[PATCH 2/5] score: Add API extensions post switch list
Mon Dec 3 11:54:08 UTC 2012
Move post switch hook from API_extensions_Control to new
API_extensions_Post_switch_control.  Rename
_API_extensions_Run_postswitch() in _API_extensions_Run_post_switch().
Add _API_extensions_Post_switch_list and
_API_extensions_Add_post_switch().
 cpukit/posix/src/pthread.c                |   11 +++--
 cpukit/rtems/src/tasks.c                  |   11 +++--
 cpukit/score/include/rtems/score/apiext.h |   62 ++++++++++++++++++++++-------
 cpukit/score/src/apiext.c                 |    1 +
 cpukit/score/src/threaddispatch.c         |    4 +-
 5 files changed, 64 insertions(+), 25 deletions(-)
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index cd2cffe..e6f9289 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -305,12 +305,14 @@ static void _POSIX_Threads_Initialize_user_threads( void )
  *  API Extension control structures
 API_extensions_Control _POSIX_Threads_API_extensions = {
-  { NULL, NULL },
   #if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API)
-    NULL,                                   /* predriver */
+    .predriver_hook = NULL,
   #endif
-  _POSIX_Threads_Initialize_user_threads,   /* postdriver */
-  _POSIX_signals_Post_switch_extension,     /* post switch */
+  .postdriver_hook = _POSIX_Threads_Initialize_user_threads
+API_extensions_Post_switch_control _POSIX_Threads_API_extensions_post_switch = {
+  .hook = _POSIX_signals_Post_switch_extension
 User_extensions_Control _POSIX_Threads_User_extensions = {
@@ -357,6 +359,7 @@ void _POSIX_Threads_Manager_initialization(void)
   _User_extensions_Add_API_set( &_POSIX_Threads_User_extensions );
   _API_extensions_Add( &_POSIX_Threads_API_extensions );
+  _API_extensions_Add_post_switch( &_POSIX_Threads_API_extensions_post_switch );
    *  If we supported MP, then here we would ...
diff --git a/cpukit/rtems/src/tasks.c b/cpukit/rtems/src/tasks.c
index 4164afe..36142d5 100644
--- a/cpukit/rtems/src/tasks.c
+++ b/cpukit/rtems/src/tasks.c
@@ -208,12 +208,14 @@ static void _RTEMS_tasks_Post_switch_extension(
 API_extensions_Control _RTEMS_tasks_API_extensions = {
-  { NULL, NULL },
   #endif
-  _RTEMS_tasks_Initialize_user_tasks,       /* postdriver */
-  _RTEMS_tasks_Post_switch_extension        /* post switch */
+  .postdriver_hook = _RTEMS_tasks_Initialize_user_tasks
+API_extensions_Post_switch_control _RTEMS_tasks_API_extensions_post_switch = {
+  .hook = _RTEMS_tasks_Post_switch_extension
 User_extensions_Control _RTEMS_tasks_User_extensions = {
@@ -265,6 +267,7 @@ void _RTEMS_tasks_Manager_initialization(void)
   _User_extensions_Add_API_set( &_RTEMS_tasks_User_extensions );
   _API_extensions_Add( &_RTEMS_tasks_API_extensions );
+  _API_extensions_Add_post_switch( &_RTEMS_tasks_API_extensions_post_switch );
    *  Register the MP Process Packet routine.
diff --git a/cpukit/score/include/rtems/score/apiext.h b/cpukit/score/include/rtems/score/apiext.h
index afd828c..a44eacf 100644
--- a/cpukit/score/include/rtems/score/apiext.h
+++ b/cpukit/score/include/rtems/score/apiext.h
@@ -46,9 +46,9 @@
 typedef void (*API_extensions_Postdriver_hook)(void);
- *  This type defines the prototype of the Postswitch Hook.
+ *  This type defines the prototype of the Post Switch Hook.
-typedef void (*API_extensions_Postswitch_hook)(
+typedef void (*API_extensions_Post_switch_hook)(
                  Thread_Control *
@@ -77,20 +77,34 @@ typedef struct {
    * @note If this field is NULL, no extension is invoked.
   API_extensions_Postdriver_hook  postdriver_hook;
+}  API_extensions_Control;
+ * @brief Control structure for post switch hooks.
+typedef struct {
+  Chain_Node Node;
-   * This field is the callout invoked during each context switch
-   * in the context of the heir thread.
+   * @brief The hook invoked during each context switch in the context of the
+   * heir thread.
-   * @note If this field is NULL, no extension is invoked.
+   * This hook must not be NULL.
-  API_extensions_Postswitch_hook  postswitch_hook;
-}  API_extensions_Control;
+  API_extensions_Post_switch_hook hook;
+} API_extensions_Post_switch_control;
  *  This is the list of API extensions to the system initialization.
 SCORE_EXTERN Chain_Control _API_extensions_List;
+ * @brief The API extensions post switch list.
+SCORE_EXTERN Chain_Control _API_extensions_Post_switch_list;
  * @brief Initialize the API Extensions Handler
@@ -109,6 +123,26 @@ void _API_extensions_Add(
   API_extensions_Control *the_extension
+ * @brief Adds the API extension post switch control to the post switch list.
+ * The post switch control is only added to the list if it is in the off chain
+ * state.  Thus this function can be called multiple times with the same
+ * post switch control and only the first invocation will actually add it to the
+ * list.
+ * @param [in] post_switch The post switch control.
+static inline void _API_extensions_Add_post_switch(
+  API_extensions_Post_switch_control *post_switch
+  _Chain_Append_if_node_is_off_chain(
+    &_API_extensions_Post_switch_list,
+    &post_switch->Node
    * @brief Execute all Pre-Driver Extensions
@@ -126,21 +160,19 @@ void _API_extensions_Add(
 void _API_extensions_Run_postdriver( void );
- * @brief Execute all Post Context Switch Extensions
- *  This routine executes all of the post context switch callouts.
+ * @brief Runs all API extension post switch hooks.
-static inline void _API_extensions_Run_postswitch( Thread_Control *executing )
+static inline void _API_extensions_Run_post_switch( Thread_Control *executing )
-  const Chain_Control *chain = &_API_extensions_List;
+  const Chain_Control *chain = &_API_extensions_Post_switch_list;
   const Chain_Node    *tail = _Chain_Immutable_tail( chain );
   const Chain_Node    *node = _Chain_Immutable_first( chain );
   while ( node != tail ) {
-    const API_extensions_Control *extension =
-      (const API_extensions_Control *) node;
+    const API_extensions_Post_switch_control *post_switch =
+      (const API_extensions_Post_switch_control *) node;
-    (*extension->postswitch_hook)( executing );
+    (*post_switch->hook)( executing );
     node = _Chain_Immutable_next( node );
diff --git a/cpukit/score/src/apiext.c b/cpukit/score/src/apiext.c
index b2ca87c..99965da 100644
--- a/cpukit/score/src/apiext.c
+++ b/cpukit/score/src/apiext.c
@@ -24,6 +24,7 @@
 void _API_extensions_Initialization( void )
  _Chain_Initialize_empty( &_API_extensions_List );
+ _Chain_Initialize_empty( &_API_extensions_Post_switch_list );
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index 283d278..66c7bdc 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -69,7 +69,7 @@ void _Thread_Dispatch( void )
      *   _Thread_Unnest_dispatch();
-     *   _API_extensions_Run_postswitch();
+     *   _API_extensions_Run_post_switch();
      * The interrupt event makes task H ready.  The interrupt code will see
@@ -202,5 +202,5 @@ post_switch:
   #endif
-  _API_extensions_Run_postswitch( executing );
+  _API_extensions_Run_post_switch( executing );
1.7.7
