 */
- mdi = (int)((mdContext->i[0] >> 3) & 0x3F);
- /* update number of bits */
- if ((mdContext->i[0] + ((UINT4)inLen << 3)) < mdContext->i[0])
- mdContext->i[1]++;
- mdContext->i[0] += ((UINT4)inLen << 3);
- mdContext->i[1] += ((UINT4)inLen >> 29);
- while (inLen--) {
- /* add new character to buffer, increment mdi */
- mdContext->in[mdi++] = *inBuf++;
- /* transform if necessary */
- if (mdi == 0x40) {
- for (i = 0, ii = 0; i < 16; i++, ii += 4)
- in[i] = (((UINT4)mdContext->in[ii+3]) << 24) |
- (((UINT4)mdContext->in[ii+2]) << 16) |
- (((UINT4)mdContext->in[ii+1]) << 8) |
- ((UINT4)mdContext->in[ii]);
- Transform (mdContext->buf, in);
- mdi = 0;
+ ctx->a = 0x67452301;
+ ctx->b = 0xefcdab89;
+ ctx->c = 0x98badcfe;
+ ctx->d = 0x10325476;
+ ctx->lo = 0;
+ ctx->hi = 0;
-/* The routine MD5Final terminates the message-digest computation and
- ends with the desired message digest in mdContext->digest[0...15].
-void MD5Final (
- unsigned char hash[],
+void MD5_Update(MD5_CTX *ctx, const void *data, size_t size)
- UINT4 in[16];
- int mdi;
- unsigned int padLen;
- /* save number of bits */
- in[14] = mdContext->i[0];
- in[15] = mdContext->i[1];
- /* pad out to 56 mod 64 */
- padLen = (mdi < 56) ? (56 - mdi) : (120 - mdi);
- MD5Update (mdContext, PADDING, padLen);
- /* append length in bits and transform */
- for (i = 0, ii = 0; i < 14; i++, ii += 4)
- /* store buffer in digest */
- for (i = 0, ii = 0; i < 4; i++, ii += 4) {
- mdContext->digest[ii] = (unsigned char)(mdContext->buf[i] & 0xFF);
- mdContext->digest[ii+1] =
- (unsigned char)((mdContext->buf[i] >> 8) & 0xFF);
- mdContext->digest[ii+2] =
- (unsigned char)((mdContext->buf[i] >> 16) & 0xFF);
- mdContext->digest[ii+3] =
- (unsigned char)((mdContext->buf[i] >> 24) & 0xFF);
- memcpy(hash, mdContext->digest, 16);
+ MD5_u32plus saved_lo;
+ size_t used, free;
+ saved_lo = ctx->lo;
+ if ((ctx->lo = (saved_lo + size) & 0x1fffffff) < saved_lo)
+ ctx->hi++;
+ ctx->hi += size >> 29;
+ used = saved_lo & 0x3f;
+ if (used) {
+ free = 64 - used;
+ if (size < free) {
+ memcpy(&ctx->buffer[used], data, size);
+ return;
+ memcpy(&ctx->buffer[used], data, free);
+ data = (uint8_t *)data + free;
+ size -= free;
+ body(ctx, ctx->buffer, 64);
+ if (size >= 64) {
+ data = body(ctx, data, size & ~(size_t)0x3f);
+ size &= 0x3f;
+ memcpy(ctx->buffer, data, size);
-/* Basic MD5 step. Transforms buf based on in.
- UINT4 *buf,
- UINT4 *in )
+void MD5_Final(uint8_t *result, MD5_CTX *ctx)
- UINT4 a = buf[0], b = buf[1], c = buf[2], d = buf[3];
- /* Round 1 */
-#define S11 7
-#define S12 12
-#define S13 17
-#define S14 22
- FF ( a, b, c, d, in[ 0], S11, UL(3614090360)); /* 1 */
- FF ( d, a, b, c, in[ 1], S12, UL(3905402710)); /* 2 */
- FF ( c, d, a, b, in[ 2], S13, UL( 606105819)); /* 3 */
- FF ( b, c, d, a, in[ 3], S14, UL(3250441966)); /* 4 */
- FF ( a, b, c, d, in[ 4], S11, UL(4118548399)); /* 5 */
- FF ( d, a, b, c, in[ 5], S12, UL(1200080426)); /* 6 */
- FF ( c, d, a, b, in[ 6], S13, UL(2821735955)); /* 7 */
- FF ( b, c, d, a, in[ 7], S14, UL(4249261313)); /* 8 */
- FF ( a, b, c, d, in[ 8], S11, UL(1770035416)); /* 9 */
- FF ( d, a, b, c, in[ 9], S12, UL(2336552879)); /* 10 */
- FF ( c, d, a, b, in[10], S13, UL(4294925233)); /* 11 */
- FF ( b, c, d, a, in[11], S14, UL(2304563134)); /* 12 */
- FF ( a, b, c, d, in[12], S11, UL(1804603682)); /* 13 */
- FF ( d, a, b, c, in[13], S12, UL(4254626195)); /* 14 */
- FF ( c, d, a, b, in[14], S13, UL(2792965006)); /* 15 */
- FF ( b, c, d, a, in[15], S14, UL(1236535329)); /* 16 */
- /* Round 2 */
-#define S21 5
-#define S22 9
-#define S23 14
-#define S24 20
- GG ( a, b, c, d, in[ 1], S21, UL(4129170786)); /* 17 */
- GG ( d, a, b, c, in[ 6], S22, UL(3225465664)); /* 18 */
- GG ( c, d, a, b, in[11], S23, UL( 643717713)); /* 19 */
- GG ( b, c, d, a, in[ 0], S24, UL(3921069994)); /* 20 */
- GG ( a, b, c, d, in[ 5], S21, UL(3593408605)); /* 21 */
- GG ( d, a, b, c, in[10], S22, UL( 38016083)); /* 22 */
- GG ( c, d, a, b, in[15], S23, UL(3634488961)); /* 23 */
- GG ( b, c, d, a, in[ 4], S24, UL(3889429448)); /* 24 */
- GG ( a, b, c, d, in[ 9], S21, UL( 568446438)); /* 25 */
- GG ( d, a, b, c, in[14], S22, UL(3275163606)); /* 26 */
- GG ( c, d, a, b, in[ 3], S23, UL(4107603335)); /* 27 */
- GG ( b, c, d, a, in[ 8], S24, UL(1163531501)); /* 28 */
- GG ( a, b, c, d, in[13], S21, UL(2850285829)); /* 29 */
- GG ( d, a, b, c, in[ 2], S22, UL(4243563512)); /* 30 */
- GG ( c, d, a, b, in[ 7], S23, UL(1735328473)); /* 31 */
- GG ( b, c, d, a, in[12], S24, UL(2368359562)); /* 32 */
- /* Round 3 */
-#define S31 4
-#define S32 11
-#define S33 16
-#define S34 23
- HH ( a, b, c, d, in[ 5], S31, UL(4294588738)); /* 33 */
- HH ( d, a, b, c, in[ 8], S32, UL(2272392833)); /* 34 */
- HH ( c, d, a, b, in[11], S33, UL(1839030562)); /* 35 */
- HH ( b, c, d, a, in[14], S34, UL(4259657740)); /* 36 */
- HH ( a, b, c, d, in[ 1], S31, UL(2763975236)); /* 37 */
- HH ( d, a, b, c, in[ 4], S32, UL(1272893353)); /* 38 */
- HH ( c, d, a, b, in[ 7], S33, UL(4139469664)); /* 39 */
- HH ( b, c, d, a, in[10], S34, UL(3200236656)); /* 40 */
- HH ( a, b, c, d, in[13], S31, UL( 681279174)); /* 41 */
- HH ( d, a, b, c, in[ 0], S32, UL(3936430074)); /* 42 */
- HH ( c, d, a, b, in[ 3], S33, UL(3572445317)); /* 43 */
- HH ( b, c, d, a, in[ 6], S34, UL( 76029189)); /* 44 */
- HH ( a, b, c, d, in[ 9], S31, UL(3654602809)); /* 45 */
- HH ( d, a, b, c, in[12], S32, UL(3873151461)); /* 46 */
- HH ( c, d, a, b, in[15], S33, UL( 530742520)); /* 47 */
- HH ( b, c, d, a, in[ 2], S34, UL(3299628645)); /* 48 */
- /* Round 4 */
-#define S41 6
-#define S42 10
-#define S43 15
-#define S44 21
- II ( a, b, c, d, in[ 0], S41, UL(4096336452)); /* 49 */
- II ( d, a, b, c, in[ 7], S42, UL(1126891415)); /* 50 */
- II ( c, d, a, b, in[14], S43, UL(2878612391)); /* 51 */
- II ( b, c, d, a, in[ 5], S44, UL(4237533241)); /* 52 */
- II ( a, b, c, d, in[12], S41, UL(1700485571)); /* 53 */
- II ( d, a, b, c, in[ 3], S42, UL(2399980690)); /* 54 */
- II ( c, d, a, b, in[10], S43, UL(4293915773)); /* 55 */
- II ( b, c, d, a, in[ 1], S44, UL(2240044497)); /* 56 */
- II ( a, b, c, d, in[ 8], S41, UL(1873313359)); /* 57 */
- II ( d, a, b, c, in[15], S42, UL(4264355552)); /* 58 */
- II ( c, d, a, b, in[ 6], S43, UL(2734768916)); /* 59 */
- II ( b, c, d, a, in[13], S44, UL(1309151649)); /* 60 */
- II ( a, b, c, d, in[ 4], S41, UL(4149444226)); /* 61 */
- II ( d, a, b, c, in[11], S42, UL(3174756917)); /* 62 */
- II ( c, d, a, b, in[ 2], S43, UL( 718787259)); /* 63 */
- II ( b, c, d, a, in[ 9], S44, UL(3951481745)); /* 64 */
- buf[0] += a;
- buf[1] += b;
- buf[2] += c;
- buf[3] += d;
+ used = ctx->lo & 0x3f;
+ ctx->buffer[used++] = 0x80;
+ free = 64 - used;
+ if (free < 8) {
+ memset(&ctx->buffer[used], 0, free);
+ used = 0;
+ free = 64;
+ memset(&ctx->buffer[used], 0, free - 8);
+ ctx->lo <<= 3;
+ ctx->buffer[56] = ctx->lo;
+ ctx->buffer[57] = ctx->lo >> 8;
+ ctx->buffer[58] = ctx->lo >> 16;
+ ctx->buffer[59] = ctx->lo >> 24;
+ ctx->buffer[60] = ctx->hi;
+ ctx->buffer[61] = ctx->hi >> 8;
+ ctx->buffer[62] = ctx->hi >> 16;
+ ctx->buffer[63] = ctx->hi >> 24;
+ result[0] = ctx->a;
+ result[1] = ctx->a >> 8;
+ result[2] = ctx->a >> 16;
+ result[3] = ctx->a >> 24;
+ result[4] = ctx->b;
+ result[5] = ctx->b >> 8;
+ result[6] = ctx->b >> 16;
+ result[7] = ctx->b >> 24;
+ result[8] = ctx->c;
+ result[9] = ctx->c >> 8;
+ result[10] = ctx->c >> 16;
+ result[11] = ctx->c >> 24;
+ result[12] = ctx->d;
+ result[13] = ctx->d >> 8;
+ result[14] = ctx->d >> 16;
+ result[15] = ctx->d >> 24;
+ memset(ctx, 0, sizeof(*ctx));
- ** End of md5.c **
- ******************************** (cut) ********************************
diff --git a/cpukit/libmd/md5.h b/cpukit/libmd/md5.h
index 543c539..0cb4950 100644
--- a/cpukit/libmd/md5.h
+++ b/cpukit/libmd/md5.h
@@ -1,68 +1,71 @@
- ** md5.h -- header file for implementation of MD5 **
- ** Revised: 12/27/90 SRD,AJ,BSK,JT Reference C version **
- ** Revised (for MD5): RLR 4/27/91 **
- ** -- G modified to have y&~z instead of y&z **
- ** -- FF, GG, HH modified to add in last register done **
- ** -- Access pattern: round 2 works mod 5, round 3 works mod 3 **
- ** -- distinct additive constant for each step **
- ** -- round 4 added, working mod 7 **
+ * Homepage:
+ * Author:
+ * See md5.c for more information.
-#ifndef __MD5_INCLUDE__
+#ifndef _MD5_H
+#define _MD5_H
+#include <sys/types.h>
#include <stdint.h>
#ifdef __cplusplus
extern "C" {
#endif /* __cplusplus */
-/* typedef a 32-bit type */
-typedef uint32_t UINT4;
+/* Any 32-bit or wider unsigned integer data type will do */
+typedef uint_fast32_t MD5_u32plus;
+#define MD5_DIGEST_LENGTH 16
-/* Data structure for MD5 (Message-Digest) computation */
typedef struct {
- UINT4 i[2]; /* number of _bits_ handled mod 2^64 */
- UINT4 buf[4]; /* scratch buffer */
- unsigned char in[64]; /* input buffer */
- unsigned char digest[16]; /* actual digest after MD5Final call */
+ MD5_u32plus lo, hi;
+ uint8_t buffer[64];
+ MD5_u32plus block[16];
} MD5_CTX;
-void MD5Init (MD5_CTX *);
-void MD5Update (MD5_CTX *, const unsigned char *, unsigned int);
-void MD5Final (unsigned char [16], MD5_CTX *);
+extern void MD5_Init(MD5_CTX *ctx);
+extern void MD5_Update(MD5_CTX *ctx, const void *data, size_t size);
+extern void MD5_Final(uint8_t *result, MD5_CTX *ctx);
+static inline void MD5Init(MD5_CTX *ctx)
+ MD5_Init(ctx);
+static inline void MD5Update(MD5_CTX *ctx, const void *data, size_t size)
+ MD5_Update(ctx, data, size);
+static inline void MD5Final(uint8_t *result, MD5_CTX *ctx)
+ MD5_Final(result, ctx);
#ifdef __cplusplus
-#define __MD5_INCLUDE__
-#endif /* __MD5_INCLUDE__ */
+#endif /* _MD5_H */
1.7.10.4
