disable thread dispatch problem
Ashi
ashi08104 at gmail.com
Mon Jul 9 06:28:38 UTC 2012
2012/7/6 Sebastian Huber <sebastian.huber at embedded-brains.de>
> On 07/06/2012 11:49 AM, Ashi wrote:
>> I've a problem of _Thread_Disable_dispatch() function in below code. It's
>> my
>> implementation of _POSIX_Keys_Run_destructors() function. I come across
>> the
>> problem when I run the psxkey03 test:if _Thread_Disable_dispatch() was
>> commented out, psxkey03 can run without problem. when
>> _Thread_Disable_dispatch() added at line 1(as below), psxkey03 will fail.
>> I
>> debug it in sparc-rtems4.11-gdb, and find psxkey03 runs into
>> _Internal_error_Occurred() function then stop. I know
>> _POSIX_Keys_Get()(at line
>> 12) will also disable thread dispatch--does this lead to the problem?
>> However,
>> can't figure out where exactly the problem exists, could anyone explain
>> it? Thanks!
> The _Thread_Disable_dispatch() can nest. I suppose you want to acquire a
> resource in the destructor which is not free. The path to
> _Internal_error_Occurred() should show the problem.
> Sebastian, I follow the calls in gdb, and find the error is:
Program received signal SIGINT, Interrupt.
0x020168b8 in _Internal_error_Occurred (the_source=INTERNAL_ERROR_CORE,
is_internal=true, the_error=5)
at ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:58
58 _CPU_Fatal_halt( the_error );
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-devel mailing list
> rtems-devel at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
Best wishes!
Zhongwei Yao
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120709/cabb9100/attachment.html>
