[GSOC] How to fix this error?
Mon Jul 2 17:45:46 UTC 2012
On 07/02/2012 12:42 PM, Xiaochen Pan wrote:
> Hello,
> When cmockery compiled under RTEMS, this error occurs: "undefined reference to signal". Which header file should 'signal' be defined under RTEMS library?
Did you build with --disable-posix?
> regards,
> xiaochen
> rtems-devel mailing list
> rtems-devel at rtems.org
Joel Sherrill, Ph.D.             Director of Research&   Development
