the problem about qemu run i386 rtems bsp
yangwei weiyang
wei.a.yang at gmail.com
Mon Jul 2 15:48:13 UTC 2012
Hi all,
When i use rtems-testing repository sim-scripts/pc386 to run pcp4 bsp,
it show the blow result:
./sim-scripts/pc386 -i
../rtems-build/i386-rtems4.11/c/pcp4/testsuites/samples/hello/hello.exe
qemu is /sdb1/gsoc2012/github/qemu-install/bin/qemu
Could not open option rom 'sgabios.bin': No such file or directory
And then there is not any output. Anyone know this issue?
The follow step is what i do:
1. git clone rtems-testing.git
2. build rtems with the configuration:
../rtems/configure --target=i386-rtems4.11
--prefix=/sdb1/gsoc2012/github/rtems-install --enable-smp
--enable-tests=yes --enable-rtemsbsp=pcp4 USE_COM1_AS_CONSOLE=1
BSP_PRESS_KEY_FOR_RESET=0
3. ./sim-scripts/pc386 -i
../rtems-build/i386-rtems4.11/c/pcp4/testsuites/samples/hello/hello.exe.
And then it shows: CANNOT FIND qemu or qemu-system-i386.
4 And then i build qemu for i386. Then run the command step 3 then it
shows the log in the head of mail.
Wei Yang
Best Regards
