Removing rtems/contrib/crossrpms
Fri Feb 17 16:08:13 UTC 2012
On Fri, Feb 17, 2012 at 9:27 AM, Ralf Corsepius
<ralf.corsepius at rtems.org> wrote:
> Hi,
> I am going to remove the contrib/crossrpms subdirectory from the rtems
> source-tree into a separate git repository
> git://git.rtems.org/data/git/rtems-crossrpms.git.
Does this mean that the patches necessary for users/developers to
build their own tools will no longer be found in the RTEMS repository?
I'm not sure that I like this change. When the patches are located in
the RTEMS repo it is trivial to figure out how to build tools that
will work for the particular version/snapshot of RTEMS that is being
used. Perhaps this is a non-issue for most, but I have on occasion had
to re-build tools for an out-of-sync RTEMS.
> Rationale: I have been treating crossrpms as a separate sub-project and have
> been using subdirs-checkouts of crossrpms ever since crossrpms had been
> around. The switch to from CVS to git made this use-case tedious to me,
> therefore I decided to move.
> Ralf
> rtems-devel mailing list
> rtems-devel at rtems.org
