pull request for atomic
wei.a.yang at gmail.com
Wed Jul 25 06:00:06 UTC 2012
在 2012-7-25,2:42,Gedare Bloom <gedare at rtems.org> 写道:
> On Tue, Jul 24, 2012 at 12:29 PM, yangwei weiyang <wei.a.yang at gmail.com> wrote:
>> 2012/7/23 Gedare Bloom <gedare at rtems.org>:
>>> On Mon, Jul 23, 2012 at 4:45 AM, yangwei weiyang <wei.a.yang at gmail.com> wrote:
>>>> 2012/7/23 Sebastian Huber <sebastian.huber at embedded-brains.de>:
>>>>> Hi,
>>>>> is it possible to squash the commits together? This makes it easier to
>>>>> review.
>>>> Hi Sebastian, firstly thank you for your comments. The commits are a
>>>> little trivial because all commits are submitted step by step. And i
>>>> do not know how to make a pull request on github with a single patch
>>>> from first commit to last commit. Or i can generate a patch manually
>>>> and send it to mail list.
>>> git rebase -i
>>> should let you specify revision range and squash commits together.
>>> then you can push a new branch and make new request.
>> Hi Gedare, Could you tell me more details about this command.
>> I use git rebase master atomic but all commits do not squash together.
> http://git-scm.com/book/en/Git-Tools-Rewriting-History#Squashing-Commits
Hi Gedare. Thank you for your material, it is very useful for me. And I have squash all the commits and create a new branch atomic-review to pull request. Any comments are welcome.
>>>>> Since you wrote the files probably on your own they should have your
>>>>> copyright.
>>>> OK, i will add the copyright to the appropriate files.
>>>>> The file "cpukit/score/cpu/i386/rtems/score/atomic_cpu.h" should include a
>>>>> generic file e.g. "cpukit/score/include/rtems/score/genericcpuatomic.h" with
>>>>> the type definitions. I think we can use this generic file on every CPU
>>>>> port.
>>>> Yeah, agree. And RTEMS support so many architectures so i will think
>>>> about what types should be generic to all cpu architecture.
>>>>> I suggest to use the following type names:
>>>>> Atomic_Int
>>>>> Atomic_Long
>>>>> Atomic_Int32
>>>>> Atomic_Int64
>>>>> Atomic_Pointer
>>>> OK. and which file follow this rule that i can study the name rule on RTEMS?
>>>>> I suggest to rename "atomic_cpu.h" into "cpuatomic.h". Currently there is
>>>>> no header file in the score with a "_".
>>>> OK.
>>>>> On 07/22/2012 06:08 PM, yangwei weiyang wrote:
>>>>>> Hi all,
>>>>>> I have made a pull request for review the source code of atomic, and
>>>>>> could you give me any comments? thank you!
>>>>>> pull request link is blow:
>>>>>> https://github.com/RTEMS/rtems/pull/1
>>>>> Sebastian Huber, embedded brains GmbH
>>>>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>>>>> Phone : +49 89 18 90 80 79-6
>>>>> Fax : +49 89 18 90 80 79-9
>>>>> E-Mail : sebastian.huber at embedded-brains.de
>>>>> PGP : Public key available on request.
>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>>> _______________________________________________
>>>>> rtems-devel mailing list
>>>>> rtems-devel at rtems.org
>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>>>> Wei Yang
>>>> Best Regards
>> Wei Yang
>> Best Regards
