[PATCH 09 v2] bootstrap: handy --base switch for bootstrapping subdirs
Daniel Hellstrom daniel at gaisler.com
Fri Feb 3 15:14:18 UTC 2012
Use the "-b/--base DIR" to process only a subdir, for example
 $ ./bootstrap --base c/src/lib/libbsp/sparc
will only generate Makefiles for all SPARC BSPs, saves some
time when working with a specific BSP.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
 bootstrap |   45 +++++++++++++++++++++++++++------------------
 1 files changed, 27 insertions(+), 18 deletions(-)
diff --git a/bootstrap b/bootstrap
index 1a2a424..b4187b3 100755
--- a/bootstrap
+++ b/bootstrap
@@ -18,6 +18,7 @@ top_srcdir=`dirname $0`
 verbose="";
 quiet="false"
 mode="autoreconf"
+base=.
 usage()
@@ -25,6 +26,7 @@ usage()
   echo "usage: ${progname} [-c|-p|-h] [-q][-v]"
   echo
   echo "options:"
+  echo "	-b .. base directory tree for bootstrapping processing, defaults to ."
   echo "	-c .. clean, remove all aclocal/autoconf/automake generated files"
   echo "	-h .. display this message and exit"
   echo "	-p .. regenerate preinstall.am files"
@@ -92,6 +94,13 @@ case $1 in
 -g|--ge|--gen|--gene|--gener|--genera|--generat|--generate)
   mode="generate";
   shift;;
+-b|--ba|--bas|--base)
+  if [ $# -lt 2 ]; then
+    echo "base option requires one argument"
+    exit 1
+  fi
+  base=$2;
+  shift 2;;
 -*) echo "unknown option $1" ;
   usage ;;
 *) echo "invalid parameter $1" ;
@@ -101,7 +110,7 @@ done
 case $mode in
 preinstall)
-  confs=`find . -name Makefile.am -exec grep -l 'include .*/preinstall\.am' {} \;`
+  confs=`find $base -name Makefile.am -exec grep -l 'include .*/preinstall\.am' {} \;`
   for i in $confs; do
     dir=$(dirname $i);
     test "$quite" = "true" || echo "Generating $dir/preinstall.am"
@@ -141,7 +150,7 @@ generate)
   esac
-  confs=`find . \( -name 'configure.in' -o -name 'configure.ac' \) -print`
+  confs=`find $base \( -name 'configure.in' -o -name 'configure.ac' \) -print`
   for i in $confs; do
   dir=`dirname $i`;
   configure=`basename $i`;
@@ -173,7 +182,7 @@ autoreconf)
     exit 1
   fi
-  confs=`find . -name 'configure.ac' -print`
+  confs=`find $base -name 'configure.ac' -print $maxdepth`
   for i in $confs; do
   dir=`dirname $i`;
@@ -190,14 +199,14 @@ autoreconf)
 clean)
   test "$quiet" = "true" || echo "removing automake generated Makefile.in files"
-  files=`find . -name 'Makefile.am' -print | sed -e 's%\.am%\.in%g'` ;
+  files=`find $base -name 'Makefile.am' -print | sed -e 's%\.am%\.in%g'` ;
   for i in $files; do if test -f $i; then
     rm -f $i
     test "$verbose" = "-v" && echo "$i"
   fi; done
   test "$quiet" = "true" || echo "removing configure files"
-  files=`find . -name 'configure' -print` ;
+  files=`find $base -name 'configure' -print` ;
   test "$verbose" = "-v" && test -n "$files" && echo "$files" ;
     rm -f $i config.sub config.guess install-sh missing mkinstalldirs
@@ -206,25 +215,25 @@ clean)
   fi; done
   test "$quiet" = "true" || echo "removing aclocal.m4 files"
-  files=`find . -name 'aclocal.m4' -print` ;
+  files=`find $base -name 'aclocal.m4' -print` ;
     rm -f $i
   fi; done
-  find . -name '*~' -print | xargs rm -f
-  find . -name 'bspopts.h.in' -print | xargs rm -f
-  find . -name '*.orig' -print | xargs rm -f
-  find . -name '*.rej' -print | xargs rm -f
-  find . -name 'config.status' -print | xargs rm -f
-  find . -name 'config.log' -print | xargs rm -f
-  find . -name 'config.cache' -print | xargs rm -f
-  find . -name 'Makefile' -print | xargs rm -f
-  find . -name '.deps' -print | xargs rm -rf
-  find . -name '.libs' -print | xargs rm -rf
-  find . -name 'stamp-h.in' | xargs rm -rf
-  find . -name 'autom4te*.cache' | xargs rm -rf
+  find $base -name '*~' -print | xargs rm -f
+  find $base -name 'bspopts.h.in' -print | xargs rm -f
+  find $base -name '*.orig' -print | xargs rm -f
+  find $base -name '*.rej' -print | xargs rm -f
+  find $base -name 'config.status' -print | xargs rm -f
+  find $base -name 'config.log' -print | xargs rm -f
+  find $base -name 'config.cache' -print | xargs rm -f
+  find $base -name 'Makefile' -print | xargs rm -f
+  find $base -name '.deps' -print | xargs rm -rf
+  find $base -name '.libs' -print | xargs rm -rf
+  find $base -name 'stamp-h.in' | xargs rm -rf
+  find $base -name 'autom4te*.cache' | xargs rm -rf
 esac
1.7.0.4
