gcc-4.7 fails to build rtems-4.11/gcc-4.6
Ralf Corsepius ralf.corsepius at rtems.org
Tue Jan 24 09:25:53 UTC 2012
Hi,
When rebuilding the rtems-4.11 toolchains for Fedora 17/rawhide,
I tripped over a pretty nasty bug in gcc-4.6:
http://gcc.gnu.org/ml/gcc/2012-01/msg00292.html
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=51969
This affects all gcc-4.6-based RTEMS-4.11 toolchains (i.e. all targets
but the lm32).
On the positive side
- a work-around is known (c.f. GCC BZ 51969)
- This bug only shows when using a gcc-4.7 based native GCC
   to build gcc-4.6.x-based toolchains.
I am going to adopt the work-around to the rtems-gcc-4.6.2 patches.
Ralf
