rtems-libbsd: status update
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Jul 11 19:56:26 UTC 2012
Hi
Jennifer and I have moved to the user space initialization
of the network stack. My recent commits added
31 of the 56 files found in the current cpukit/libnetworking/libc
plus a VERY trimmed down version of the stack initialization
routine which sets IP address, netmask, etc.
There are some of the libc routines in freebsd-userspace
which do NOT currently compile. I left them in but disabled
compiling them until we fix whatever the issues are.
I solved the <freebsd/FILE> where you wanted <FILE> problem.
At this point, initializing the "lo0" interface fails because
we are "not owner". This requires opening an AF_INET
socket. Once this works, we should be able to initialize
the fxp0 interface and try to ping the target.
Help in porting more of the libc support is appreciated.
Joel Sherrill, Ph.D. Director of Research& Development
