git issues
Wed Dec 19 19:14:48 UTC 2012
On 12/19/2012 8:41 AM, Gedare Bloom wrote:
> This is an error with the auto-updater that is supposed to be pushing
> commits from git.rtems.org/rtems.git to github/rtems.git
> The problem has existed for awhile, I don't think we got the
> auto-updating to ever quite work right.
> -Gedare
FWIW I have seen some permissions problems on newly created directories in
the past on git.rtems.org. I will check the permissions when I get the
password
for the machine from Jeff.
> On Wed, Dec 19, 2012 at 8:17 AM, Ralf Corsepius
> <ralf.corsepius at rtems.org> wrote:
>> Hi,
>> Upon git committing to rtems, I am facing this error:
>> # git push oar oar-master:master
>> Counting objects: 5, done.
>> Delta compression using up to 2 threads.
>> Compressing objects: 100% (3/3), done.
>> Writing objects: 100% (3/3), 368 bytes, done.
>> Total 3 (delta 2), reused 0 (delta 0)
>> remote: 1: mail rtems-vc at rtems.org
>> remote: 2: update github
>> Auto packing the repository for optimum performance.
>> fatal: Unable to create '/data/git/rtems.git/packed-refs.lock': Permission
>> denied
>> error: failed to run pack-refs
>> To ssh://ralf@git.rtems.org/data/git/rtems.git
>>     11109ea..b1efb2f  oar-master -> master
>> WTH is going on?
>> Ralf
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
