[Bug 2030] New: Export more shell functions
Sat Feb 25 18:46:54 UTC 2012
On my phone without code access but I think all shell command entry points can be static but the structure that is used by shellconfig.h must not be static.
Shell helper methods like make args and others to invoke a script or initialize the shell must be public.
The exception would be a case where you might invoke a shell commands main method directly and I don't know of these.
Or where one command wraps or uses another.
--joel
Gedare Bloom <gedare at rtems.org> wrote:
>Ralf,
>On Fri, Feb 24, 2012 at 4:36 PM,  <bugzilla-daemon at rtems.org> wrote:
>> https://www.rtems.org/bugzilla/show_bug.cgi?id=2030
>>             Bug #: 2030
>>           Summary: Export more shell functions
>>    Classification: Unclassified
>>           Product: RTEMS
>>           Version: HEAD
>>          Platform: All
>>        OS/Version: RTEMS
>>            Status: NEW
>>          Severity: normal
>>          Priority: P3
>>         Component: cpukit
>>        AssignedTo: joel.sherrill at oarcorp.com
>>        ReportedBy: sebastien at milkymist.org
>> Created attachment 1445
>>  --> https://www.rtems.org/bugzilla/attachment.cgi?id=1445
>> patch
>> Export rtems_shell_init_env, rtems_shell_env_free, rtems_shell_main_mv,
>> rtems_shell_main_cp and rtems_shell_main_rm
>I think you changed these (at least the mv one) to be static recently.
>Is this change acceptable?
>> Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
>> ------- You are receiving this mail because: -------
>> You are watching all bug changes.
>> rtems-bugs mailing list
>> rtems-bugs at rtems.org
>> http://rtems.org/mailman/listinfo/rtems-bugs
>rtems-devel mailing list
>rtems-devel at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-devel
