AG patches chunk A
Thu Feb 2 19:54:20 UTC 2012
How about a new summary Daniel? And a confirmation that
the source in the tree is OK to you.
I think we cleared a number of them.
--joel
On 02/02/2012 09:31 AM, Daniel Hellstrom wrote:
> On 02/02/2012 03:54 PM, Joel Sherrill wrote:
>> On 02/02/2012 08:39 AM, Daniel Hellstrom wrote:
>>> Hello,
>>> I summarize the first chunk of patches, PATCH means I will send them on the rtems-devel list, PR means I will file a bugzilla PR. Feel free to comment.. and apply :)
>> I am putting my first thought on whether or not a PR is required.
>> Correct me if I am wrong.
>>> Patches are listed in reverse apply order, thus IO_MANAGER patch comes last.
>>> Thanks,
>>> Daniel
>>> + SPARC specific enhancements
>>>        c1afe98 LEON3: fix compiler warning in SHM driver
>> This sounds like an easy one to review. Probably completely
>> benign and applies to 4.10 branch. Bugzilla.
> one-line patch. Ok will add to bugzilla shortly.
>>> + SPARC specific bugs
>>>        3e2aa5e LEON3BSP MP: may wake one more CPU than expected
>> Head only.
> Ok, was a big quick here, was given BUG 2006. Is a bug though. Please terminate it.
>>>        fe9dc9e SPARC BSPs: workspace must be aligned on a 8-byte boundary
>> Bugzilla.
> BUG 2007
>>>        124e68d LEON3: CPU index intialization moved to bspstart.c
>> I thought head but I read your description. This sounds like
>> a bug fix to include in 4.10.
> Yes a bug, however only on AMP systems. Will file a PR shortly.
>>>        c7d92b6 LEON3: change d-cache snoop detect implementation
>> Your description below makes this sound like it is a bug which
>> needs to be a Bugzilla PR so it can be in a 4.10 release.
> I think it is a bug, especially on a LEON3 UT699 where snooping is implemented but can not be enabled. Will file PR.
>>>        LEON specific because GRETH driver only used by LEON:
>>>        7a92dba GRETH: Moved print to remove potential deadlock
>>>        6c66b13 GRETH: performance improvements and one bugfix
>> Treat as one PR in Bugzilla.
> Ok. Will add two patches in same PR.
>>> + General bugs, (but not in any release, so PR not filed)
>>>        839ef7b MP06 TEST: avoid program failure when slow UART on CPU core 0
>> How is this not in a release?
> Ok, sorry I thought the MP tests will be released first in RTEMS-4.11. This patch need reviewing.
>>> + General enhancements
>>>        fe2ee40 bootstrap: handy --root switch for bootstrapping subdirs
>>>        11ae399 IO_MANAGER: early dynamic driver registration
>> Definitely through devel.
> Patches sent onto list as 09 and 10.
> Thanks,
> Daniel
>>> PATCH commit 8713dbeead0fb5ce880793ef391916cc422efce5
>>> Author: Daniel Hellstrom<daniel at gaisler.com>
>>> Date:   Thu Nov 24 16:54:28 2011 +0100
>>>        Adds the possibility to register drivers before the IO Manager has
>>>        completed the initialization. Sometimes the BSP may want to register
>>>        a driver dynamically early in the boot process.
>>>        Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>>> PATCH commit b2a54a1af400bf731855fe26c8c4550a7cc0697b
>>> Date:   Fri Nov 25 13:58:07 2011 +0100
>>>        Use the "--root DIR" to process only a subdir, for example
>>>         $ ./bootstrap --root c/src/lib/libbsp/sparc
>>>        will only generate Makefiles for all SPARC BSPs, saves some
>>>        time when working with a specific BSP.
>>> PR commit 6c66b134e18dc24b3fe8b2d9a9a6954c6bc6840e
>>> Date:   Fri Dec 2 10:47:58 2011 +0100
>>>        GRETH driver updated, 10-15% performance improvements for GBIT MAC,
>>>        unnecessary RX interrupts not taken which under heavy load saves approx.
>>>        1500 interrupts/s, one task removed saving about 5kb memory and 1 bug
>>>        solved.
>>>        BUG: RX interrupt was enabled before the RX-daemon was created which could
>>>        result in a faulty call to rtems_event_send.
>>> PR commit 7a92dba76fa113ab9fba1ddc90a2578ea8ff8d0a
>>> Date:   Fri Dec 2 10:45:10 2011 +0100
>>>        Deadlock may arise when the EDCL bug link is used to tunnel
>>>        console output over Ethernet, when Ethernet is down one should
>>>        avoid using console (only during debugging of LEON targets)
>>>        Author: Marko Isomaki<marko at gaisler.com>
>>> PR[DEP-1] commit c7d92b6562014f85a29bd94ceb2c3292f36dfb32
>>> Date:   Fri Nov 25 14:02:00 2011 +0100
>>>        The previous code only checked if d-cache snooping was implemented,
>>>        however snooping may be available but not enabled which may lead
>>>        to driver bugs.
>>> PR commit 124e68d114f1ae6489ee86167357e6b6b16503e5
>>> Date:   Fri Nov 25 14:15:16 2011 +0100
>>>        All LEON3/4 systems have a CPU-id, if on a single-CPU system the
>>>        ID is always zero. On a multicore system it ranges from 0 to 15.
>>>        The CPU index should always by updated even in a non-MP RTEMS OS
>>>        since the CPU running RTEMS may not always be CPU0. For example
>>>        when RTEMS runs on CPU1 and Linux on CPU0 in a mixed ASMP system.
>>>        The old code executed within the IRQ controller initialization code
>>>        makes no sense since the ASR register is a CPU register, it has
>>>        nothing to do with AMBA initialization either.
>>> PATCH commit 839ef7ba191dc65ecbb777bbd108758025259d34
>>> Date:   Wed Nov 16 16:56:46 2011 +0100
>>> PR commit fe9dc9e1a55c1e71980eaa290f193cdae79141ca
>>> Date:   Fri Nov 25 10:54:28 2011 +0100
>>>        The linker-script already declares a 8-byte aligned symbol (_end)
>>>        which can be used instead of "variable aligned" symbol end.
>>> PR commit 3e2aa5ed2415ff02dac7545930f0a07c546dac77
>>> Date:   Wed Nov 9 16:09:55 2011 +0100
>>>        The SHM code always wakes one CPU more that configured, however
>>>        this has never been a problem since RTEMS will be running on all CPUs
>>>        or only two cores were available.
>>> PATCH commit c1afe981bf63c79f695b6ff826c5109a9f7f1dd7
>>> Date:   Fri Nov 25 11:33:11 2011 +0100
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
Joel Sherrill, Ph.D.             Director of Research&   Development
