RTEMS Coding Style for Header Files
Sun Dec 16 14:13:41 UTC 2012
On 15/12/12 16:08, Gedare Bloom wrote:
> One issue that needs to be clarified is whether we want to use
> @param[] or @a, or a mix depending on the situation.
> I lean toward using the @param. Often the @a usage leads to awkward
> wording in description text.
I would also drop the @a completely and use @param only.
Thanks for updating the wiki.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
