[PATCH] rtems misc: Clean up Doxygen GCI Task #6
Wed Dec 5 15:52:36 UTC 2012
Author:    Alex Ivanov <alexivanov97 at gmail.com>
http://www.google-melange.com/gci/task/view/google/gci2012/8019205
On Wed, Dec 5, 2012 at 10:52 AM, Gedare Bloom <gedare at rtems.org> wrote:
> diff --git a/cpukit/rtems/include/rtems/rtems/barrier.h
> b/cpukit/rtems/include/rtems/rtems/barrier.h
> index df0e6f2..4884d2c 100644
> --- a/cpukit/rtems/include/rtems/rtems/barrier.h
> +++ b/cpukit/rtems/include/rtems/rtems/barrier.h
> @@ -125,10 +125,12 @@ rtems_status_code rtems_barrier_ident(
> - *  @brief rtems_barrier_delete
> + *  @brief RTEMS Delete Barrier
>   *  This routine implements the rtems_barrier_delete directive.  The
> - *  barrier indicated by @a id is deleted.
> + *  barrier indicated by @a id is deleted.  The barrier is freed back to
> the
> + *  inactive barrier chain.
>   *  @param[in] id indicates the barrier to delete
> diff --git a/cpukit/rtems/include/rtems/rtems/dpmem.h
> b/cpukit/rtems/include/rtems/rtems/dpmem.h
> index a4cf251..e305b31 100644
> --- a/cpukit/rtems/include/rtems/rtems/dpmem.h
> +++ b/cpukit/rtems/include/rtems/rtems/dpmem.h
> @@ -84,13 +84,24 @@ RTEMS_DPMEM_EXTERN Objects_Information
> _Dual_ported_memory_Information;
>  void _Dual_ported_memory_Manager_initialization(void);
> - *  @brief rtems_port_create
> + *  @brief RTEMS Create Port
>   *  This routine implements the rtems_port_create directive.  The port
>   *  will have the name name.  The port maps onto an area of dual ported
>   *  memory of length bytes which has internal_start and external_start
>   *  as the internal and external starting addresses, respectively.
>   *  It returns the id of the created port in ID.
> + *  @param[in] name is the user defined port name
> + *  @param[in] internal_start is the internal start address of port
> + *  @param[in] external_start is the external start address of port
> + *  @param[in] length is the physical length in bytes
> + *  @param[in] id is the address of port id to set
> + *  @return This method returns RTEMS_SUCCESSFUL if there was not an
> + *          error.  Otherwise, a status code is returned indicating the
> + *          source of the error.  If successful, the id will
> + *          be filled in with the port id.
>  rtems_status_code rtems_port_create(
>    rtems_name    name,
> @@ -118,10 +129,16 @@ rtems_status_code rtems_port_ident(
> - *  @brief rtems_port_delete
> + *  @brief RTEMS Delete Port
>   *  This routine implements the rtems_port_delete directive.  It deletes
>   *  the port associated with ID.
> + *  @param[in] id is the dual-ported memory area id
>  rtems_status_code rtems_port_delete(
>    rtems_id   id
> diff --git a/cpukit/rtems/include/rtems/rtems/modes.h
> b/cpukit/rtems/include/rtems/rtems/modes.h
> index 0dbf91b..f80cb44 100644
> --- a/cpukit/rtems/include/rtems/rtems/modes.h
> +++ b/cpukit/rtems/include/rtems/rtems/modes.h
> @@ -102,7 +102,7 @@ typedef uint32_t   Modes_Control;
>  extern const uint32_t rtems_interrupt_mask;
> - *  @brief Body for RTEMS_INTERRUPT_LEVEL macro.
> + *  @brief Body for RTEMS_INTERRUPT_LEVEL Macro
>   *  @param[in] level is the desired interrupt level
> diff --git a/cpukit/rtems/include/rtems/rtems/part.h
> b/cpukit/rtems/include/rtems/rtems/part.h
> index b6b5b3a..d46be0a 100644
> --- a/cpukit/rtems/include/rtems/rtems/part.h
> +++ b/cpukit/rtems/include/rtems/rtems/part.h
> @@ -84,7 +84,7 @@ typedef struct {
>  RTEMS_PART_EXTERN Objects_Information _Partition_Information;
> - *  @brief Partition_Manager_initialization
> + *  @brief Partition Manager Initialization
>   *  This routine performs the initialization necessary for this manager.
> diff --git a/cpukit/rtems/include/rtems/rtems/region.h
> b/cpukit/rtems/include/rtems/rtems/region.h
> index 055e25d..f58bdff 100644
> --- a/cpukit/rtems/include/rtems/rtems/region.h
> +++ b/cpukit/rtems/include/rtems/rtems/region.h
> @@ -109,12 +109,20 @@ rtems_status_code rtems_region_create(
> - *  @brief rtems_region_extend
> + *  @brief RTEMS Extend Region
>   *  This routine implements the rtems_region_extend directive.  The
>   *  region will have the name name.  The memory area managed by
>   *  the region will be attempted to be grown by length bytes using
>   *  the memory starting at starting_address.
> + *  @param[in] id is the id of region to grow
> + *  @param[in] starting_address starting address of memory area for
> extension
> + *  @param[in] length is the physical length in bytes to grow the region
>  rtems_status_code rtems_region_extend(
>    rtems_id            id,
> @@ -123,12 +131,20 @@ rtems_status_code rtems_region_extend(
> - *  @brief rtems_region_ident
> + *  @brief RTEMS Region Name to Id
>   *  This routine implements the rtems_region_ident directive.
>   *  This directive returns the region ID associated with name.
>   *  If more than one region is named name, then the region
>   *  to which the ID belongs is arbitrary.
> + *  @param[in] name is the user defined region name
> + *  @param[in] id is the pointer to region id
> + *          be filled in with the region id.
>  rtems_status_code rtems_region_ident(
>    rtems_name    name,
> @@ -166,10 +182,17 @@ rtems_status_code rtems_region_get_free_information(
> - *  @brief rtems_region_delete
> + *  @brief RTEMS Delete Region
>   *  This routine implements the rtems_region_delete directive.  The
> - *  region indicated by ID is deleted.
> + *  region indicated by ID is deleted, provided that none of its segments
> are
> + *  still allocated.
> + *  @param[in] id is the region id
>  rtems_status_code rtems_region_delete(
>    rtems_id   id
> @@ -206,10 +229,19 @@ rtems_status_code rtems_region_get_segment(
> - *  @brief rtems_region_get_segment_size
> + *  @brief RTEMS Get Region Segment Size
>   *  This routine implements the rtems_region_get_segment_size directive.
> It
>   *  returns the size in bytes of the specified user memory area.
> + *  @param[in] segment is the segment address
> + *  @param[in] size is the pointer to segment size in bytes
> + *          source of the error.  If successful, the size will
> + *          be filled in with the segment size in bytes.
>  rtems_status_code rtems_region_get_segment_size(
>    rtems_id           id,
> diff --git a/cpukit/rtems/include/rtems/rtems/sem.h
> b/cpukit/rtems/include/rtems/rtems/sem.h
> index 2322088..aedc5ea 100644
> --- a/cpukit/rtems/include/rtems/rtems/sem.h
> +++ b/cpukit/rtems/include/rtems/rtems/sem.h
> @@ -229,20 +229,28 @@ bool _Semaphore_Seize(
> - *  @brief _Semaphore_Translate_core_mutex_return_code
> + *  @brief Semaphore Translate Core Mutex Return Code
>   *  This function returns a RTEMS status code based on the mutex
>   *  status code specified.
> + *  @param[in] the_mutex_status is the mutex status code to translate
> + *  @return translated RTEMS status code
>  rtems_status_code _Semaphore_Translate_core_mutex_return_code (
>    uint32_t   the_mutex_status
> - *  @brief _Semaphore_Translate_core_semaphore_return_code
> + *  @brief Semaphore Translate Core Semaphore Return Code
>   *  This function returns a RTEMS status code based on the semaphore
> + *  @param[in] status is the semaphore status code to translate
>  rtems_status_code _Semaphore_Translate_core_semaphore_return_code (
> diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h
> b/cpukit/rtems/include/rtems/rtems/tasks.h
> index 90379c1..abd7d1f 100644
> --- a/cpukit/rtems/include/rtems/rtems/tasks.h
> +++ b/cpukit/rtems/include/rtems/rtems/tasks.h
> @@ -278,7 +278,7 @@ rtems_status_code rtems_task_create(
> - *  @brief rtems_task_ident
> + *  @brief RTEMS Task Name to Id
>   *  This routine implements the rtems_task_ident directive.
>   *  This directive returns the task ID associated with name.
> @@ -287,6 +287,15 @@ rtems_status_code rtems_task_create(
>   *  extent of the search for the ID of the task named name.
>   *  The search can be limited to a particular node or allowed to
>   *  encompass all nodes.
> + *  @param[in] name is the user defined thread name
> + *  @param[in] node is(are) the node(s) to be searched
> + *  @param[in] id is the pointer to thread id
> + *          be filled in with the thread id.
>  rtems_status_code rtems_task_ident(
>    rtems_name    name,
> @@ -295,10 +304,18 @@ rtems_status_code rtems_task_ident(
> - *  @brief rtems_task_delete
> + *  @brief RTEMS Delete Task
>   *  This routine implements the rtems_task_delete directive.  The
> - *  task indicated by ID is deleted.
> + *  task indicated by ID is deleted. The executive halts execution
> + *  of the thread and frees the thread control block.
> + *  @param[in] id is the thread id
> + *          error and id is not the requesting thread.  Status code is
> + *          returned indicating the source of the error.  Nothing
> + *          is returned if id is the requesting thread (always succeeds).
>  rtems_status_code rtems_task_delete(
>    rtems_id   id
> @@ -376,10 +393,17 @@ rtems_status_code rtems_task_restart(
> - *  @brief rtems_task_suspend
> + *  @brief RTEMS Suspend Task
>   *  This routine implements the rtems_task_suspend directive.  The
> - *  SUSPENDED state is set for task associated with ID.
> + *  SUSPENDED state is set for task associated with ID. Note that the
> + *  suspended state can be in addition to other waiting states.
>  rtems_status_code rtems_task_suspend(
>    rtems_id   id
> @@ -522,14 +546,10 @@ rtems_id rtems_task_self(void);
>  void _RTEMS_tasks_Initialize_user_tasks( void );
> - *  @brief _RTEMS_Tasks_Invoke_task_variable_dtor
> + *  @brief RTEMS Tasks Invoke Task Variable Destructor
>   *  This routine invokes the optional user provided destructor on the
>   *  task variable and frees the memory for the task variable.
> - *  Input parameters: NONE
> - *  Output parameters:  NONE
>  void _RTEMS_Tasks_Invoke_task_variable_dtor(
>    Thread_Control        *the_thread,
> diff --git a/cpukit/rtems/include/rtems/rtems/timer.h
> b/cpukit/rtems/include/rtems/rtems/timer.h
> index ee35fec..b7ab2e2 100644
> --- a/cpukit/rtems/include/rtems/rtems/timer.h
> +++ b/cpukit/rtems/include/rtems/rtems/timer.h
> @@ -222,7 +222,7 @@ RTEMS_TIMER_EXTERN Timer_server_Control *volatile
> _Timer_server;
>  RTEMS_TIMER_EXTERN Objects_Information  _Timer_Information;
> - *  @brief _Timer_Manager_initialization
> + *  @brief Timer Manager Initialization
> @@ -301,13 +301,22 @@ rtems_status_code rtems_timer_fire_after(
> - *  @brief rtems_timer_server_fire_after
> + *  @brief RTEMS Timer Server Fire After
>   *  This routine implements the rtems_timer_server_fire_after directive.
> It
>   *  initiates the timer associated with ID to fire in ticks clock
>   *  ticks.  When the timer fires, the routine will be invoked by the
>   *  Timer Server in the context of a task NOT IN THE CONTEXT of the
>   *  clock tick interrupt.
> + *  @param[in] id is the timer id
> + *  @param[in] ticks is the interval until routine is fired
> + *  @param[in] routine is the routine to schedule
> + *  @param[in] user_data is the passed as argument to routine when it is
> fired
>  rtems_status_code rtems_timer_server_fire_after(
>    rtems_id                           id,
> @@ -317,13 +326,22 @@ rtems_status_code rtems_timer_server_fire_after(
> - *  @brief rtems_timer_fire_when
> + *  @brief RTEMS Timer Fire When
>   *  This routine implements the rtems_timer_fire_when directive.  It
>   *  initiates the timer associated with ID to fire at wall_time
>   *  When the timer fires, the routine will be invoked in the context
>   *  of the rtems_clock_tick directive which is normally invoked as
>   *  part of servicing a periodic interupt.
> + *  @param[in] wall_time is the time of day to fire timer
> fired
>  rtems_status_code rtems_timer_fire_when(
>    rtems_id                            id,
> diff --git a/cpukit/rtems/src/barrierdelete.c
> b/cpukit/rtems/src/barrierdelete.c
> index 9811773..a73846d 100644
> --- a/cpukit/rtems/src/barrierdelete.c
> +++ b/cpukit/rtems/src/barrierdelete.c
> @@ -1,6 +1,11 @@
> - *  Barrier Manager -- Delete a Barrier
> + *  @file
> + *  @ingroup ClassicBarrier
>   *  COPYRIGHT (c) 1989-2007.
>   *  On-Line Applications Research Corporation (OAR).
> @@ -21,21 +26,6 @@
>  #include <rtems/score/thread.h>
>  #include <rtems/score/threadq.h>
> - *  rtems_barrier_delete
> - *  This directive allows a thread to delete a barrier specified by
> - *  the barrier id.  The barrier is freed back to the inactive
> - *  barrier chain.
> - *    id - barrier id
> - *    RTEMS_SUCCESSFUL - if successful
> - *    error code       - if unsuccessful
>  rtems_status_code rtems_barrier_delete(
>    rtems_id   id
> diff --git a/cpukit/rtems/src/dpmemcreate.c
> b/cpukit/rtems/src/dpmemcreate.c
> index 7ac6ae9..6987670 100644
> --- a/cpukit/rtems/src/dpmemcreate.c
> +++ b/cpukit/rtems/src/dpmemcreate.c
> @@ -1,6 +1,11 @@
> - *  Dual Port Memory Manager
> + *  @file
> + *  @ingroup ClassicDPMEM
>   *  COPYRIGHT (c) 1989-1999.
> @@ -22,24 +27,6 @@
>  #include <rtems/rtems/dpmem.h>
> - *  rtems_port_create
> - *  This directive creates a port into a dual-ported memory area.
> - *    name           - user defined port name
> - *    internal_start - internal start address of port
> - *    external_start - external start address of port
> - *    length         - physical length in bytes
> - *    id             - address of port id to set
> - *    id       - port id
>    rtems_name    name,
>    void         *internal_start,
> diff --git a/cpukit/rtems/src/dpmemdelete.c
> b/cpukit/rtems/src/dpmemdelete.c
> index 02c3fbb..4f78035 100644
> --- a/cpukit/rtems/src/dpmemdelete.c
> +++ b/cpukit/rtems/src/dpmemdelete.c
> @@ -1,6 +1,11 @@
> + *  @file
> @@ -22,20 +27,6 @@
> - *  rtems_port_delete
> - *  This directive allows a thread to delete a dual-ported memory area
> - *  specified by the dual-ported memory identifier.
> - *    id - dual-ported memory area id
>    rtems_id id
> diff --git a/cpukit/rtems/src/modes.c b/cpukit/rtems/src/modes.c
> index 0c51281..6e4acff 100644
> --- a/cpukit/rtems/src/modes.c
> +++ b/cpukit/rtems/src/modes.c
> @@ -1,12 +1,11 @@
>   *  @file
> - *  @body Body for Mode Routines Implemented as Macros
> - *  This file contains bodies for Mode Macros which are
> - *  needed by language bindings other than C and C++.
> + *  @ingroup ClassicModes
>   *  COPYRIGHT (c) 1989-2012.
> diff --git a/cpukit/rtems/src/part.c b/cpukit/rtems/src/part.c
> index 65e5331..042cdaf 100644
> --- a/cpukit/rtems/src/part.c
> +++ b/cpukit/rtems/src/part.c
> @@ -1,6 +1,11 @@
> - *  Partition Manager
> + *  @file
> + *  @ingroup ClassicPart
>   *  COPYRIGHT (c) 1989-2008.
> @@ -23,17 +28,6 @@
>  #include <rtems/score/sysstate.h>
> - *  _Partition_Manager_initialization
> - *  This routine initializes all partition manager related
> - *  data structures.
>  void _Partition_Manager_initialization(void)
>    _Objects_Initialize_information(
> diff --git a/cpukit/rtems/src/regiondelete.c
> b/cpukit/rtems/src/regiondelete.c
> index d691bed..8ad5085 100644
> --- a/cpukit/rtems/src/regiondelete.c
> +++ b/cpukit/rtems/src/regiondelete.c
> @@ -1,7 +1,11 @@
> - *  Region Manager
> + *  @file
> + *  @ingroup ClassicRegion
> @@ -24,21 +28,6 @@
>  #include <rtems/score/apimutex.h>
> - *  rtems_region_delete
> - *  This directive allows a thread to delete a region specified by
> - *  the region identifier, provided that none of its segments are
> - *  still allocated.
> - *    id - region id
>    rtems_id id
> diff --git a/cpukit/rtems/src/regionextend.c
> b/cpukit/rtems/src/regionextend.c
> index 205534b..d5e3cd6 100644
> --- a/cpukit/rtems/src/regionextend.c
> +++ b/cpukit/rtems/src/regionextend.c
> @@ -1,6 +1,11 @@
> - *  Region Manager - Extend (add memory to) a Region
> + *  @file
>   *  COPYRIGHT (c) 1989-2009.
> @@ -23,22 +28,6 @@
> - *  rtems_region_extend
> - *  This directive attempts to grow a region of physical contiguous
> memory area
> - *  from which variable sized segments can be allocated.
> - *    id         - id of region to grow
> - *    start      - starting address of memory area for extension
> - *    length     - physical length in bytes to grow the region
>    rtems_id   id,
>    void      *starting_address,
> diff --git a/cpukit/rtems/src/regiongetsegmentsize.c
> b/cpukit/rtems/src/regiongetsegmentsize.c
> index 8333d16..94a6686 100644
> --- a/cpukit/rtems/src/regiongetsegmentsize.c
> +++ b/cpukit/rtems/src/regiongetsegmentsize.c
> @@ -1,7 +1,11 @@
> - *  Region Manager
> + *  @file
> @@ -23,22 +27,6 @@
>  #include <rtems/score/states.h>
> - *  rtems_region_get_segment_size
> - *  This directive will return the size of the segment indicated
> - *    id         - region id
> - *    segment    - segment address
> - *    size       - pointer to segment size in bytes
> - *    size       - segment size in bytes filled in
>    rtems_id   id,
>    void      *segment,
> diff --git a/cpukit/rtems/src/regionident.c
> b/cpukit/rtems/src/regionident.c
> index 6e18092..ca15664 100644
> --- a/cpukit/rtems/src/regionident.c
> +++ b/cpukit/rtems/src/regionident.c
> @@ -1,7 +1,11 @@
> - *  Region Manager
> + *  @file
> @@ -24,22 +28,6 @@
> - *  rtems_region_ident
> - *  This directive returns the system ID associated with
> - *  the region name.
> - *    name - user defined region name
> - *    id   - pointer to region id
> - *    *id      - region id
>    rtems_name  name,
>    rtems_id   *id
> diff --git a/cpukit/rtems/src/rtclock.c b/cpukit/rtems/src/rtclock.c
> index 515788c..fb4cb35 100644
> --- a/cpukit/rtems/src/rtclock.c
> +++ b/cpukit/rtems/src/rtclock.c
> @@ -1,6 +1,11 @@
> - *  Clock Manager
> + *  @file
> + *  @brief No Initialization Routine
> + *  @ingroup ClassicClock
> diff --git a/cpukit/rtems/src/rtemsobjectidgetnode.c
> b/cpukit/rtems/src/rtemsobjectidgetnode.c
> index eb97a37..15f8cd8 100644
> --- a/cpukit/rtems/src/rtemsobjectidgetnode.c
> +++ b/cpukit/rtems/src/rtemsobjectidgetnode.c
> @@ -1,6 +1,11 @@
> - *  RTEMS Object Helper -- Extract Node From Id
> + *  @file
> + *  @brief Get Node Portion of Object Id
> + *  @ingroup ClassicClassInfo
> diff --git a/cpukit/rtems/src/rtemstimer.c b/cpukit/rtems/src/rtemstimer.c
> index 6a8a3e0..6bf33c1 100644
> --- a/cpukit/rtems/src/rtemstimer.c
> +++ b/cpukit/rtems/src/rtemstimer.c
> @@ -1,7 +1,11 @@
> - *  Timer Manager
> + *  @file
> + *  @ingroup ClassicTimer
> @@ -24,16 +28,6 @@
>  #include <rtems/score/tod.h>
>  #include <rtems/score/watchdog.h>
> - *  _Timer_Manager_initialization
> - *  This routine initializes all timer manager related data structures.
>  void _Timer_Manager_initialization(void)
> diff --git a/cpukit/rtems/src/semtranslatereturncode.c
> b/cpukit/rtems/src/semtranslatereturncode.c
> index 2231df8..a06a848 100644
> --- a/cpukit/rtems/src/semtranslatereturncode.c
> +++ b/cpukit/rtems/src/semtranslatereturncode.c
> @@ -1,20 +1,11 @@
> - *  Semaphore Manager
> - *  DESCRIPTION:
> - *  This package is the implementation of the Semaphore Manager.
> - *  This manager utilizes standard Dijkstra counting semaphores to provide
> - *  synchronization and mutual exclusion capabilities.
> - *  Directives provided are:
> - *     + create a semaphore
> - *     + get an ID of a semaphore
> - *     + delete a semaphore
> - *     + acquire a semaphore
> - *     + release a semaphore
> + *  @file
> + *  @brief Semaphore Translate Core Mutex and Semaphore Return Code
> + *  @ingroup ClassicSem
> @@ -47,17 +38,6 @@
>  #include <rtems/score/interr.h>
> - *  _Semaphore_Translate_core_mutex_return_code
> - *    status - mutex status code to translate
> - *    rtems status code - translated RTEMS status code
>  const rtems_status_code _Semaphore_Translate_core_mutex_return_code_[] = {
>    RTEMS_SUCCESSFUL,         /* CORE_MUTEX_STATUS_SUCCESSFUL */
>    RTEMS_UNSATISFIED,        /* CORE_MUTEX_STATUS_UNSATISFIED_NOWAIT */
> @@ -95,17 +75,6 @@ rtems_status_code
>    return _Semaphore_Translate_core_mutex_return_code_[status];
> - *  _Semaphore_Translate_core_semaphore_return_code
> - *    status - semaphore status code to translate
> _Semaphore_Translate_core_semaphore_return_code_[] = {
>    RTEMS_SUCCESSFUL,         /* CORE_SEMAPHORE_STATUS_SUCCESSFUL */
>    RTEMS_UNSATISFIED,        /* CORE_SEMAPHORE_STATUS_UNSATISFIED_NOWAIT */
> diff --git a/cpukit/rtems/src/taskdelete.c b/cpukit/rtems/src/taskdelete.c
> index 5204569..2f78301 100644
> --- a/cpukit/rtems/src/taskdelete.c
> +++ b/cpukit/rtems/src/taskdelete.c
> @@ -1,7 +1,11 @@
> - *  RTEMS Task Manager
> + *  @file
> + *  @ingroup ClassicTasks
> @@ -30,23 +34,6 @@
> - *  rtems_task_delete
> - *  This directive allows a thread to delete itself or the thread
> - *  identified in the id field.  The executive halts execution
> - *  of the thread and frees the thread control block.
> - *    id - thread id
> - *    nothing           - if id is the requesting thread (always succeeds)
> - *    RTEMS_SUCCESSFUL - if successful and id is
> - *                           not the requesting thread
>    rtems_id id
> diff --git a/cpukit/rtems/src/taskident.c b/cpukit/rtems/src/taskident.c
> index 570aa35..2c30909 100644
> --- a/cpukit/rtems/src/taskident.c
> +++ b/cpukit/rtems/src/taskident.c
> @@ -1,7 +1,11 @@
> + *  @file
> @@ -29,23 +33,6 @@
>  #include <rtems/score/apiext.h>
> - *  rtems_task_ident
> - *  the thread name.
> - *    name - user defined thread name
> - *    node - node(s) to be searched
> - *    id   - pointer to thread id
> - *    *id               - thread id
>    rtems_name    name,
>    uint32_t      node,
> diff --git a/cpukit/rtems/src/tasksuspend.c
> b/cpukit/rtems/src/tasksuspend.c
> index e1e82dd..8128100 100644
> --- a/cpukit/rtems/src/tasksuspend.c
> +++ b/cpukit/rtems/src/tasksuspend.c
> @@ -1,7 +1,11 @@
> + *  @file
> @@ -29,21 +33,6 @@
> - *  rtems_task_suspend
> - *  This directive will place the specified thread in the "suspended"
> - *  state.  Note that the suspended state can be in addition to
> - *  other waiting states.
> - *    id - thread id
>    rtems_id id
> diff --git a/cpukit/rtems/src/taskvariable_invoke_dtor.c
> b/cpukit/rtems/src/taskvariable_invoke_dtor.c
> index 9f797c4..76fc268 100644
> --- a/cpukit/rtems/src/taskvariable_invoke_dtor.c
> +++ b/cpukit/rtems/src/taskvariable_invoke_dtor.c
> @@ -1,7 +1,11 @@
> - *  Invoke the destructor on a per-task variable
> + *  @file
> diff --git a/cpukit/rtems/src/timerfirewhen.c
> b/cpukit/rtems/src/timerfirewhen.c
> index df24e2a..487471f 100644
> --- a/cpukit/rtems/src/timerfirewhen.c
> +++ b/cpukit/rtems/src/timerfirewhen.c
> @@ -1,7 +1,11 @@
> - *  Timer Manager - rtems_timer_fire_when directive
> + *  @file
> @@ -23,22 +27,6 @@
> - *  rtems_timer_fire_when
> - *  This directive allows a thread to start a timer.
> - *    id        - timer id
> - *    wall_time - time of day to fire timer
> - *    routine   - routine to schedule
> - *    user_data - passed as argument to routine when it is fired
>    rtems_id                            id,
>    rtems_time_of_day                  *wall_time,
> diff --git a/cpukit/rtems/src/timerserverfireafter.c
> b/cpukit/rtems/src/timerserverfireafter.c
> index d515d5f..ee8dc8f 100644
> --- a/cpukit/rtems/src/timerserverfireafter.c
> +++ b/cpukit/rtems/src/timerserverfireafter.c
> @@ -1,7 +1,11 @@
> - *  Timer Manager - rtems_timer_server fire_after directive
> + *  @file
> @@ -23,23 +27,6 @@
> - *  rtems_timer_server_fire_after
> - *  This directive allows a thread to start a timer which will by
> - *  executed by the Timer Server when it fires.
> - *    id        - timer id
> - *    ticks     - interval until routine is fired
>    rtems_id                           id,
>    rtems_interval                     ticks,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20121205/c7143247/attachment-0001.html>
