[rtems commit] Check that the file offset is valid after a seek
Sebastian Huber
Fri Feb 10 21:46:50 UTC 2012
The lseek and truncate mechanic is completely broken (just look at the
fstests). This patch is not sufficient and it is work in progress.
On 10/02/12 19:33, Joel Sherrill wrote:
> This looks like something that should also be on the 4.10 branch
> with a PR.
> What do you think?
> --joel
> On 02/09/2012 04:08 AM, Sebastian Huber wrote:
>> Module: rtems
>> Branch: master
>> Commit: e303adf4445919d4d87e8467854c404f9bd0d076
>> Changeset:
>> http://git.rtems.org/rtems/commit/?id=e303adf4445919d4d87e8467854c404f9bd0d076
>> Author: Sebastian Huber<sebastian.huber at embedded-brains.de>
>> Date: Thu Feb 9 10:53:16 2012 +0100
>> cpukit/libfs/src/dosfs/msdos_dir.c | 18 ++++--------------
>> cpukit/libfs/src/dosfs/msdos_file.c | 4 ++++
>> 2 files changed, 8 insertions(+), 14 deletions(-)
>> diff --git a/cpukit/libfs/src/dosfs/msdos_dir.c
>> b/cpukit/libfs/src/dosfs/msdos_dir.c
>> index 9a8ed1e..a0ef507 100644
>> --- a/cpukit/libfs/src/dosfs/msdos_dir.c
>> +++ b/cpukit/libfs/src/dosfs/msdos_dir.c
>> @@ -500,21 +500,11 @@ msdos_dir_read(rtems_libio_t *iop, void
>> *buffer, size_t count)
>> off_t
>> msdos_dir_lseek(rtems_libio_t *iop, off_t offset, int whence)
>> - switch (whence)
>> - case SEEK_SET:
>> - case SEEK_CUR:
>> - break;
>> - * Movement past the end of the directory via lseek is not a
>> - * permitted operation
>> - case SEEK_END:
>> - default:
>> - rtems_set_errno_and_return_minus_one( EINVAL );
>> - break;
>> + if (iop->offset>= 0&& iop->offset<= iop->size) {
>> + return 0;
>> + } else {
>> + rtems_set_errno_and_return_minus_one(EINVAL);
>> - return RC_OK;
>> /* msdos_dir_stat --
>> diff --git a/cpukit/libfs/src/dosfs/msdos_file.c
>> b/cpukit/libfs/src/dosfs/msdos_file.c
>> index b0eeba9..5378a25 100644
>> --- a/cpukit/libfs/src/dosfs/msdos_file.c
>> +++ b/cpukit/libfs/src/dosfs/msdos_file.c
>> @@ -231,6 +231,10 @@ msdos_file_lseek(rtems_libio_t *iop, off_t
>> offset, int whence)
>> fat_file_fd_t *fat_fd = iop->pathinfo.node_access;
>> uint32_t real_size = 0;
>> + if (iop->offset< 0 || iop->offset> UINT32_MAX) {
>> sc = rtems_semaphore_obtain(fs_info->vol_sema, RTEMS_WAIT,
>> MSDOS_VOLUME_SEMAPHORE_TIMEOUT);
>> if (sc != RTEMS_SUCCESSFUL)
>> rtems-vc mailing list
>> rtems-vc at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-vc
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
