[1/1] cpukit/libblock Doxygen Enhancement Task #1
Fri Dec 21 17:51:41 UTC 2012
On 21/12/12 15:30, Joel Sherrill wrote:
> Just to make sure... is this desire documented in:
> http://www.rtems.org/wiki/index.php/GoogleCodeInProjects#Cleanup_Doxygen
> Even if it has to be repeated from an earlier task description?
Yes, Gedare updated this page accordingly:
Use sentences for function @brief
Convert function @brief from "Table of Contents" to "Topic sentence"
style. The descriptive text of a function's @brief is used to start a
paragraph, so it should be a simple, concise sentence describing the
function that begins with an active, present tense verb. See
Doxygen_Recommendations#Declaring_functions
<http://www.rtems.org/wiki/index.php/Doxygen_Recommendations#Declaring_functions>
for an example. When the description begins with a noun, rewrite the
description so that the action of the function comes first. Eliminate
any redundant wording such as "Function that does..." or "This
function...".
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
