[GSoC] Arm Simulators problem.
Hesham Moustafa heshamelmatary at gmail.com
Tue Jul 3 09:56:03 UTC 2012
Hi,
When i run hello.exe sample with gdb or any simulator ( whether at
rtems-testing/sim-script or not ),
The program output that and i got nothing.
hesham at Hesham-Laptop sim-scripts$ qemu-gumstix
/home/hesham/gumstix/arm-rtems4.11/c/gumstix/testsuites/samples/hello/hello.exe
qemu-system-arm is /usr/bin/qemu-system-arm
running
for maximum 60 seconds...
Other simulators outputs connection time out.
Note that i have enables test when configuring rtems for building with
--enable-tests.
I have build the following BSPs for ARM and test hello.exe with gdb and
simulator and i got the same result.
edb7312
csb337
gumstix
lm3s69xx
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120703/52e39855/attachment.html>
