[PATCH 12] SPARC BSPs: bsp_early_malloc() routine for startup memory allocation
Daniel Hellstrom daniel at gaisler.com
Mon Feb 6 16:08:20 UTC 2012
On 02/06/2012 04:45 PM, Gedare Bloom wrote:
> On Mon, Feb 6, 2012 at 9:15 AM, Daniel Hellstrom<daniel at gaisler.com>  wrote:
>> If bsp_early_malloc() is called early during boot room will be
>> allocated after BSS END. If the function is called after boot
>> is will call malloc() instead. The returned memory is not freeable
>> and always 8-byte aligned.
>> If the bsp_early_malloc() isn't called the function is not
>> dragged in and the workspace will be unmodified in size.
>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>>   c/src/lib/libbsp/sparc/erc32/Makefile.am           |    2 +-
>>   c/src/lib/libbsp/sparc/erc32/include/bsp.h         |    3 +
>>   c/src/lib/libbsp/sparc/leon2/Makefile.am           |    3 +-
>>   c/src/lib/libbsp/sparc/leon2/include/bsp.h         |    3 +
>>   c/src/lib/libbsp/sparc/leon3/Makefile.am           |    2 +-
>>   c/src/lib/libbsp/sparc/leon3/include/bsp.h         |    3 +
>>   c/src/lib/libbsp/sparc/shared/bspgetworkarea.c     |   10 ++++-
>>   .../lib/libbsp/sparc/shared/startup/early_malloc.c |   44 ++++++++++++++++++++
>>   8 files changed, 65 insertions(+), 5 deletions(-)
>>   create mode 100644 c/src/lib/libbsp/sparc/shared/startup/early_malloc.c
>> diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
>> index cecfe14..e70310d 100644
>> --- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
>> +++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
>> @@ -38,7 +38,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
>>      ../../shared/bspstart.c ../../shared/bootcard.c ../../shared/bspinit.c \
>>      ../../shared/sbrk.c startup/setvec.c startup/spurious.c \
>>      startup/erc32mec.c startup/boardinit.S startup/bspidle.c \
>> -    startup/bspdelay.c
>> +    startup/bspdelay.c ../../sparc/shared/startup/early_malloc.c
>>   # ISR Handler
>>   libbsp_a_SOURCES += ../../sparc/shared/irq_asm.S
>>   # gnatsupp
>> diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>> index 8655732..8075e8e 100644
>> --- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>> +++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>> @@ -81,6 +81,9 @@ void BSP_fatal_return( void );
>>   void bsp_spurious_initialize( void );
>> +/* Allocate 8-byte aligned non-freeable pre-malloc memory */
>> +void *bsp_early_malloc(int size);
>>   #ifdef __cplusplus
>>   #endif
>> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
>> index 9df3c7d..6e2697f 100644
>> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
>> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
>> @@ -55,7 +55,8 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
>>      startup/bspstart.c ../../sparc/shared/bsppretaskinghook.c \
>>      ../../sparc/shared/bspgetworkarea.c ../../shared/bootcard.c \
>>      ../../shared/sbrk.c startup/setvec.c startup/spurious.c startup/bspidle.c \
>> -    ../../shared/bspinit.c startup/bspdelay.c
>> +    ../../shared/bspinit.c startup/bspdelay.c \
>> +    ../../sparc/shared/startup/early_malloc.c
>>   # ISR Handler
>>   # gnatsupp
>> diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>> index 34e31ce..b0695cb 100644
>> --- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>> +++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>> @@ -94,6 +94,9 @@ void BSP_fatal_return( void );
>>   #ifdef __cplusplus
>>   #endif
>> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> index 8eae306..dc24051 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>>      ../../sparc/shared/bsppretaskinghook.c ../../shared/bsppredriverhook.c \
>>      ../../sparc/shared/bspgetworkarea.c ../../shared/sbrk.c startup/setvec.c \
>>      startup/spurious.c startup/bspidle.S startup/bspdelay.c \
>> +    ../../shared/bspinit.c ../../sparc/shared/startup/early_malloc.c
>>   # ISR Handler
>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>> index 89b36d4..70ab8b3 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>> @@ -104,6 +104,9 @@ void BSP_fatal_return( void );
>>   #ifdef __cplusplus
>>   #endif
>> diff --git a/c/src/lib/libbsp/sparc/shared/bspgetworkarea.c b/c/src/lib/libbsp/sparc/shared/bspgetworkarea.c
>> index c6e1491..580a911 100644
>> --- a/c/src/lib/libbsp/sparc/shared/bspgetworkarea.c
>> +++ b/c/src/lib/libbsp/sparc/shared/bspgetworkarea.c
>> @@ -22,6 +22,9 @@
>>   /* Tells us where to put the workspace in case remote debugger is present.  */
>>   extern uint32_t rdb_start;
>> +/* Must be aligned to 8, _end is aligned to 8 */
>> +unsigned int early_mem = (unsigned int)&end;
>>   *  This method returns the base address and size of the area which
>>   *  is to be allocated between the RTEMS Workspace and the C Program
>> @@ -37,8 +40,11 @@ void bsp_get_work_area(
>>    /* must be identical to STACK_SIZE in start.S */
>>    #define STACK_SIZE (16 * 1024)
>> -  *work_area_start =&end;
>> -  *work_area_size  = (void *)rdb_start - (void *)&end - STACK_SIZE;
>> +  /* Early dynamic memory allocator is placed just above _end  */
>> +  *work_area_start = (void *)early_mem;
>> +  *work_area_size  = (void *)rdb_start - (void *)early_mem - STACK_SIZE;
>> +  early_mem        = ~0; /* Signal bsp_early_malloc not to be used anymore */
>>    *heap_start      = BSP_BOOTCARD_HEAP_USES_WORK_AREA;
>>    *heap_size       = BSP_BOOTCARD_HEAP_SIZE_DEFAULT;
>> diff --git a/c/src/lib/libbsp/sparc/shared/startup/early_malloc.c b/c/src/lib/libbsp/sparc/shared/startup/early_malloc.c
>> new file mode 100644
>> index 0000000..c6abaca
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/shared/startup/early_malloc.c
>> @@ -0,0 +1,44 @@
>> + *  Early dynamic memory allocation (not freeable) for BSP
>> + *  boot routines. Minimum alignment 8 bytes. Memory is
>> + *  allocated after _end, it will shrink the workspace.
>> + *  COPYRIGHT (c) 2011.
>> + *  Aeroflex Gaisler AB
>> + *  The license and distribution terms for this file may be
>> + *  found in the file LICENSE in this distribution or at
>> + *  http://www.rtems.com/license/LICENSE.
>> + *  $Id: early_malloc.c
>> +#include<bsp.h>
>> +#include<stdlib.h>
>> +/* Tells us where to put the workspace in case remote debugger is present. */
>> +extern uint32_t rdb_start;
>> +/* Must be aligned to 8 */
>> +extern unsigned int early_mem;
>> +/* must be identical to STACK_SIZE in start.S */
>> +#define STACK_SIZE (16 * 1024)
>> +       void *start;
>> +       /* Not early anymore? */
>> +       if (early_mem == ~0)
>> +               return malloc(size);
>> +       size = (size + 7)&  ~0x7;
>> +       if (rdb_start - STACK_SIZE - early_mem<  size)
>> +               return NULL;
>> +       start = (void *)early_mem;
>> +       early_mem += size;
>> +       return start;
>> 1.7.0.4
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
> This looks OK to me. Basic bump allocation for early dynamic memory.
> workspace is properly adjusted. If the BSP exhausts memory then RTEMS
> should fail gracefully during bootup when it detects the workspace is
> not big enough.
> I wonder if there would be any use in having this early memory
> mechanism available on every BSP? For what do you use it?
I will use it later in a AMBA Plug&Play layer patch.
The LEON3/4 is plug and play, one never knows how many cores are available on boot, the PnP layers scan the plug&play info and creates one "RAM structure" description per PnP entry. Before this was
made by allocating a worst-case structure in leon3/amba/amba.c (amba_confarea_type amba_conf) which could hold lots of RAM descriptions. However on small systems its a waste, and on very large systems
it breaks. Using malloc() would require BSP initialization too late and malloc() wastes 4 or 8-bytes per allocation of memory that we never would have freed anyway.
It can probably be useful for other BSPs as well.
Daniel
