Eliminate $Id:$
Ralf Corsepius
ralf.corsepius at rtems.org
Tue Jan 17 04:12:17 UTC 2012
On 01/17/2012 04:27 AM, Joel Sherrill wrote:
> I have some work from the flight to purge cvs refrences in files but nothing for Id strings. One bsp prints like $Name or something.
> All cvsignore files need to be renamed gitignore.
Again, no - This only works in trivial cases, but is wrong in general.
cvsignores and gitignores use a different syntax and are incompatible.
That said, a single toplevel .gitignore can replace a whole CVS source
tree's .cvsignore hierarchy.
In other words, you will want to
find .cvsignore | xargs git rm
and write a toplevel .gitignore
But more important than discussing these details: When will OAR's
rtems.git finally go online and be fully operational?
Ralf
