Gsoc 2012 project
Tue Feb 7 23:54:53 UTC 2012
On 8/02/12 1:34 AM, yangwei weiyang wrote:
> Hi all:
>      From the mail of Joel I know that the Google summer of code 2012 is
> going to start and RTEMS will be absolutely a member of organizations.
> There are lots of projects i am interested in from the Wiki open project
> section. The most favorite one for me is "Bus Space API". So i want to
> know as much information as possible.
Thanks for looking.
>      First i have read "Bus Space API" section carefully at the Wiki,
> And also know some basic backgroud through the IRC log. The bus_space
> API is originally from NetBSD, its goal is to allow a single driver
> source file to manipulate a set of devices on different system
> architectures, and to allow a single driver object file to manipulate a
> set of devices on multiple bus types on a single architecture. It is
> implemented in the BSP layer and the architecture layer, that  means
> different architecture and machine must implement its own bus space type
> and
> functions. But the goal of "Bus Space API" project is to easing the
> ports of BSD drivers to RTEMS, so in order to realize its goal, should
> we port bus_space API to RTEMS BSP layer and architecture layer or adapt
> the bus_space API in the RTEMS score which make BSP layer and
> architecture layer unchanged or changed minimum?
>      So i want to know more information about this project, are there
> some protential mentors to help me?
The bus space project is complex and I suspect beyond the scope of GSoC
from past experience. The issue is the way it needs to be embedded into
the score and the RTEMS name-space then mapped to the BSD API with a low
overhead.
I understand there is work being done on this project how-ever I think
the work is limited to a couple of architectures. I do not know the
timeline for this work, how-ever if it was in the master repo by the
time GSoC started there would be projects to add support for those
architectures not added in the first pass.
