pull request for atomic
yangwei weiyang wei.a.yang at gmail.com
Mon Jul 23 08:45:52 UTC 2012
2012/7/23 Sebastian Huber <sebastian.huber at embedded-brains.de>:
> Hi,
> is it possible to squash the commits together?  This makes it easier to
> review.
Hi Sebastian, firstly thank you for your comments. The commits are a
little trivial because all commits are submitted step by step. And i
do not know how to make a pull request on github with a single patch
from first commit to last commit. Or i can generate a patch manually
and send it to mail list.
> Since you wrote the files probably on your own they should have your
> copyright.
OK, i will add the copyright to the appropriate files.
> The file "cpukit/score/cpu/i386/rtems/score/atomic_cpu.h" should include a
> generic file e.g. "cpukit/score/include/rtems/score/genericcpuatomic.h" with
> the type definitions.  I think we can use this generic file on every CPU
> port.
Yeah, agree. And RTEMS support so many architectures so i will think
about what types should be generic to all cpu architecture.
> I suggest to use the following type names:
> Atomic_Int
> Atomic_Long
> Atomic_Int32
> Atomic_Int64
> Atomic_Pointer
OK. and which file follow this rule that i can study the name rule on RTEMS?
> I suggest to rename "atomic_cpu.h" into "cpuatomic.h".  Currently there is
> no header file in the score with a "_".
OK.
> On 07/22/2012 06:08 PM, yangwei weiyang wrote:
>> Hi all,
>> I have made a pull request for review the source code of atomic, and
>> could you give me any comments? thank you!
>> pull request link is blow:
>> https://github.com/RTEMS/rtems/pull/1
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
> rtems-devel mailing list
> rtems-devel at rtems.org
Wei Yang
Best Regards
