[PR 06] LEON3: change d-cache snoop detect implementation
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 2 14:46:27 UTC 2012
The previous code only checked if d-cache snooping was implemented,
however snooping may be available but not enabled which may lead
to driver bugs.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
c/src/lib/libbsp/sparc/leon3/startup/bspstart.c | 10 +++++-----
1 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
index 82054e8..c712f84 100644
--- a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
+++ b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
@@ -36,19 +36,19 @@ extern void amba_initialize(void);
* set_snooping
* Read the data cache configuration register to determine if
- * bus snooping is available. This is needed for some drivers so
- * that they can select the most efficient copy routines.
+ * bus snooping is available and enabled. This is needed for some
+ * drivers so that they can select the most efficient copy routines.
static inline int set_snooping(void)
int tmp;
- __asm__ (" lda [%1] 2, %0 "
+ __asm__ (" lda [%%g0] 2, %0 "
: "=r"(tmp)
- : "r"(0xC)
- return (tmp >> 27) & 1;
+ return (tmp >> 23) & 1;
/* ASM-function used to get the CPU-Index on calling LEON3 CPUs */
1.7.0.4
