[PR 05] LEON3: CPU index intialization moved to bspstart.c
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 2 15:50:55 UTC 2012
On 02/02/2012 04:45 PM, Gedare Bloom wrote:
> On Thu, Feb 2, 2012 at 9:46 AM, Daniel Hellstrom<daniel at gaisler.com> wrote:
>> All LEON3/4 systems have a CPU-id, if on a single-CPU system the
>> ID is always zero. On a multicore system it ranges from 0 to 15.
>> The CPU index should always by updated even in a non-MP RTEMS OS
>> since the CPU running RTEMS may not always be CPU0. For example
>> when RTEMS runs on CPU1 and Linux on CPU0 in a mixed ASMP system.
>> The old code executed within the IRQ controller initialization code
>> makes no sense since the ASR register is a CPU register, it has
>> nothing to do with AMBA initialization either.
>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>> c/src/lib/libbsp/sparc/leon3/amba/amba.c | 18 ------------------
>> c/src/lib/libbsp/sparc/leon3/startup/bspstart.c | 18 ++++++++++++++++++
>> 2 files changed, 18 insertions(+), 18 deletions(-)
>> diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>> index 1932cee..b0a43f9 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>> @@ -21,8 +21,6 @@ amba_confarea_type amba_conf;
>> /* Pointers to Interrupt Controller configuration registers */
>> volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;
>> -int LEON3_Cpu_Index = 0;
>> * amba_initialize
>> @@ -33,16 +31,6 @@ int LEON3_Cpu_Index = 0;
>> * amba_ahb_masters, amba_ahb_slaves and amba.
>> -unsigned int getasr17(void);
>> -__asm__ (" .text \n"
>> - "getasr17: \n"
>> - "retl \n"
>> - "mov %asr17, %o0\n"
>> -extern rtems_configuration_table Configuration;
>> extern int scan_uarts(void);
>> void amba_initialize(void)
>> @@ -58,12 +46,6 @@ void amba_initialize(void)
>> if ( i> 0 ){
>> /* Found APB IRQ_MP Interrupt Controller */
>> LEON3_IrqCtrl_Regs = (volatile LEON3_IrqCtrl_Regs_Map *) dev.start;
>> -#if defined(RTEMS_MULTIPROCESSING)
>> - if (rtems_configuration_get_user_multiprocessing_table() != NULL) {
>> - unsigned int tmp = getasr17();
>> - LEON3_Cpu_Index = (tmp>> 28)& 3;
>> -#endif
>> /* find GP Timer */
>> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>> index a4b9ffa..82054e8 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>> @@ -27,6 +27,9 @@
>> int CPU_SPARC_HAS_SNOOPING;
>> +/* Index of CPU, in an AMP system CPU-index may be non-zero */
>> +int LEON3_Cpu_Index = 0;
>> extern void amba_initialize(void);
>> @@ -48,6 +51,14 @@ static inline int set_snooping(void)
>> return (tmp>> 27)& 1;
>> +/* ASM-function used to get the CPU-Index on calling LEON3 CPUs */
>> +static inline unsigned int get_asr17(void)
>> + unsigned int reg;
>> + __asm__ (" mov %%asr17, %0 " : "=r"(reg) :);
>> + return reg;
> Might get_asr17 make sense as a function defined by
> cpukit/score/cpu/sparc/rtems/score/sparc.h? Or is it really only
> useful for getting the cpu index as used below?
>> * bsp_start
>> @@ -57,6 +68,13 @@ void bsp_start( void )
>> CPU_SPARC_HAS_SNOOPING = set_snooping();
>> + /* Get the LEON3 CPU index, normally 0, but for MP systems we do
>> + * _not_ assume that this is CPU0. One may run another OS on CPU0
>> + * and RTEMS on this CPU, and AMP system with mixed operating
>> + * systems
>> + LEON3_Cpu_Index = (get_asr17()>> 28)& 3;
> Would it make sense to also define something like
> sparc_get_cpu_index()? Or does it only ever need to be done during bsp
> initialization?
Yes, that makes sens, but perhaps in a separate "clean patch" for HEAD? This is the way the code was code first time:
>> /* Find UARTs */
>> amba_initialize();
>> 1.7.0.4
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
