[PATCH 1/2] score: Do not inline _RBTree_Find_unprotected()
Sat Dec 22 17:00:58 UTC 2012
This function is too big to inline.  It leads also to test case
explosion.
 cpukit/score/include/rtems/score/rbtree.h  |   14 ++++++++++++
 cpukit/score/inline/rtems/score/rbtree.inl |   33 ----------------------------
 cpukit/score/src/rbtreefind.c              |   24 ++++++++++++++++++++
 3 files changed, 38 insertions(+), 33 deletions(-)
diff --git a/cpukit/score/include/rtems/score/rbtree.h b/cpukit/score/include/rtems/score/rbtree.h
index 5a03d7c..dedc182 100644
--- a/cpukit/score/include/rtems/score/rbtree.h
+++ b/cpukit/score/include/rtems/score/rbtree.h
@@ -222,6 +222,20 @@ RBTree_Node *_RBTree_Get(
   RBTree_Direction dir
+/** @brief Find the node with given key in the tree
+ *  This function returns a pointer to the node in @a the_rbtree
+ *  having key equal to key of  @a the_node if it exists,
+ *  and NULL if not. @a the_node has to be made up before a search.
+ *  @note If the tree is not unique and contains duplicate keys, the set
+ *        of duplicate keys acts as FIFO.
+RBTree_Node *_RBTree_Find_unprotected(
+  RBTree_Control *the_rbtree,
+  RBTree_Node *the_node
diff --git a/cpukit/score/inline/rtems/score/rbtree.inl b/cpukit/score/inline/rtems/score/rbtree.inl
index 439b40a..e25e3df 100644
--- a/cpukit/score/inline/rtems/score/rbtree.inl
+++ b/cpukit/score/inline/rtems/score/rbtree.inl
@@ -341,39 +341,6 @@ RTEMS_INLINE_ROUTINE bool _RBTree_Is_lesser(
   return compare_result < 0;
-/** @brief Find the node with given key in the tree
- *  This function returns a pointer to the node in @a the_rbtree
- *  having key equal to key of  @a the_node if it exists,
- *  and NULL if not. @a the_node has to be made up before a search.
- *  @note If the tree is not unique and contains duplicate keys, the set
- *        of duplicate keys acts as FIFO.
-RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Find_unprotected(
-    RBTree_Control *the_rbtree,
-    RBTree_Node *the_node
-  RBTree_Node* iter_node = the_rbtree->root;
-  RBTree_Node* found = NULL;
-  int compare_result;
-  while (iter_node) {
-    compare_result = the_rbtree->compare_function(the_node, iter_node);
-    if ( _RBTree_Is_equal( compare_result ) ) {
-      found = iter_node;
-      if ( the_rbtree->is_unique )
-        break;
-    RBTree_Direction dir =
-      (RBTree_Direction) _RBTree_Is_greater( compare_result );
-    iter_node = iter_node->child[dir];
-  } /* while(iter_node) */
-  return found;
  * @brief Returns the predecessor of a node.
diff --git a/cpukit/score/src/rbtreefind.c b/cpukit/score/src/rbtreefind.c
index 2e8cdc3..3f205ab 100644
--- a/cpukit/score/src/rbtreefind.c
+++ b/cpukit/score/src/rbtreefind.c
@@ -36,3 +36,27 @@ RBTree_Node *_RBTree_Find(
   _ISR_Enable( level );
   return return_node;
+  RBTree_Node* iter_node = the_rbtree->root;
+  RBTree_Node* found = NULL;
+  int compare_result;
+  while (iter_node) {
+    compare_result = the_rbtree->compare_function(the_node, iter_node);
+    if ( _RBTree_Is_equal( compare_result ) ) {
+      found = iter_node;
+      if ( the_rbtree->is_unique )
+        break;
+    RBTree_Direction dir =
+      (RBTree_Direction) _RBTree_Is_greater( compare_result );
+    iter_node = iter_node->child[dir];
+  } /* while(iter_node) */
+  return found;
1.7.10.4
