AG patches chunk A
Daniel Hellstrom daniel at gaisler.com
Fri Feb 3 13:29:56 UTC 2012
On 02/02/2012 03:39 PM, Daniel Hellstrom wrote:
> Hello,
> I summarize the first chunk of patches, PATCH means I will send them on the rtems-devel list, PR means I will file a bugzilla PR. Feel free to comment.. and apply :)
> Patches are listed in reverse apply order, thus IO_MANAGER patch comes last.
> Thanks,
> Daniel
A summary of chunk A status:
> + SPARC specific enhancements
>     c1afe98 LEON3: fix compiler warning in SHM driver
BUG 2008. closed.
> + SPARC specific bugs
>     3e2aa5e LEON3BSP MP: may wake one more CPU than expected
BUG 2006. closed
>     fe9dc9e SPARC BSPs: workspace must be aligned on a 8-byte boundary
BUG 2007. closed
>     124e68d LEON3: CPU index intialization moved to bspstart.c
BUG 2009. closed
>     c7d92b6 LEON3: change d-cache snoop detect implementation
BUG 2010. closed
>     LEON specific because GRETH driver only used by LEON:
>     7a92dba GRETH: Moved print to remove potential deadlock
>     6c66b13 GRETH: performance improvements and one bugfix
BUG 2011. closed. (both GRETH patches, in same PR)
> + General bugs, (but not in any release, so PR not filed)
>     839ef7b MP06 TEST: avoid program failure when slow UART on CPU core 0
Pushed to future discussion, considered dirty. I'm dropping this issue at the moment, we can come back to this later on.
> + General enhancements
>     fe2ee40 bootstrap: handy --root switch for bootstrapping subdirs
Sent to list, no comments.
>     11ae399 IO_MANAGER: early dynamic driver registration
Sent to list, on-going discussion.
I'm satisfied with the current status, I can move on to chunk B. The last two patches has no dependencies any way.
I have rebased my two branches, master and 4.10 branch without conflicts.
Thanks all,
Daniel
> PATCH commit 8713dbeead0fb5ce880793ef391916cc422efce5
> Author: Daniel Hellstrom <daniel at gaisler.com>
> Date:   Thu Nov 24 16:54:28 2011 +0100
>     Adds the possibility to register drivers before the IO Manager has
>     completed the initialization. Sometimes the BSP may want to register
>     a driver dynamically early in the boot process.
>     Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
> PATCH commit b2a54a1af400bf731855fe26c8c4550a7cc0697b
> Date:   Fri Nov 25 13:58:07 2011 +0100
>     Use the "--root DIR" to process only a subdir, for example
>      $ ./bootstrap --root c/src/lib/libbsp/sparc
>     will only generate Makefiles for all SPARC BSPs, saves some
>     time when working with a specific BSP.
> PR commit 6c66b134e18dc24b3fe8b2d9a9a6954c6bc6840e
> Date:   Fri Dec 2 10:47:58 2011 +0100
>     GRETH driver updated, 10-15% performance improvements for GBIT MAC,
>     unnecessary RX interrupts not taken which under heavy load saves approx.
>     1500 interrupts/s, one task removed saving about 5kb memory and 1 bug
>     solved.
>     BUG: RX interrupt was enabled before the RX-daemon was created which could
>     result in a faulty call to rtems_event_send.
> PR commit 7a92dba76fa113ab9fba1ddc90a2578ea8ff8d0a
> Date:   Fri Dec 2 10:45:10 2011 +0100
>     Deadlock may arise when the EDCL bug link is used to tunnel
>     console output over Ethernet, when Ethernet is down one should
>     avoid using console (only during debugging of LEON targets)
>     Author: Marko Isomaki <marko at gaisler.com>
> PR[DEP-1] commit c7d92b6562014f85a29bd94ceb2c3292f36dfb32
> Date:   Fri Nov 25 14:02:00 2011 +0100
>     The previous code only checked if d-cache snooping was implemented,
>     however snooping may be available but not enabled which may lead
>     to driver bugs.
> PR commit 124e68d114f1ae6489ee86167357e6b6b16503e5
> Date:   Fri Nov 25 14:15:16 2011 +0100
>     All LEON3/4 systems have a CPU-id, if on a single-CPU system the
>     ID is always zero. On a multicore system it ranges from 0 to 15.
>     The CPU index should always by updated even in a non-MP RTEMS OS
>     since the CPU running RTEMS may not always be CPU0. For example
>     when RTEMS runs on CPU1 and Linux on CPU0 in a mixed ASMP system.
>     The old code executed within the IRQ controller initialization code
>     makes no sense since the ASR register is a CPU register, it has
>     nothing to do with AMBA initialization either.
> PATCH commit 839ef7ba191dc65ecbb777bbd108758025259d34
> Date:   Wed Nov 16 16:56:46 2011 +0100
> PR commit fe9dc9e1a55c1e71980eaa290f193cdae79141ca
> Date:   Fri Nov 25 10:54:28 2011 +0100
>     The linker-script already declares a 8-byte aligned symbol (_end)
>     which can be used instead of "variable aligned" symbol end.
> PR commit 3e2aa5ed2415ff02dac7545930f0a07c546dac77
> Date:   Wed Nov 9 16:09:55 2011 +0100
>     The SHM code always wakes one CPU more that configured, however
>     this has never been a problem since RTEMS will be running on all CPUs
>     or only two cores were available.
> PATCH commit c1afe981bf63c79f695b6ff826c5109a9f7f1dd7
> Date:   Fri Nov 25 11:33:11 2011 +0100
> rtems-devel mailing list
> rtems-devel at rtems.org
