Should UID 0 or GID 0 have a special meaning in RTEMS?
Fri Feb 17 16:15:18 UTC 2012
Hello,
I work currently with the RTEMS file system subsystem.  I want to unify the
access checks.  The question is if UID 0 or GID 0 should have a special meaning
in RTEMS?
Do we want this
bool rtems_filesystem_check_access(
   int eval_flags,
   mode_t node_mode,
   uid_t node_uid,
   gid_t node_gid
   mode_t perm_flags = eval_flags & RTEMS_LIBIO_PERMS_RWX;
   uid_t task_uid = geteuid();
   if (task_uid == 0 || task_uid == node_uid) {
     perm_flags <<= 6;
   } else {
     gid_t task_gid = getegid();
     if (task_gid == 0 || task_gid == node_gid) {
       perm_flags <<= 3;
     } else {
       perm_flags <<= 0;
   return (perm_flags & node_mode) == perm_flags;
or this
   int eval_flags,
   mode_t node_mode,
   uid_t node_uid,
   gid_t node_gid
   if (geteuid() == node_uid) {
     perm_flags <<= 6;
   } else if (getegid() == node_gid) {
     perm_flags <<= 3;
   } else {
     perm_flags <<= 0;
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
