AG patches chunk A
Daniel Hellstrom daniel at gaisler.com
Thu Feb 2 17:04:55 UTC 2012
On 02/02/2012 04:31 PM, Daniel Hellstrom wrote:
> On 02/02/2012 03:54 PM, Joel Sherrill wrote:
>> On 02/02/2012 08:39 AM, Daniel Hellstrom wrote:
>>> Hello,
>>> I summarize the first chunk of patches, PATCH means I will send them on the rtems-devel list, PR means I will file a bugzilla PR. Feel free to comment.. and apply :)
>> I am putting my first thought on whether or not a PR is required.
>> Correct me if I am wrong.
>>> Patches are listed in reverse apply order, thus IO_MANAGER patch comes last.
>>> Thanks,
>>> Daniel
>>> + SPARC specific enhancements
>>>       c1afe98 LEON3: fix compiler warning in SHM driver
>> This sounds like an easy one to review. Probably completely
>> benign and applies to 4.10 branch. Bugzilla.
> one-line patch. Ok will add to bugzilla shortly.
BUG 2008
>>> + SPARC specific bugs
>>>       3e2aa5e LEON3BSP MP: may wake one more CPU than expected
>> Head only.
> Ok, was a big quick here, was given BUG 2006. Is a bug though. Please terminate it.
closed OK.
>>>       fe9dc9e SPARC BSPs: workspace must be aligned on a 8-byte boundary
>> Bugzilla.
> BUG 2007
dropped closed OK.
>>>       124e68d LEON3: CPU index intialization moved to bspstart.c
>> I thought head but I read your description. This sounds like
>> a bug fix to include in 4.10.
> Yes a bug, however only on AMP systems. Will file a PR shortly.
BUG 2009
>>>       c7d92b6 LEON3: change d-cache snoop detect implementation
>> Your description below makes this sound like it is a bug which
>> needs to be a Bugzilla PR so it can be in a 4.10 release.
> I think it is a bug, especially on a LEON3 UT699 where snooping is implemented but can not be enabled. Will file PR.
BUG 2010
>>>       LEON specific because GRETH driver only used by LEON:
>>>       7a92dba GRETH: Moved print to remove potential deadlock
>>>       6c66b13 GRETH: performance improvements and one bugfix
>> Treat as one PR in Bugzilla.
> Ok. Will add two patches in same PR.
BUG 2011
>>> + General bugs, (but not in any release, so PR not filed)
>>>       839ef7b MP06 TEST: avoid program failure when slow UART on CPU core 0
>> How is this not in a release?
> Ok, sorry I thought the MP tests will be released first in RTEMS-4.11. This patch need reviewing.
Should we leave this for now, and investigate a cleaner patch?
Thanks,
Daniel
>>> + General enhancements
>>>       fe2ee40 bootstrap: handy --root switch for bootstrapping subdirs
>>>       11ae399 IO_MANAGER: early dynamic driver registration
>> Definitely through devel.
> Patches sent onto list as 09 and 10.
> Thanks,
> Daniel
>>> PATCH commit 8713dbeead0fb5ce880793ef391916cc422efce5
>>> Author: Daniel Hellstrom<daniel at gaisler.com>
>>> Date:   Thu Nov 24 16:54:28 2011 +0100
>>>       Adds the possibility to register drivers before the IO Manager has
>>>       completed the initialization. Sometimes the BSP may want to register
>>>       a driver dynamically early in the boot process.
>>>       Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>>> PATCH commit b2a54a1af400bf731855fe26c8c4550a7cc0697b
>>> Date:   Fri Nov 25 13:58:07 2011 +0100
>>>       Use the "--root DIR" to process only a subdir, for example
>>>        $ ./bootstrap --root c/src/lib/libbsp/sparc
>>>       will only generate Makefiles for all SPARC BSPs, saves some
>>>       time when working with a specific BSP.
>>> PR commit 6c66b134e18dc24b3fe8b2d9a9a6954c6bc6840e
>>> Date:   Fri Dec 2 10:47:58 2011 +0100
>>>       GRETH driver updated, 10-15% performance improvements for GBIT MAC,
>>>       unnecessary RX interrupts not taken which under heavy load saves approx.
>>>       1500 interrupts/s, one task removed saving about 5kb memory and 1 bug
>>>       solved.
>>>       BUG: RX interrupt was enabled before the RX-daemon was created which could
>>>       result in a faulty call to rtems_event_send.
>>> PR commit 7a92dba76fa113ab9fba1ddc90a2578ea8ff8d0a
>>> Date:   Fri Dec 2 10:45:10 2011 +0100
>>>       Deadlock may arise when the EDCL bug link is used to tunnel
>>>       console output over Ethernet, when Ethernet is down one should
>>>       avoid using console (only during debugging of LEON targets)
>>>       Author: Marko Isomaki<marko at gaisler.com>
>>> PR[DEP-1] commit c7d92b6562014f85a29bd94ceb2c3292f36dfb32
>>> Date:   Fri Nov 25 14:02:00 2011 +0100
>>>       The previous code only checked if d-cache snooping was implemented,
>>>       however snooping may be available but not enabled which may lead
>>>       to driver bugs.
>>> PR commit 124e68d114f1ae6489ee86167357e6b6b16503e5
>>> Date:   Fri Nov 25 14:15:16 2011 +0100
>>>       All LEON3/4 systems have a CPU-id, if on a single-CPU system the
>>>       ID is always zero. On a multicore system it ranges from 0 to 15.
>>>       The CPU index should always by updated even in a non-MP RTEMS OS
>>>       since the CPU running RTEMS may not always be CPU0. For example
>>>       when RTEMS runs on CPU1 and Linux on CPU0 in a mixed ASMP system.
>>>       The old code executed within the IRQ controller initialization code
>>>       makes no sense since the ASR register is a CPU register, it has
>>>       nothing to do with AMBA initialization either.
>>> PATCH commit 839ef7ba191dc65ecbb777bbd108758025259d34
>>> Date:   Wed Nov 16 16:56:46 2011 +0100
>>> PR commit fe9dc9e1a55c1e71980eaa290f193cdae79141ca
>>> Date:   Fri Nov 25 10:54:28 2011 +0100
>>>       The linker-script already declares a 8-byte aligned symbol (_end)
>>>       which can be used instead of "variable aligned" symbol end.
>>> PR commit 3e2aa5ed2415ff02dac7545930f0a07c546dac77
>>> Date:   Wed Nov 9 16:09:55 2011 +0100
>>>       The SHM code always wakes one CPU more that configured, however
>>>       this has never been a problem since RTEMS will be running on all CPUs
>>>       or only two cores were available.
>>> PATCH commit c1afe981bf63c79f695b6ff826c5109a9f7f1dd7
>>> Date:   Fri Nov 25 11:33:11 2011 +0100
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
