disable thread dispatch problem
Ashi
ashi08104 at gmail.com
Mon Jul 9 06:28:51 UTC 2012
2012/7/6 Joel Sherrill <joel.sherrill at oarcorp.com>
> On 07/06/2012 04:49 AM, Ashi wrote:
>> Hi, all.
>> I've a problem of _Thread_Disable_dispatch() function in below code. It's
>> my implementation of _POSIX_Keys_Run_destructors() function. I come across
>> the problem when I run the psxkey03 test:if _Thread_Disable_dispatch() was
>> commented out, psxkey03 can run without problem. when
>> _Thread_Disable_dispatch() added at line 1(as below), psxkey03 will fail. I
>> debug it in sparc-rtems4.11-gdb, and find psxkey03 runs into
>> _Internal_error_Occurred() function then stop. I know _POSIX_Keys_Get()(at
>> line 12) will also disable thread dispatch--does this lead to the problem?
>> However, can't figure out where exactly the problem exists, could anyone
>> explain it? Thanks!
> This call chain goes back to score/src/threadclose.c and this section of
> code.
> * We assume the Allocator Mutex is locked when we get here.
> * This provides sufficient protection to let the user extensions
> * run but as soon as we get back, we will make the thread
> * disappear and set a transient state on it. So we temporarily
> * unnest dispatching.
> _Thread_Unnest_dispatch();
> _User_extensions_Thread_**delete( the_thread );
> **** you are called in this state ***
> - mutex allocator locked
> - dispatching disabled (level = 1)
> I find the mutex allocator's work is protection for all memory allocations
and deallocations, does it mean I can't call _Workspace_Free at line 17?
>> 1 _Thread_Disable_dispatch();
>> 2 chain = &((POSIX_API_Control *)thread->API_Extensions[
>> THREAD_API_POSIX ])->the_chain;
>> 3 iter = _Chain_First( chain );
>> 4 while ( !_Chain_Is_tail( chain, iter ) ) {
>> 5 next = _Chain_Next( iter );
>> 6 /**
>> 7 * here Chain_Node *iter can be convert to POSIX_Keys_Rbtree_node *,
>> 8 * because Chain_Node is the first member of POSIX_Keys_Rbtree_node
>> structure.
>> 9 */
>> 10 _RBTree_Extract_unprotected( &_POSIX_Keys_Rbtree,
>> &((POSIX_Keys_Rbtree_node *)iter)->rb_node );
>> 11 _Chain_Extract_unprotected( iter );
>> Thread dispatching is disabled here to level 1.
> 12 the_key = _POSIX_Keys_Get( ((POSIX_Keys_Rbtree_node *)iter)->key,
>> &location);
> This nests the dispatching level to 2.
I would move your code below the _POSIX_Keys_Get() call. There are logically
> two actions: key removal from rbtree and run the destructor. Put comments
> above each block of code indicating what is happening LOGICALLY. Everyone
> can read the code.
> If order is important between the two blocks, document it. I am assuming
> your
> block will move between lines 12 and 13.
> Sorry, Joel, I haven't quite got your idea, what do you mean by "move code
below the _POSIX_Keys_Get() call"?
However, I test the code after add a _Thread_Enable_dispatch() between line
16 and 17, and the error is gone. Is it a proper solution to my problem?
> 13 destructor = the_key->destructor;
>> 14 value = ((POSIX_Keys_Rbtree_node *)iter)->value;
>> 15 if ( destructor != NULL && value != NULL )
>> 16 (*destructor)( value );
>> 17 _Workspace_Free( (POSIX_Keys_Rbtree_node *)iter );
>> 18 iter = next;
>> 19}
>> 20_Thread_Enable_dispatch();
>> Best regards!
>> Zhongwei Yao
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
Best wishes!
Zhongwei Yao
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120709/5e9c1d92/attachment.html>
