Commit messages
Tue Feb 21 20:06:49 UTC 2012
On Tue, Feb 21, 2012 at 1:11 PM, Ralf Corsepius
<ralf.corsepius at rtems.org> wrote:
> On 02/21/2012 05:35 PM, Thomas Doerfler wrote:
>> Hi,
>> just to throw in my two (euro)cents:
>> Am 21.02.2012 16:53, schrieb Joel Sherrill:
>>> But.. we haven't cleaned up from CVS yet.  We are in limbo
>>> right now on ChangeLog's and $Id$'s and we need to settle that.
>>> + Do we remove $Id$'s?
> Well, does git have something comparable? CVS's $Id$'s are helpful when
> people are referring to files from tarballs, e.g. in bug reports.
Unless I'm mistaken the "official" tarballs are just the release
versions right? So I don't see a need to have any redundant versioning
information. Maybe I missed something.
>>> + We haven't decided what to do about the ChangeLog files yet. :)
>>>    - Do they continue to be maintained or not?
>> I would vote YES, but possibly in a different format, if this is
>> suitable for the VCS in use.
> I would vote manually written ChangeLogs in exactly the format we had used.
If we do then we should have some good way to update ChangeLog files
atomically when pushing changes in order to avoid the potential mess
of merging branches--especially long-running development
branches--that contain commits that touch ChangeLog files.
>> Having a detailed history of changes is
>> useful in many maintenance cases and we should provide that information
>> even for those users working with tarballs instead of direkt GIT access.
> Exactly. You can not expect users to have git access.
>>>    - If not, then they need to be renamed. It is confusing to users.
>> Archiving the CVS-based Changelogs in place with a suitable name (like
>> "Changelog.pre2012") makes sense IMHO.
> IMO, it does not make sense. We should continue to provide them as before,
> may-be splitting some overly large ones into ChangeLog.<year> or similar
> (This is what GCC does).
I think it makes sense to rename/archive them as a natural phase of
the change to git. For users trying to find what changed during the
4.11 release cycle, however, it will complicate matters.
>>>    - If we don't manually maintain them but want to keep them, then an
>>>      automated update needs to occur on every commit. Given the
>>> ChangeLog's
>>>      are scattered through the tree, if we do this, the script will have
>>> to update
>>>      the appropriate ChangeLogs.
>> The current location of ChangeLog files seems quite artifical to me.
> It isn't artificial.
> Each of these ChangeLogs corresponds to a _subpackage_, which can be
> relocated to a different location with fairly small amounts of works.
>> Ralf's explanation, that they are at the same nodes as the configure.ac
>> seems artifical to me either.
> Again, no. Each configure.ac makes them a _subpackage_ auto*tool-wise.
> Think about BSPs. Your users will really want a per-BSP ChangeLog and not a
> monolytic toplevel ChangeLog containing all changes of everything.
I think it is a nice idea to consider more arguments than
autotool-dependent subpackages: what if autotools goes away, then what
is the reasoning behind our placement of ChangeLogs? Do we really need
ChangeLogs in (just to pick one) ./doc/tools/bmenu/?
You deleted what Thomas said about placing the ChangeLog files, which
includes per-BSP. Here I will reprint it and add a few more:
- rtems/
- rtems/c/src/lib/libbsp/
- rtems/c/src/lib/libbsp/<arch>/<bsp>/
- rtems/c/src/lib/libcpu/<arch>
- rtems/c/src/libchip/
- rtems/cpukit/
- rtems/testsuites/
AND
- rtems/cpukit/score/cpu/<arch>/
- rtems/c/src/
- rtems/doc
- rtems/tools
> Ralf
> rtems-devel mailing list
> rtems-devel at rtems.org
