[PATCH 12] SPARC BSPs: bsp_early_malloc() routine for startup memory allocation
Daniel Hellstrom
daniel at gaisler.com
Mon Feb 6 14:15:45 UTC 2012
If bsp_early_malloc() is called early during boot room will be
allocated after BSS END. If the function is called after boot
is will call malloc() instead. The returned memory is not freeable
and always 8-byte aligned.
If the bsp_early_malloc() isn't called the function is not
dragged in and the workspace will be unmodified in size.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
c/src/lib/libbsp/sparc/erc32/Makefile.am | 2 +-
c/src/lib/libbsp/sparc/erc32/include/bsp.h | 3 +
c/src/lib/libbsp/sparc/leon2/Makefile.am | 3 +-
c/src/lib/libbsp/sparc/leon2/include/bsp.h | 3 +
c/src/lib/libbsp/sparc/leon3/Makefile.am | 2 +-
c/src/lib/libbsp/sparc/leon3/include/bsp.h | 3 +
c/src/lib/libbsp/sparc/shared/bspgetworkarea.c | 10 ++++-
.../lib/libbsp/sparc/shared/startup/early_malloc.c | 44 ++++++++++++++++++++
8 files changed, 65 insertions(+), 5 deletions(-)
create mode 100644 c/src/lib/libbsp/sparc/shared/startup/early_malloc.c
diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
index cecfe14..e70310d 100644
--- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
+++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
@@ -38,7 +38,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
../../shared/bspstart.c ../../shared/bootcard.c ../../shared/bspinit.c \
../../shared/sbrk.c startup/setvec.c startup/spurious.c \
startup/erc32mec.c startup/boardinit.S startup/bspidle.c \
- startup/bspdelay.c
+ startup/bspdelay.c ../../sparc/shared/startup/early_malloc.c
# ISR Handler
libbsp_a_SOURCES += ../../sparc/shared/irq_asm.S
# gnatsupp
diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
index 8655732..8075e8e 100644
--- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
@@ -81,6 +81,9 @@ void BSP_fatal_return( void );
void bsp_spurious_initialize( void );
+/* Allocate 8-byte aligned non-freeable pre-malloc memory */
+void *bsp_early_malloc(int size);
#ifdef __cplusplus
#endif
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 9df3c7d..6e2697f 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -55,7 +55,8 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
startup/bspstart.c ../../sparc/shared/bsppretaskinghook.c \
../../sparc/shared/bspgetworkarea.c ../../shared/bootcard.c \
../../shared/sbrk.c startup/setvec.c startup/spurious.c startup/bspidle.c \
- ../../shared/bspinit.c startup/bspdelay.c
+ ../../shared/bspinit.c startup/bspdelay.c \
+ ../../sparc/shared/startup/early_malloc.c
# ISR Handler
# gnatsupp
diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
index 34e31ce..b0695cb 100644
--- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
@@ -94,6 +94,9 @@ void BSP_fatal_return( void );
#ifdef __cplusplus
#endif
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 8eae306..dc24051 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
../../sparc/shared/bsppretaskinghook.c ../../shared/bsppredriverhook.c \
../../sparc/shared/bspgetworkarea.c ../../shared/sbrk.c startup/setvec.c \
startup/spurious.c startup/bspidle.S startup/bspdelay.c \
+ ../../shared/bspinit.c ../../sparc/shared/startup/early_malloc.c
# ISR Handler
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index 89b36d4..70ab8b3 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
@@ -104,6 +104,9 @@ void BSP_fatal_return( void );
#ifdef __cplusplus
#endif
diff --git a/c/src/lib/libbsp/sparc/shared/bspgetworkarea.c b/c/src/lib/libbsp/sparc/shared/bspgetworkarea.c
index c6e1491..580a911 100644
--- a/c/src/lib/libbsp/sparc/shared/bspgetworkarea.c
+++ b/c/src/lib/libbsp/sparc/shared/bspgetworkarea.c
@@ -22,6 +22,9 @@
/* Tells us where to put the workspace in case remote debugger is present. */
extern uint32_t rdb_start;
+/* Must be aligned to 8, _end is aligned to 8 */
+unsigned int early_mem = (unsigned int)&end;
* This method returns the base address and size of the area which
* is to be allocated between the RTEMS Workspace and the C Program
@@ -37,8 +40,11 @@ void bsp_get_work_area(
/* must be identical to STACK_SIZE in start.S */
#define STACK_SIZE (16 * 1024)
- *work_area_start = &end;
- *work_area_size = (void *)rdb_start - (void *)&end - STACK_SIZE;
+ /* Early dynamic memory allocator is placed just above _end */
+ *work_area_start = (void *)early_mem;
+ *work_area_size = (void *)rdb_start - (void *)early_mem - STACK_SIZE;
+ early_mem = ~0; /* Signal bsp_early_malloc not to be used anymore */
*heap_start = BSP_BOOTCARD_HEAP_USES_WORK_AREA;
*heap_size = BSP_BOOTCARD_HEAP_SIZE_DEFAULT;
diff --git a/c/src/lib/libbsp/sparc/shared/startup/early_malloc.c b/c/src/lib/libbsp/sparc/shared/startup/early_malloc.c
new file mode 100644
index 0000000..c6abaca
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/startup/early_malloc.c
@@ -0,0 +1,44 @@
+ * Early dynamic memory allocation (not freeable) for BSP
+ * boot routines. Minimum alignment 8 bytes. Memory is
+ * allocated after _end, it will shrink the workspace.
+ * COPYRIGHT (c) 2011.
+ * Aeroflex Gaisler AB
+ * http://www.rtems.com/license/LICENSE.
+ * $Id: early_malloc.c
+#include <bsp.h>
+#include <stdlib.h>
+/* Tells us where to put the workspace in case remote debugger is present. */
+extern uint32_t rdb_start;
+/* Must be aligned to 8 */
+extern unsigned int early_mem;
+/* must be identical to STACK_SIZE in start.S */
+#define STACK_SIZE (16 * 1024)
+ void *start;
+ /* Not early anymore? */
+ if (early_mem == ~0)
+ return malloc(size);
+ size = (size + 7) & ~0x7;
+ if (rdb_start - STACK_SIZE - early_mem < size)
+ return NULL;
+ start = (void *)early_mem;
+ early_mem += size;
+ return start;
1.7.0.4
