AG patches chunk A
Daniel Hellstrom daniel at gaisler.com
Thu Feb 2 15:31:09 UTC 2012
On 02/02/2012 03:54 PM, Joel Sherrill wrote:
> On 02/02/2012 08:39 AM, Daniel Hellstrom wrote:
>> Hello,
>> I summarize the first chunk of patches, PATCH means I will send them on the rtems-devel list, PR means I will file a bugzilla PR. Feel free to comment.. and apply :)
> I am putting my first thought on whether or not a PR is required.
> Correct me if I am wrong.
>> Patches are listed in reverse apply order, thus IO_MANAGER patch comes last.
>> Thanks,
>> Daniel
>> + SPARC specific enhancements
>>       c1afe98 LEON3: fix compiler warning in SHM driver
> This sounds like an easy one to review. Probably completely
> benign and applies to 4.10 branch. Bugzilla.
one-line patch. Ok will add to bugzilla shortly.
>> + SPARC specific bugs
>>       3e2aa5e LEON3BSP MP: may wake one more CPU than expected
> Head only.
Ok, was a big quick here, was given BUG 2006. Is a bug though. Please terminate it.
>>       fe9dc9e SPARC BSPs: workspace must be aligned on a 8-byte boundary
> Bugzilla.
BUG 2007
>>       124e68d LEON3: CPU index intialization moved to bspstart.c
> I thought head but I read your description. This sounds like
> a bug fix to include in 4.10.
Yes a bug, however only on AMP systems. Will file a PR shortly.
>>       c7d92b6 LEON3: change d-cache snoop detect implementation
> Your description below makes this sound like it is a bug which
> needs to be a Bugzilla PR so it can be in a 4.10 release.
I think it is a bug, especially on a LEON3 UT699 where snooping is implemented but can not be enabled. Will file PR.
>>       LEON specific because GRETH driver only used by LEON:
>>       7a92dba GRETH: Moved print to remove potential deadlock
>>       6c66b13 GRETH: performance improvements and one bugfix
> Treat as one PR in Bugzilla.
Ok. Will add two patches in same PR.
>> + General bugs, (but not in any release, so PR not filed)
>>       839ef7b MP06 TEST: avoid program failure when slow UART on CPU core 0
> How is this not in a release?
Ok, sorry I thought the MP tests will be released first in RTEMS-4.11. This patch need reviewing.
>> + General enhancements
>>       fe2ee40 bootstrap: handy --root switch for bootstrapping subdirs
>>       11ae399 IO_MANAGER: early dynamic driver registration
> Definitely through devel.
Patches sent onto list as 09 and 10.
Thanks,
Daniel
>> PATCH commit 8713dbeead0fb5ce880793ef391916cc422efce5
>> Author: Daniel Hellstrom<daniel at gaisler.com>
>> Date:   Thu Nov 24 16:54:28 2011 +0100
>>       Adds the possibility to register drivers before the IO Manager has
>>       completed the initialization. Sometimes the BSP may want to register
>>       a driver dynamically early in the boot process.
>>       Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>> PATCH commit b2a54a1af400bf731855fe26c8c4550a7cc0697b
>> Date:   Fri Nov 25 13:58:07 2011 +0100
>>       Use the "--root DIR" to process only a subdir, for example
>>        $ ./bootstrap --root c/src/lib/libbsp/sparc
>>       will only generate Makefiles for all SPARC BSPs, saves some
>>       time when working with a specific BSP.
>> PR commit 6c66b134e18dc24b3fe8b2d9a9a6954c6bc6840e
>> Date:   Fri Dec 2 10:47:58 2011 +0100
>>       GRETH driver updated, 10-15% performance improvements for GBIT MAC,
>>       unnecessary RX interrupts not taken which under heavy load saves approx.
>>       1500 interrupts/s, one task removed saving about 5kb memory and 1 bug
>>       solved.
>>       BUG: RX interrupt was enabled before the RX-daemon was created which could
>>       result in a faulty call to rtems_event_send.
>> PR commit 7a92dba76fa113ab9fba1ddc90a2578ea8ff8d0a
>> Date:   Fri Dec 2 10:45:10 2011 +0100
>>       Deadlock may arise when the EDCL bug link is used to tunnel
>>       console output over Ethernet, when Ethernet is down one should
>>       avoid using console (only during debugging of LEON targets)
>>       Author: Marko Isomaki<marko at gaisler.com>
>> PR[DEP-1] commit c7d92b6562014f85a29bd94ceb2c3292f36dfb32
>> Date:   Fri Nov 25 14:02:00 2011 +0100
>>       The previous code only checked if d-cache snooping was implemented,
>>       however snooping may be available but not enabled which may lead
>>       to driver bugs.
>> PR commit 124e68d114f1ae6489ee86167357e6b6b16503e5
>> Date:   Fri Nov 25 14:15:16 2011 +0100
>>       All LEON3/4 systems have a CPU-id, if on a single-CPU system the
>>       ID is always zero. On a multicore system it ranges from 0 to 15.
>>       The CPU index should always by updated even in a non-MP RTEMS OS
>>       since the CPU running RTEMS may not always be CPU0. For example
>>       when RTEMS runs on CPU1 and Linux on CPU0 in a mixed ASMP system.
>>       The old code executed within the IRQ controller initialization code
>>       makes no sense since the ASR register is a CPU register, it has
>>       nothing to do with AMBA initialization either.
>> PATCH commit 839ef7ba191dc65ecbb777bbd108758025259d34
>> Date:   Wed Nov 16 16:56:46 2011 +0100
>> PR commit fe9dc9e1a55c1e71980eaa290f193cdae79141ca
>> Date:   Fri Nov 25 10:54:28 2011 +0100
>>       The linker-script already declares a 8-byte aligned symbol (_end)
>>       which can be used instead of "variable aligned" symbol end.
>> PR commit 3e2aa5ed2415ff02dac7545930f0a07c546dac77
>> Date:   Wed Nov 9 16:09:55 2011 +0100
>>       The SHM code always wakes one CPU more that configured, however
>>       this has never been a problem since RTEMS will be running on all CPUs
>>       or only two cores were available.
>> PATCH commit c1afe981bf63c79f695b6ff826c5109a9f7f1dd7
>> Date:   Fri Nov 25 11:33:11 2011 +0100
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
