[PATCH 11] SPARC: added libcpu lowlevel access and byteorder routines/definitions
Mon Feb 6 15:33:53 UTC 2012
On Mon, Feb 6, 2012 at 9:15 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> The low level routines can be used in different occasions, it will be
> required when accessing PCI.
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>  c/src/lib/libbsp/sparc/erc32/Makefile.am          |    4 +-
>  c/src/lib/libbsp/sparc/leon2/Makefile.am          |    1 +
>  c/src/lib/libbsp/sparc/leon3/Makefile.am          |    4 +-
>  c/src/lib/libcpu/sparc/Makefile.am                |    7 ++
>  c/src/lib/libcpu/sparc/access/access.S            |   65 ++++++++++++++++++++
>  c/src/lib/libcpu/sparc/access/access_le.c         |   32 ++++++++++
>  c/src/lib/libcpu/sparc/include/libcpu/access.h    |   48 +++++++++++++++
>  c/src/lib/libcpu/sparc/include/libcpu/byteorder.h |   66 +++++++++++++++++++++
>  c/src/lib/libcpu/sparc/preinstall.am              |    8 +++
>  9 files changed, 233 insertions(+), 2 deletions(-)
>  create mode 100644 c/src/lib/libcpu/sparc/access/access.S
>  create mode 100644 c/src/lib/libcpu/sparc/access/access_le.c
>  create mode 100644 c/src/lib/libcpu/sparc/include/libcpu/access.h
>  create mode 100644 c/src/lib/libcpu/sparc/include/libcpu/byteorder.h
> diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> index abe44c3..cecfe14 100644
> --- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> @@ -68,7 +68,9 @@ erc32sonic_rel_CPPFLAGS = $(AM_CPPFLAGS) $(erc32sonic_CPPFLAGS)
>  erc32sonic_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>  endif
> -libbsp_a_LIBADD  = ../../../libcpu/@RTEMS_CPU@/cache.rel \
> +libbsp_a_LIBADD  = \
> +    ../../../libcpu/@RTEMS_CPU@/access.rel \
> +    ../../../libcpu/@RTEMS_CPU@/cache.rel \
>     ../../../libcpu/@RTEMS_CPU@/reg_win.rel \
>     ../../../libcpu/@RTEMS_CPU@/syscall.rel
>  if HAS_NETWORKING
> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> index 9c7819c..9df3c7d 100644
> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> @@ -118,6 +118,7 @@ leon_open_eth_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>  endif
>  libbsp_a_LIBADD = \
> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> index 5edbe9d..8eae306 100644
> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> @@ -126,7 +126,9 @@ libbsp_a_SOURCES += shmsupp/addrconv.c shmsupp/getcfg.c shmsupp/lock.c \
>     shmsupp/mpisr.c
>  endif
> diff --git a/c/src/lib/libcpu/sparc/Makefile.am b/c/src/lib/libcpu/sparc/Makefile.am
> index 7bebd94..711d6b1 100644
> --- a/c/src/lib/libcpu/sparc/Makefile.am
> +++ b/c/src/lib/libcpu/sparc/Makefile.am
> @@ -10,6 +10,8 @@ noinst_PROGRAMS =
>  include_libcpudir = $(includedir)/libcpu
>  include_libcpu_HEADERS = ../shared/include/cache.h
> +include_libcpu_HEADERS += include/libcpu/byteorder.h
> +include_libcpu_HEADERS += include/libcpu/access.h
>  noinst_PROGRAMS += cache.rel
>  cache_rel_SOURCES = cache/cache.c cache/cache_.h \
> @@ -31,5 +33,10 @@ reg_win_rel_SOURCES = reg_win/window.S
>  reg_win_rel_CPPFLAGS = $(AM_CPPFLAGS)
>  reg_win_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
> +noinst_PROGRAMS += access.rel
> +access_rel_SOURCES = access/access.S access/access_le.c
> +access_rel_CPPFLAGS = $(AM_CPPFLAGS)
> +access_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>  include $(srcdir)/preinstall.am
>  include $(top_srcdir)/../../../automake/local.am
> diff --git a/c/src/lib/libcpu/sparc/access/access.S b/c/src/lib/libcpu/sparc/access/access.S
> new file mode 100644
> index 0000000..7e69f64
> --- /dev/null
> +++ b/c/src/lib/libcpu/sparc/access/access.S
> @@ -0,0 +1,65 @@
> + *  Access routines for SPARC
> + *  COPYRIGHT (c) 2011
> + *  Aeroflex Gaisler.
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.com/license/LICENSE.
> +#include <rtems/asm.h>
> +       .align 4
> +       .seg "text"
> +       PUBLIC(_ld8)
> +       PUBLIC(_ld16)
> +       PUBLIC(_ld32)
> +       PUBLIC(_ld64)
> +       PUBLIC(_st8)
> +       PUBLIC(_st16)
> +       PUBLIC(_st32)
> +       PUBLIC(_st64)
> +       PUBLIC(_ld_be16)
> +       PUBLIC(_ld_be32)
> +       PUBLIC(_st_be16)
> +       PUBLIC(_st_be32)
> +SYM(_ld8):
> +       retl
> +        ldub [%o0], %o0
> +SYM(_ld_be16):
> +SYM(_ld16):
> +       retl
> +        lduh [%o0], %o0
> +SYM(_ld_be32):
> +SYM(_ld32):
> +       retl
> +        ld [%o0], %o0
> +SYM(_ld_be64):
> +SYM(_ld64):
> +       retl
> +        ldd [%o0], %o0
> +SYM(_st8):
> +       retl
> +        stub %o1, [%o0]
> +SYM(_st_be16):
> +SYM(_st16):
> +       retl
> +        stuh %o1, [%o0]
> +SYM(_st_be32):
> +SYM(_st32):
> +       retl
> +        st %o1, [%o0]
> +SYM(_st_be64):
> +SYM(_st64):
> +       retl
> +        std %o1, [%o0]
Do these functions get used somewhere I don't see?
Do we need these defined in assembly language, maybe at least inline
assembly would be better to get some kind of type-checking assist from
the compiler?
I suspect something is wrong with the _st64/_st_be64 function, because
sparc uses paired registers to store a 64-bit number the compiler will
pack the arguments differently and probably as o0/o1 or o2/o3.
> diff --git a/c/src/lib/libcpu/sparc/access/access_le.c b/c/src/lib/libcpu/sparc/access/access_le.c
> index 0000000..15031cc
> --- /dev/null
> +++ b/c/src/lib/libcpu/sparc/access/access_le.c
> @@ -0,0 +1,32 @@
> + *  Little-endian access routines for SPARC
> +#include <libcpu/byteorder.h>
> +uint16_t _ld_le16(uint16_t *addr)
> +       return ld_le16(addr);
> +void _st_le16(uint16_t *addr, uint16_t val)
> +       st_le16(addr, val);
> +uint32_t _ld_le32(uint32_t *addr)
> +       return ld_le32(addr);
> +void _st_le32(uint32_t *addr, uint32_t val)
> +       st_le32(addr, val);
> diff --git a/c/src/lib/libcpu/sparc/include/libcpu/access.h b/c/src/lib/libcpu/sparc/include/libcpu/access.h
> index 0000000..2d87c2a
> --- /dev/null
> +++ b/c/src/lib/libcpu/sparc/include/libcpu/access.h
> @@ -0,0 +1,48 @@
> + *  access.h  - access routines for SPARC. SPARC is big endian only.
> +#ifndef _LIBCPU_ACCESS_H
> +#define _LIBCPU_ACCESS_H
> +#include <rtems/system.h>
> +#include <rtems/score/cpu.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +/* "Raw" access */
> +extern uint8_t _ld8(uint8_t *addr);
> +extern void _st8(uint8_t *addr, uint8_t val);
> +extern uint16_t _ld16(uint16_t *addr);
> +extern void _st16(uint16_t *addr, uint16_t val);
> +extern uint32_t _ld32(uint32_t *addr);
> +extern void _st32(uint32_t *addr, uint32_t val);
> +extern uint64_t _ld64(uint64_t *addr);
> +extern void _st64(uint64_t *addr, uint64_t val);
> +/* Aliases for Big Endian */
> +extern uint16_t _ld_be16(uint16_t *addr);
> +extern void _st_be16(uint16_t *addr, uint16_t val);
> +extern uint32_t _ld_be32(uint32_t *addr);
> +extern void _st_be32(uint32_t *addr, uint32_t val);
> +/* Little endian */
> +extern uint16_t _ld_le16(uint16_t *addr);
> +extern void _st_le16(uint16_t *addr, uint16_t val);
> +extern uint32_t _ld_le32(uint32_t *addr);
> +extern void _st_le32(uint32_t *addr, uint32_t val);
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/c/src/lib/libcpu/sparc/include/libcpu/byteorder.h b/c/src/lib/libcpu/sparc/include/libcpu/byteorder.h
> index 0000000..d626f28
> --- /dev/null
> +++ b/c/src/lib/libcpu/sparc/include/libcpu/byteorder.h
> @@ -0,0 +1,66 @@
> + *  byteorder.h  - Endian conversion for SPARC. SPARC is big endian only.
> +#ifndef _LIBCPU_BYTEORDER_H
> +#define _LIBCPU_BYTEORDER_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +RTEMS_INLINE_ROUTINE uint16_t ld_le16(volatile uint16_t *addr)
> +       return CPU_swap_u16(*addr);
> +RTEMS_INLINE_ROUTINE void st_le16(volatile uint16_t *addr, uint16_t val)
> +       *addr = CPU_swap_u16(val);
> +RTEMS_INLINE_ROUTINE uint32_t ld_le32(volatile uint32_t *addr)
> +       return CPU_swap_u32(*addr);
> +RTEMS_INLINE_ROUTINE void st_le32(volatile uint32_t *addr, uint32_t val)
> +       *addr = CPU_swap_u32(val);
> +RTEMS_INLINE_ROUTINE uint16_t ld_be16(volatile uint16_t *addr)
> +       return *addr;
> +RTEMS_INLINE_ROUTINE void st_be16(volatile uint16_t *addr, uint16_t val)
> +       *addr = val;
> +RTEMS_INLINE_ROUTINE uint32_t ld_be32(volatile uint32_t *addr)
> +       return *addr;
> +RTEMS_INLINE_ROUTINE void st_be32(volatile uint32_t *addr, uint32_t val)
> +       *addr = val;
Is there a reason for the addr argument to be volatile to these functions?
Why not use the functions defined above in access.h?
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/c/src/lib/libcpu/sparc/preinstall.am b/c/src/lib/libcpu/sparc/preinstall.am
> index 412b683..2efe38b 100644
> --- a/c/src/lib/libcpu/sparc/preinstall.am
> +++ b/c/src/lib/libcpu/sparc/preinstall.am
> @@ -22,3 +22,11 @@ $(PROJECT_INCLUDE)/libcpu/cache.h: ../shared/include/cache.h $(PROJECT_INCLUDE)/
>        $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache.h
> +$(PROJECT_INCLUDE)/libcpu/byteorder.h: include/libcpu/byteorder.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/byteorder.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/byteorder.h
> +$(PROJECT_INCLUDE)/libcpu/access.h: include/libcpu/access.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/access.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/access.h
> 1.7.0.4
> rtems-devel mailing list
> rtems-devel at rtems.org
