AG patches chunk B
Daniel Hellstrom daniel at gaisler.com
Thu Feb 9 10:06:43 UTC 2012
On 02/06/2012 02:48 PM, Daniel Hellstrom wrote:
> Hello,
> This is the second chunk of patches, there are still two open (bootstrap and IO_MANAGER) since last chunk. Since the first patches does not depend on anything in chunk B I descided to move on.
> As before, PATCH means I will send them on the rtems-devel list solely, PR means I will file a bugzilla PR.
> Note that GRETH-autoneg patch closes already opened PR 1465, thanks to Joris the PR was brought up again.
A summary of status of chunk B so far.
> + SPARC specific enhancements
> LIST 512a080 SPARC: added libcpu lowlevel access and byteorder routines/definitions
On the list.
Patch updated to Joel and Gedares comments. Gadare: Looks good to me.
> LIST 5a2482c SPARC BSPs: bsp_early_malloc() routine for startup memory allocation
On the list.
Discussion about making bsp_early_malloc() available on all BSPs, it was concluded that it is not really needed for all BSPs. Unsure of the status here.
> LIST dec5e65 LEON3: make SHM driver configurable using weak
BUG 2015
Fixed Gedares comments about global variable initialization: version 2 submitted to list and bugzilla
> LIST 62003f0 LEON3: spurious trap handler print out trap in hex instead
On list.
Gedare: Looks good.
> + SPARC specific bugs
>  NONE
> + General bugs
> PR be4f867 SMC91111: ERC32 was never supported by driver
BUG 2016
Gedare: seems ok
> + General bugs (only used by LEON2/LEON3 BSPS)
> PR 4a81ecd GRETH: Fixed autonego timeout overflow problem
BUG 1465.
Joris: This looks fine
Gedare: looks good
> PR[1465] 815d368 GRETH: added support for non-snooping GRETH 10/100 systems
BUG  2014
Fixed Gedares comments, Patch Version 3 on list and in bugzilla.
> + General enhancements
> LIST cf004f3 shared-irq: add support for custom BSP vector verification
On the list
Gedare: seems reasonable
> Patches are listed in reverse apply order, thus SPARC-access patch comes last.
> PR commit 815d36885ec5e5d93926aac517bb8fe6d8c654b5
> Author: Daniel Hellstrom <daniel at gaisler.com>
> Date:   Fri Dec 2 10:53:35 2011 +0100
>     When data cache snooping is not present the cache needs
>     flushing, the SPARC LEON CPUs does not have to ability
>     to flush individual cache rows and flushing all cache is
>     expensive. Instead the LDA instruction is used to force
>     cache miss on individual loads during the IP-align copy
>     operation required anyway.
>     GRETH GBIT non-snooping systems are still unsupported,
>     since it use zero-copy (can deal with unaligned DMA).
>     Also, made the GRETH driver only built on LEON2/LEON3
>     platforms.
>     Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>  c/src/libchip/network/greth.c |   80 +++++++++++++++++++++++++++++++++++++---
>  1 files changed, 74 insertions(+), 6 deletions(-)
> PR[1465] commit 4a81ecd7b95187ddfc0695d04b69efddc5eae368
> Date:   Fri Dec 2 10:54:44 2011 +0100
>  c/src/libchip/network/greth.c |    2 +-
>  1 files changed, 1 insertions(+), 1 deletions(-)
> PR commit be4f8674f3cd1e6f5e6116c5581ac96660eeb136
> Date:   Mon Nov 28 14:04:19 2011 +0100
>     Moved the intelligence whether the driver is supported or not
>     completely to the BSP, now that bsp.h is included (even though it
>     is a driver... hmm). The ERC32 was never supported, so HAS_SMC91111
>     is not added to erc32/include/bsp.h.
>  c/src/lib/libbsp/sparc/leon2/include/bsp.h |    2 ++
>  c/src/lib/libbsp/sparc/leon3/include/bsp.h |    2 ++
>  c/src/libchip/network/smc91111.c           |    4 ++--
>  3 files changed, 6 insertions(+), 2 deletions(-)
> LIST commit cf004f315932dca97b33cf56c0afedfa000e33a7
> Date:   Fri Nov 25 13:11:28 2011 +0100
>  c/src/lib/libbsp/shared/include/irq-generic.h |    2 ++
>  c/src/lib/libbsp/shared/include/irq.h         |    8 ++++++++
>  2 files changed, 10 insertions(+), 0 deletions(-)
> LIST commit 62003f0e8fd23ca91508887e934b2c9f9c885c9d
> Date:   Fri Nov 25 12:11:09 2011 +0100
>  c/src/lib/libbsp/sparc/leon3/startup/spurious.c |    2 +-
> LIST commit dec5e65f707b1a7a4a190464f5f9129bda7e01f7
> Date:   Fri Nov 25 11:17:51 2011 +0100
>     Since the configuration struct is always present one can let
>     DATA initialize it to reduce footprint, at the same time it
>     is made weak to let the user able to configure the SHM driver
>     without editing the driver code.
>  c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c |   10 ++++++----
>  1 files changed, 6 insertions(+), 4 deletions(-)
> LIST commit 5a2482c8839d81fecd8d3e170609e0c253df79bc
> Date:   Thu Oct 13 13:37:45 2011 +0200
>     If bsp_early_malloc() is called early during boot room will be
>     allocated after BSS END. If the function is called after boot
>     is will call malloc() instead. The returned memory is not freeable
>     and always 8-byte aligned.
>     If the bsp_early_malloc() isn't called the function is not
>     dragged in and the workspace will be unmodified in size.
>  c/src/lib/libbsp/sparc/erc32/Makefile.am           |    2 +-
>  c/src/lib/libbsp/sparc/erc32/include/bsp.h         |    3 +
>  c/src/lib/libbsp/sparc/leon2/Makefile.am           |    3 +-
>  c/src/lib/libbsp/sparc/leon2/include/bsp.h         |    3 +
>  c/src/lib/libbsp/sparc/leon3/Makefile.am           |    2 +-
>  c/src/lib/libbsp/sparc/leon3/include/bsp.h         |    3 +
>  c/src/lib/libbsp/sparc/shared/bspgetworkarea.c     |   10 ++++-
>  .../lib/libbsp/sparc/shared/startup/early_malloc.c |   44 ++++++++++++++++++++
>  8 files changed, 65 insertions(+), 5 deletions(-)
> LIST commit 512a080dddbe76b2824b4efdf7219e06fd514935
> Date:   Fri Nov 25 10:08:13 2011 +0100
>     The low level routines can be used in different occasions, it will be
>     required when accessing PCI.
>  c/src/lib/libbsp/sparc/erc32/Makefile.am          |    4 +-
>  c/src/lib/libbsp/sparc/leon2/Makefile.am          |    1 +
>  c/src/lib/libbsp/sparc/leon3/Makefile.am          |    4 +-
>  c/src/lib/libcpu/sparc/Makefile.am                |    7 ++
>  c/src/lib/libcpu/sparc/access/access.S            |   65 ++++++++++++++++++++
>  c/src/lib/libcpu/sparc/access/access_le.c         |   32 ++++++++++
>  c/src/lib/libcpu/sparc/include/libcpu/access.h    |   48 +++++++++++++++
>  c/src/lib/libcpu/sparc/include/libcpu/byteorder.h |   66 +++++++++++++++++++++
>  c/src/lib/libcpu/sparc/preinstall.am              |    8 +++
>  9 files changed, 233 insertions(+), 2 deletions(-)
> rtems-devel mailing list
> rtems-devel at rtems.org
