disable thread dispatch problem
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Jul 9 14:58:32 UTC 2012
Likely dispatching was still disabled and you returned to the thread
body without scheduling/dispatching to another thread. Your
thread thought it was deleted but really continued past the
pthread_exit() or rtems_task_delete() call.
You must have a Classic API task which fell off the bottom of its
body and returned. If the test is over, you need to exit().
On 07/09/2012 07:32 AM, Ashi wrote:
> 2012/7/9 Sebastian Huber <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>>
> On 07/09/2012 08:28 AM, Ashi wrote:
> 2012/7/6 Sebastian Huber <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>>>
> On 07/06/2012 11:49 AM, Ashi wrote:
> I've a problem of _Thread_Disable_dispatch() function
> in below code.
> It's my
> implementation of _POSIX_Keys_Run_destructors()
> function. I come across the
> problem when I run the psxkey03 test:if
> _Thread_Disable_dispatch() was
> commented out, psxkey03 can run without problem. when
> _Thread_Disable_dispatch() added at line 1(as below),
> psxkey03 will fail. I
> debug it in sparc-rtems4.11-gdb, and find psxkey03
> runs into
> _Internal_error_Occurred() function then stop. I know
> _POSIX_Keys_Get()(at line
> 12) will also disable thread dispatch--does this lead
> to the problem?
> However,
> can't figure out where exactly the problem exists,
> could anyone explain
> it? Thanks!
> The _Thread_Disable_dispatch() can nest. I suppose you
> want to acquire a
> resource in the destructor which is not free. The path to
> _Internal_error_Occurred() should show the problem.
> Sebastian, I follow the calls in gdb, and find the error is:
> Program received signal SIGINT, Interrupt.
> 0x020168b8 in _Internal_error_Occurred
> (the_source=INTERNAL_ERROR_CORE,
> is_internal=true, the_error=5)
> at
> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:58
> 58 _CPU_Fatal_halt( the_error );
> What is the call stack here?
> Hi, Sebastian, the call stack is:
> // #0 0x020168bc in _Internal_error_Occurred
> (the_source=INTERNAL_ERROR_CORE, is_internal=true, the_error=5) at
> #1 0x0202ae58 in _Thread_Handler () at
> ../../../../../../rtems/c/src/../../cpukit/score/src/threadhandler.c:197
> #2 0x0202acb0 in _Thread_Handler () at
> ../../../../../../rtems/c/src/../../cpukit/score/src/threadhandler.c:89
> and the info local shows:
> level = 4198629
> The error=5 is probably INTERNAL_ERROR_THREAD_EXITTED (see also
> Internal_errors_Core_list). How did you terminate the task?
> the task is terminated by Ctrl+C in sparc-rtems-gdb.
> However, as I said in my last post, the problem is gone when I add
> _Thread_Enable_dispatch() at the end of each while iteration...is it
> proper?
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6 <tel:%2B49%2089%2018%2090%2080%2079-6>
> Fax : +49 89 18 90 80 79-9 <tel:%2B49%2089%2018%2090%2080%2079-9>
> rtems-devel mailing list
> rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
> Best wishes!
> Zhongwei Yao
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120709/1ff37de6/attachment.html>
