Commit messages
Tue Feb 21 15:33:49 UTC 2012
On 02/21/2012 09:05 AM, Ralf Corsepius wrote:
> On 02/20/2012 06:54 PM, Gedare Bloom wrote:
>> On Mon, Jan 23, 2012 at 3:31 AM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de>   wrote:
>>> Hello,
>>> I think we should write down (or copy from somewhere else) some standard for
>>> the commit messages.  How to format it and what to put in it.  Maybe also
>>> some standard phrases.
>> This thread got hijacked. Anyone care to comment on standardizing
>> commit messages, or to say what they have been doing in practice?
> Common practice with RTEMS CVS had been
> - One ChangeLog file per directory containing a "configure.ac"
> This matches with GCC/gdb/binutils/newlib and many other GNU project's
> conventions.
> (For historical reasons, there were some exceptions from this rule in
> RTEMS CVS).
FWIW my personal ChangeLog entries have been written
with the aid of the script rtems-testing/merge-helpers/mkChangeLogList
which follows what Ralf describes with one addition. If there is a PR
associated with the change, it should be noted in the line above the
file name and descriptions as:
\tPR nnnn/category
It also notes which files were added and deleted and has standard
verbage for that case.
> - Each ChangeLog entry was supposed to be formated this way:
> <iso-date>\t<Author>  <email>
> \n
> \t*<relative file name>:<description>.
> Which each line 80 chars at maximum, each description with a terminating
> "dot" and block indented by tabs.
> E.g.
> <snip>
> 2012-02-21	John Doe<jdoe at somewhere.universe.org>
> 	* subdir1/file1.c: Remove xyz.
> 	* subdir2/file2.c: Add xyz.
> 	* subdir3/file3.c: This change  ....
> 	does not want to fit ....
> 	... in a single line.
> </snip>
> This formating is mostly borrowed from GCC/gdb/binutils/newlib, but
> marginally differs from these projects' conventions.
> Ralf
> rtems-devel mailing list
> rtems-devel at rtems.org
Joel Sherrill, Ph.D.             Director of Research&   Development
