Please avoid merge commits
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Feb 23 19:03:59 UTC 2012
On 02/23/2012 12:43 PM, Cláudio Silva wrote:
> Hi,
>> On 02/23/2012 11:40 AM, Sebastian Huber wrote:
>>> Hello,
>>> please rebase your work to the current branch head and avoid merge commits
>>> like
>>> this:
>>> http://git.rtems.org/rtems/commit/?id=8f7f6caaef26f9067aeb2feaa85a2d50c0853ba8
>> This is my fault. I passed along a command sequence to Jennifer.
>>> This makes browsing the history quite painful.
>> Agreed.
>>> git rebase --help
>> The command sequence which is doing this is from
>> the wiki http://wiki.rtems.org/wiki/index.php/RTEMS_GIT_Repository
>> Section 5.2.3 Update from upstream master (RTEMS head)
>> # git fetch upstream
>> # git merge upstream/master
>> Should the merge command be dropped? Or is the proper
>> sequence this?
>> # git rebase upstream/master
>> Advice appreciated. We need to make sure that the instructions
>> are right and that I am properly retrained. :)
> # git checkout master
> You can use this command sequence to update your local master branch
> when you have no changes in it (it is the same as a git pull).
> When you have changes and you want to propagate them upstream: (if you
> have those changes on a separate branch)
> # git checkout new_features
> # git push upstream new_features:master
> If those new commits are in your local master (this is -not- very advisable):
> # git checkout master (if you are not already in master)
> # git push upstream master:master
> You can also replace the git rebase with "git rebase --interactive".
> An interactive rebase allows you to edit commit messages, squash
> commits together or ignore them.
Thanks Claudio! New tools and new things to learn.
And new mistakes to make.
> Regards,
> Cláudio
Joel Sherrill, Ph.D. Director of Research& Development
