[PATCH 09] bootstrap: handy --root switch for bootstrapping subdirs
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 2 14:46:30 UTC 2012
Use the "--root DIR" to process only a subdir, for example
$ ./bootstrap --root c/src/lib/libbsp/sparc
will only generate Makefiles for all SPARC BSPs, saves some
time when working with a specific BSP.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
bootstrap | 10 +++++++---
1 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/bootstrap b/bootstrap
index 1a2a424..472416d 100755
--- a/bootstrap
+++ b/bootstrap
@@ -18,6 +18,7 @@ top_srcdir=`dirname $0`
verbose="";
quiet="false"
mode="autoreconf"
+root=.
usage()
@@ -92,6 +93,9 @@ case $1 in
-g|--ge|--gen|--gene|--gener|--genera|--generat|--generate)
mode="generate";
shift;;
+--root)
+ root=$2;
+ shift 2;;
-*) echo "unknown option $1" ;
usage ;;
*) echo "invalid parameter $1" ;
@@ -101,7 +105,7 @@ done
case $mode in
preinstall)
- confs=`find . -name Makefile.am -exec grep -l 'include .*/preinstall\.am' {} \;`
+ confs=`find $root -name Makefile.am -exec grep -l 'include .*/preinstall\.am' {} \;`
for i in $confs; do
dir=$(dirname $i);
test "$quite" = "true" || echo "Generating $dir/preinstall.am"
@@ -141,7 +145,7 @@ generate)
esac
- confs=`find . \( -name 'configure.in' -o -name 'configure.ac' \) -print`
+ confs=`find $root \( -name 'configure.in' -o -name 'configure.ac' \) -print`
for i in $confs; do
dir=`dirname $i`;
configure=`basename $i`;
@@ -173,7 +177,7 @@ autoreconf)
exit 1
fi
- confs=`find . -name 'configure.ac' -print`
+ confs=`find . -name 'configure.ac' -print $maxdepth`
for i in $confs; do
dir=`dirname $i`;
1.7.0.4
