[RFA] [PATCH] mips*el support for RTEMS
Sebastian Huber
Fri Dec 14 19:21:40 UTC 2012
Hello Feng,
it would really help if you can explain why you need this mips*el-rtems*
target. All targets have the pattern $arch-rtems*. Here $arch is
"mips" for example. The RTEMS tool chain comes with so called
multilibs. These are basic libraries like libc and libgcc compiled for
different ABIs and instruction sets. Since the MIPS tool chain already
provides a -mel multilib your patch makes no sense from my point of view.
On 13/12/12 09:40, Sebastian Huber wrote:
> On 12/13/2012 04:51 AM, feng Gao wrote:
>> Hello Sebastian,
>> We do need mips*el-*rtems* as defaut, so I hope the patch can be
>> approved.
>> May you please apply it?
> Why do you need a mips*el-*rtems* target? Why can you not simply use
> mips-rtems* with the -mel option?
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
